Old 07-11-2013, 08:29 AM   #43
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by buditjoenawan View Post
I agree completely, but since the Vortech system doesn't have a hotside, we can't compare that....
budi
Restriction on the exhaust side contributes to pressure in the intake manifold at any given flow rate, yet another reason 10psi turbo /= 10psi sc
Old 07-11-2013, 09:00 AM   #44
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
Ah....yes.... but have you considered the pressure differential across the intake valve? And how it can be affected by intake valve opening angle?
Toma is offline   Reply With Quote
Old 07-11-2013, 09:06 AM   #45
Toma
Boost is nothing more than resistance to flow. Try and jam more air volume into an engine than it can move through itself and it backs up.... ie.... boost.
Assuming constant air flow supply... increasing displacement, adding a cam, porting the head etc... and for the same air 'supply' , 'boost' will drop.
There is no question that for the same mass flow, the turbo makes more power.
Look at any racing class where they limit compressor sizes and dictate weights. Outlaw drag radial is where we race. The turbo cars have to be 200 plus pounds heavier and the supercharged cars can have much bigger impellers. Guys running blowers at our level have said that it takes upwards of 300+ hp right off the crank to move the 2000+ hp of air that they are
Old 10-03-2013, 02:04 PM   #46
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
For the love of...
If someone would just buy a SC and a Turbo, boost them both to the same psi (lets say 10 for simplicity's sake) and then spend a whole day swapping between stock, SC, and TC on the same dyno, attempting to maintain the same atmospheric temperature, then we can finally see the end to this madness
MADNESS!
I figure as long as you smile while driving the car, you're doing it right.
SillySaxon is offline   Reply With Quote
Old 10-03-2013, 08:57 PM   #47
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Originally Posted by SillySaxon View Post
For the love of...
MADNESS!
I think you should do it.
Sellout is offline   Reply With Quote
Old 10-03-2013, 11:29 PM   #48
SillySaxon
SillySaxon's Avatar
Now taking donations
Sent from my SGH-T999 using Tapatalk 2
Old 10-04-2013, 01:05 PM   #49
MikeW
MikeW's Avatar
Drives: 2013 BRZ | 2013 WRX | 1991 318i
If people are so worried about efficiency than why do either? Max efficiency will be achieved by taking the bus.
MikeW is offline   Reply With Quote
The Following User Says Thank You to MikeW For This Useful Post:
Frs300 (10-04-2013)
Old 10-04-2013, 01:41 PM   #50
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Buses use turbos by the way.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Foobar (10-04-2013), MikeW (10-04-2013)
Old 10-04-2013, 02:21 PM   #51
MikeW
MikeW's Avatar
[ame="http://www.youtube.com/watch?v=GRvcfIqFENA"]http://www.youtube.com/watch?v=GRvcfIqFENA[/ame]
AVO Stage 1 Turbocharger Kit BRZ / FR-S Now Available For Pre-Order! Boston Motorsports Forced Induction 82 07-23-2013 11:42 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 02:47 PM
Suggestions for more horsepower! Turbocharger upgrade + more! forzajuve Forced Induction 14 04-10-2013 08:51 PM
Report: BRZ STI Model Already in the Works, No Turbocharger Sport-Tech BRZ First-Gen (2012+) — General Topics 188 08-30-2012 05:53 PM
