Drives: frs
stock height stiffer springs?
anyone makes those?
Drives: Mazda 3
I think your only solution are coilovers with longer springs to get the static height up at the expense of droop travel.
*except Ohlins R&T which I think can be run at stock height without longer springs. |
Drives: 2013 Scion FR-S, Raven, Manual
May I ask what your reasoning for wanting that is?
One option is to contact Ground Control. They make everything custom by the order and will help you with whatever you need. |
Drives: 2005 Toyota Camry
Easiest way is to get some type of TRD/STi sport springs, with minimal drop and stiffer rate.
And virtually every type of coilover can be raised to stock height if it features proper design. -alex |
Drives: frs
trivial, driveway clearance. i have a pretty steep driveway to the sidewalk. tried the rubber driveway/curb ramp but it didn't work as the shape underneath didn't match mine.
Drives: frs
i thought about coilovers but it's like 'killing a mosquito with cannon'. it's my DD and wouldn't be using the coils to their full potential.
Custom order for sure. Wont likely find a place selling higher rate springs at stock spring lengths.
Coilovers some will allow you stock height but as said $$ and overkill.
Drives: 1993 Impreza w/ WRX Swap + FWD!
BRZ front springs on your FRS and it will be plenty stiff at stock height.
Drives: frs
@Kostamojen thank you for advice
does anyone actually know the stock FRS and BRZ rates (front and rear)? nevermind, found it: http://www.ft86club.com/forums/showthread.php?t=10416 Last edited by vgi; 10-04-2013 at 12:33 PM. |
#10 |
FYI I'm trying out the stiffer rear FRS springs with the stiff front BRZ springs and I like it a lot, I'm really satisfied. Make sure to get some camber bolts for the front too and maybe a front swaybar.
#11 |
SLO NO MO
I saw the question and wondered the same thing and immediately thought "dude must be from the Northeast where most of our roads suck."
I'm on stock suspension with a lip kit and I've scraped that thing just driving on the street, forget about driveways and stuff! |
#12 |
I wanted it to be a rallycar project :P
#13 |
Drives: Some rust bucket
Stiffer and OEM length springs won't necessarily give you the factory ride height. All things equal, a stiffer spring with the same OEM length will actually make your ride height taller than factory. This is because a stiffer spring will compress less when you lower the floor jack. Conversely, softer springs will let the spring "sag" more when you lower the floor jack.
What's your reasoning for going with stiffer spring rates? Factory springs are just fine for daily driving purposes. |
#14 | |
Drives: frs
| 18x9.5 stock height stock struts | etherealfall | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 07-11-2017 05:44 AM |
| Euro GT86 cars have springs with lower ride height? | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 09-29-2013 01:33 PM |
| Your FAVORITE Rims on STOCK Height | taimysho0 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-21-2013 09:40 AM |
| Need help with Stock height measurement | D1cker | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 08-03-2012 03:30 AM |
| Stock ride height or lower? | StevenDavisPhoto | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 156 | 01-31-2012 10:58 AM |
