Old 10-02-2013, 12:12 PM   #15
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Originally Posted by Adeets View Post
You need to contact your tuner, and get it to a dyno or street tune. That's unsat.
That's Toni@Fa20club
I sent him a datalog nothing yet..
Scalzo is offline   Reply With Quote
Old 10-02-2013, 12:14 PM   #16
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Is this the can tune? If it is Toni, make sure you keep sending data logs, even when your happy with the tune, he will get this sorted out.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 10-02-2013, 12:16 PM   #17
Scalzo
Scalzo's Avatar
Yeah the e-tunes. It also doesn't help I dont have an intake tube :/
Old 10-02-2013, 12:16 PM   #18
Adeets
OEDC
Adeets's Avatar
Maybe want to call fa20club, he could be sick or on vacation, that looks like he wasn't quite done fixing you yet before u dyno'd it.
My BRZ FI Build
Old 10-02-2013, 12:17 PM   #19
Adeets
OEDC
Adeets's Avatar
When you say you don't have an intake tube, can you explain?
My BRZ FI Build
Old 10-02-2013, 12:21 PM   #20
Scalzo
Scalzo's Avatar
I meant the pipe, from the turbo.
Check my build thread look at my intake, it's connect straight on the turbo.
Old 10-02-2013, 02:02 PM   #21
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I thought the issue was 3rd gear felt good and 4th gear didn't. Can you post more than a Virtual Dyno?
Old 10-02-2013, 02:04 PM   #22
Scalzo
Scalzo's Avatar
That is pretty indicative of a fuel pump issue. I am not sure it is the tune if it was previously running fine.
Ever since I put the 3" turbo back i've had this prob, I'm putting the new fuel pump next summer along with injectors. I called Toni he said hes gonna check the datalog
Old 10-02-2013, 02:06 PM   #23
Scalzo
Scalzo's Avatar
Want me to post my datalog?
Old 10-02-2013, 02:09 PM   #24
King Tut
NASA SpecE30 Racer
King Tut's Avatar
If Toni is looking at it you should be good. Your AFR definitely should not increase like it starts to at 5200 RPM which could be a fuel pressure issue due to the pump or could be the tune. I still don't see any of this making a difference depending on what gear you are in.
Old 10-02-2013, 02:30 PM   #25
Scalzo
Scalzo's Avatar
Could it also be that My intake is on the turbo and not attached to the intake pipe? Thats why I run lean?
Old 10-02-2013, 02:52 PM   #26
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Shouldn't make any difference.
Old 10-02-2013, 03:17 PM   #27
Fabron757
Drives: 2013 blue frs m6 BW EFR 7064 Turbo
Here is a video of a turbo frs in 4th at 4k rpms. Don't know if this helps.
[ame="https://www.youtube.com/watch?v=BvQH0pYrmJM"]Frs Turbo EFR 7064 4th Gear pull at 60mph. - YouTube[/ame]
Fabron757 is offline   Reply With Quote
Old 10-02-2013, 03:25 PM   #28
Scalzo
Scalzo's Avatar
I'll do a pull from 4th gear at 60mph as well to compare, your rpm seems to go through faster
DIY fender rolling and pulling? OICU812 DIY (Do-It-Yourself) Guides 12 01-02-2017 09:02 PM
Brz pulling trailer? subiesteve Southwest 7 11-20-2013 09:04 PM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
Pulling your FRS off of the lot, what are you bumpin'?? poormans_LFA BRZ First-Gen (2012+) — General Topics 201 06-09-2012 09:52 PM
Pulling the trigger tomorrow Style Scion FR-S / Toyota 86 GT86 General Forum 13 05-14-2012 02:38 PM
