Old 10-11-2013, 02:31 PM   #197
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Originally Posted by Adeets View Post
Lol if you learn to read before you post you'd see that all that maths have supported the kraftworx.
Fyi if we were comparing the 9psi to 9 psi, as it currently stands the vortech blows it out of the water... As my build shows. It's not the forums fault that they are using some rarity of a dyno that not even the Europeans use, in fact it's not even listed under the wiki page.
its still not really apples to apples, despite borla's shitty collector its still going to be better than the factory catted header that kraftwerks used in testing on pump gas (no cat restrictions). it would have been more fair if they had used the skunk2 header for pump gas as well. as well as optimizing the tune, for all we know these are just base maps that come with the kit.
that said, as it stands you are correct that the vortech has higher numbers right now. i just wanna see pump gas dynos of a C38-71 at 10psi
FreshFRS is offline   Reply With Quote
Old 10-11-2013, 02:40 PM   #198
sw20kosh
Drives: 2013 Black FR-S
The near 300 whp run was with 93 pumpgas.
http://www.ft86club.com/forums/showthread.php?t=41285
Just curious, has anyone been able to replicate that kind of torque curve? Looks beast! I think @Adeets got close no?
Old 10-11-2013, 04:18 PM   #199
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by elopez View Post
http://www.ft86club.com/forums/showp...&postcount=118
repeat, get one your vortech kits out there to kraftwerks and end this nonsense. otherwise, these comparisons are pointless.
nevermind, keeping thread on topic
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 10-11-2013, 04:36 PM   #200
DJCarbine
Thupercharged
DJCarbine's Avatar
just tired of you vortech fanboys hanging out in this thread trying to prove your "vortech manhood", that's all...
I have three posts in here, one was about a JRSC on a K series engine, the other was asking about the compressor map conversions, and the last post was stating that the 300whp dyno was on e85 and how I like when dynos are shown with 93 octane.
Not sure how that makes me a fanboy
IMO there are more anti-vortech people than those claiming the vortech is the best thing ever since cam phasing
Most of the people in here are interested in the potential of the kit and how it will stack up with ALL other forms of FI.
2013 FRS
Vortech V3 11psi
Old 10-11-2013, 07:00 PM   #201
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
You could compare my 92tune to their e85 tune, something something 285hp@9psi, that was done with header and exhaust. Just note they use some obscure dyno that doesn't show up on wiki. Wish they would use a dynojet or mustang... You know, like pretty much all other company's selling shit for our cars.
i've heard of roto-test dynos before, they are pretty rare but we had one up in the area i'm originally from. it read about 15% lower than the dyno-jet. for example i made 440whp in my s2k on a dyno-jet, the same day i made 374 on the Roto-test, wish i had my dyno-sheets still. sold the car and gave the dyno's away with it.
The Following User Says Thank You to FreshFRS For This Useful Post:
Adeets (10-11-2013)
Old 10-11-2013, 07:43 PM   #202
sw20kosh
here's some math for you all:
fa20club vortech dyno = 292.04 - 15% = 248.23
adeets vortech dyno = 274.76 - 15% = 233.54
agreed, math is the the ultimate language.
Why are you subtracting 15% from wheel horsepower
Old 10-11-2013, 07:45 PM   #203
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
I can't find much of anything about the Roto-Test dyno to know if it reads high, low, whatever. My sole reasons for springing on this kit without additional testing is simply:
A) Rotrex has had great results on other platforms so with proper tune and supporting mods the numbers should come in just fine.
B) The piping of this kit is very well laid out IMO. I'm a less is more kind of guy and this layout just appeals to me, except the oil cooler add on. Gonna be a PITA to get at that oil cap.
C) Off set charger on separate belt means I can always limp the car home if the belt breaks.
I appreciate all the posts from the people breaking down the math and throwing out the hypotheticals because the math is usually going to come pretty close and I'm not the type that would sit down and do all that stuff myself. Information is good to have. You can use it or ignore it. Without people doing this type of discussion the thread would just be stagnant until the kit was released and there's more real world results for cars with different configurations performed on different dynos available.
digital_assassin is offline   Reply With Quote
The Following User Says Thank You to digital_assassin For This Useful Post:
Adeets (10-11-2013)
Old 10-12-2013, 01:32 AM   #204
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Is it like a mustang drive up, or is it one where you have to take your wheels off... I always thought OEM uses flywheel dynos, where the engine is actually dyno'd outside of the car.
its a much more complicated looking dyna-pak. Oem's use flywheel dynos for engine development but they also have chassis dyno's to test drivetrain loss and develop more efficiency that way.
Old 10-12-2013, 01:40 AM   #205
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
this guy.. any dyno can read high or low, it really depends on the settings so either of those dynos could produce the same number depending a variety of conditions and factors, temp, pressure, humidity etc. its hard to do dyno leveling this way, quite frankly its wrong and way too basic. it was an example, either of the dyno's in the reference you made could read lower than both dynos i have used, who knows..
Old 10-12-2013, 01:46 AM   #206
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
It's funny because every person will tell you their dyno reads low. I've never once heard someone say my dyno reads perfect or high. It's always a heartbreaker dyno or x% lower than other dynos
Nolan
pheoxs is offline   Reply With Quote
Old 10-12-2013, 01:51 AM   #207
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
that is so true, the guy with the dyno jet said it was a heartbreaker, it reads lowish for the turbo i was running (PTE6262 should be ~470 at the boost i was running), and so did the shop with the roto-test (definitely read low for what i was expecting). it all depends on the software and conditions.
Old 10-12-2013, 02:13 AM   #208
ft_sjo
Drives: GT86
It's a hub dyno. I don't know of any OEM's that use them. Perhaps some race teams, but not the big ones.
The Following User Says Thank You to ft_sjo For This Useful Post:
Adeets (10-12-2013)
Old 10-12-2013, 03:06 AM   #209
gmsii
gmsii's Avatar
unless one is well initiated in the dyno market space, one wouldnt really know much of anything regarding what OEs are or arent using.
Rototest is quite commonly used by OE's who use it for development and validation testing in conjuction with their engine dyno test rigs.
To quote Rototest...'The Rototest HUBDYNO® is arguably the most advanced chassis dynamometer in the world of motorsports, and is used by companies like Adam Opel, DE, Daimler (Mercedes-Benz), DE, Daeki Faurecia, Dongwon Precision, KR, EMCON (ArvinMeritor), CN, FIAT Auto, IT, GKN Technology, UK, General Motors, SA, SAAB Powertrain, SE, KIA Motors, KR and MAHLE Powertrain (Cosworth Technology), UK and Andretti Green Racing, US.'
There are several NASCAR cup teams, ALMS teams, and Indycar teams that are using the dyno, but Rototest is not able to reveal because of NDA agreements in place. At Group-A we are privy to this information because US distributor for the motorsports dyno.
gmsii is offline   Reply With Quote
Old 10-12-2013, 05:22 AM   #210
ft_sjo
Drives: GT86
Originally Posted by gmsii View Post
unless one is well initiated in the dyno market space, one wouldnt really know much of anything regarding what OEs are or arent using..
I work at a major OE powertrain R&D facility. Does that qualify me? We have hundreds of dyno cells.
[TX] DFW General Discussion feedbag Southwest 1488 06-18-2022 07:25 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 03:28 PM
ROTREX SC Brainstorming MANDALAY Forced Induction 61 12-11-2012 05:57 PM
Rotrex kit - why no build? MindtheGap Engine, Exhaust, Transmission 5 10-26-2012 07:01 PM
