Old 10-04-2013, 07:11 PM   #15
vgi
Drives: frs
Originally Posted by Foobar View Post
I saw the question and wondered the same thing and immediately thought "dude must be from the Northeast where most of our roads suck."
I'm on stock suspension with a lip kit and I've scraped that thing just driving on the street, forget about driveways and stuff!
Heh, when I lived in NY I bottomed my tranny in down town manhattan on a stock height civic, had to get a new one.
vgi is offline   Reply With Quote
Old 10-04-2013, 07:22 PM   #16
vgi
Drives: frs
Originally Posted by ayau View Post
Stiffer and OEM length springs won't necessarily give you the factory ride height. All things equal, a stiffer spring with the same OEM length will actually make your ride height taller than factory. This is because a stiffer spring will compress less when you lower the floor jack. Conversely, softer springs will let the spring "sag" more when you lower the floor jack.
What's your reasoning for going with stiffer spring rates? Factory springs are just fine for daily driving purposes.
I did't say 'oem lenght' I said stock height - that is car sitting at the same height on stiffer springs as the car on oem springs. I hope it's clear now.
Are you implying that all people who DD their cars and install coils or springs do it only because they think lowered car looks pretty?
Old 10-05-2013, 01:17 AM   #17
Kostamojen
Originally Posted by vgi View Post
I'm not in a rush right now to add extra weight, the more so upfront.
What weight?
Old 10-05-2013, 05:57 PM   #18
vgi
Drives: frs
Originally Posted by Kostamojen View Post
What weight?
i just looked it up - apparently aftermarket front swaybar is just 1.5-2.5 lbs heavier. not too bad.
Old 10-05-2013, 08:37 PM   #19
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by Zach3794 View Post
May I ask what your reasoning for wanting that is?
maintain OEM static geometry
maintain OEM damper travel (for optimal damper operation and comfort)
if spring balance is maintained, car balance is maintained while increasing weight transfer speed (response) and increasing roll resistance.
i'd want something like this...
The Following User Says Thank You to 7thgear For This Useful Post:
vgi (10-05-2013)
Old 10-06-2013, 01:35 PM   #20
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Well in that case why not just go balls out and do something like Robispec where he's dropped 3" and maintains OEM geometry and travel. Oh wait, I forgot not all of us have like 5k laying around to dump into that :P
Zach3794 is offline   Reply With Quote
Old 10-06-2013, 02:45 PM   #21
wootwoot
Drives: FRS
Ground control sleeve kit may work... Cheap... And I think you can order whatever spring rates you want.
Old 10-06-2013, 11:08 PM   #22
vgi
Drives: frs
that looks interesting, thx a bunch!
18x9.5 stock height stock struts etherealfall Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-11-2017 05:44 AM
Euro GT86 cars have springs with lower ride height? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-29-2013 01:33 PM
Your FAVORITE Rims on STOCK Height taimysho0 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-21-2013 09:40 AM
Need help with Stock height measurement D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-03-2012 03:30 AM
Stock ride height or lower? StevenDavisPhoto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 01-31-2012 10:58 AM
