Old 10-03-2013, 04:54 PM   #1
vgi
Drives: frs
stock height stiffer springs?
anyone makes those?
vgi is offline   Reply With Quote
Old 10-03-2013, 05:01 PM   #2
autobrz
Drives: Mazda 3
I think your only solution are coilovers with longer springs to get the static height up at the expense of droop travel.
*except Ohlins R&T which I think can be run at stock height without longer springs.
autobrz is offline   Reply With Quote
Old 10-03-2013, 05:08 PM   #3
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
May I ask what your reasoning for wanting that is?
One option is to contact Ground Control. They make everything custom by the order and will help you with whatever you need.
Zach3794 is offline   Reply With Quote
Old 10-03-2013, 05:45 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Easiest way is to get some type of TRD/STi sport springs, with minimal drop and stiffer rate.
And virtually every type of coilover can be raised to stock height if it features proper design.
-alex
Old 10-03-2013, 09:17 PM   #5
vgi
Drives: frs
trivial, driveway clearance. i have a pretty steep driveway to the sidewalk. tried the rubber driveway/curb ramp but it didn't work as the shape underneath didn't match mine.
Old 10-03-2013, 09:20 PM   #6
vgi
Drives: frs
i thought about coilovers but it's like 'killing a mosquito with cannon'. it's my DD and wouldn't be using the coils to their full potential.
Old 10-03-2013, 11:33 PM   #7
Dezoris
Dezoris's Avatar
Custom order for sure. Wont likely find a place selling higher rate springs at stock spring lengths.
Coilovers some will allow you stock height but as said $$ and overkill.
Old 10-04-2013, 01:30 AM   #8
Kostamojen
BRZ front springs on your FRS and it will be plenty stiff at stock height.
Old 10-04-2013, 10:56 AM   #9
vgi
Drives: frs
@Kostamojen thank you for advice
does anyone actually know the stock FRS and BRZ rates (front and rear)?
nevermind, found it:
http://www.ft86club.com/forums/showthread.php?t=10416
Old 10-04-2013, 02:32 PM   #10
Kostamojen
FYI I'm trying out the stiffer rear FRS springs with the stiff front BRZ springs and I like it a lot, I'm really satisfied. Make sure to get some camber bolts for the front too and maybe a front swaybar.
Old 10-04-2013, 02:46 PM   #11
Foobar
SLO NO MO
Foobar's Avatar
I saw the question and wondered the same thing and immediately thought "dude must be from the Northeast where most of our roads suck."
I'm on stock suspension with a lip kit and I've scraped that thing just driving on the street, forget about driveways and stuff!
Old 10-04-2013, 04:41 PM   #12
Zach3794
I wanted it to be a rallycar project :P
Old 10-04-2013, 04:51 PM   #13
ayau
Drives: Some rust bucket
Stiffer and OEM length springs won't necessarily give you the factory ride height. All things equal, a stiffer spring with the same OEM length will actually make your ride height taller than factory. This is because a stiffer spring will compress less when you lower the floor jack. Conversely, softer springs will let the spring "sag" more when you lower the floor jack.
What's your reasoning for going with stiffer spring rates? Factory springs are just fine for daily driving purposes.
Old 10-04-2013, 07:06 PM   #14
vgi
Drives: frs
I'm not in a rush right now to add extra weight, the more so upfront.
18x9.5 stock height stock struts etherealfall Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-11-2017 05:44 AM
Euro GT86 cars have springs with lower ride height? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-29-2013 01:33 PM
Your FAVORITE Rims on STOCK Height taimysho0 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-21-2013 09:40 AM
Need help with Stock height measurement D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-03-2012 03:30 AM
Stock ride height or lower? StevenDavisPhoto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 01-31-2012 10:58 AM
