Old 09-25-2013, 03:03 AM   #1
DarkestBuddha
Drives: BRZ limited GBS
ABS and Traction lights come on while driving (video)
Here is a video of the ABS and Traction lights coming on as I am driving.
It can come on randomly, but i was able to reproduce it on uneven corners.
Here im driving up my office building garage in 2nd.
I have also gotten this in 6th on the freeways.
When i turn the car off and back on the lights will usually be off.
However, tonight when i turned the car on to head home, the ABS and Traction lights came on with the car. First time this has happened.
When the lights come on, i can feel no difference in driving tho.
Has anyone else run into this issue?
EDIT: Also the 3rd brake lights (on the rear window) seems to come on as well. the lights in the 3rd brake light are "dim" and when i brake they get brighter.
also, i dont know if this makes a difference, but i have a 4th brake light kit that is tapped into the left brake light.
[ame]http://youtu.be/zrKge2cOBGU[/ame]
DarkestBuddha is offline   Reply With Quote
Old 09-25-2013, 06:59 AM   #2
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Different sized wheels/tires? Strange...
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 09-25-2013, 11:38 AM   #3
DarkestBuddha
its on stock tires
Old 09-25-2013, 11:51 AM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
Check your ABS sensor wires. I'm betting one may be chewed up
Old 09-25-2013, 12:27 PM   #5
dehydratedH2O
Drives: 2014 BRZ Limited DGM
Take it to the dealer. You have a video as proof. You have a warranty for a reason.
dehydratedH2O is offline   Reply With Quote
Old 09-25-2013, 12:41 PM   #6
DarkestBuddha
yea i will be taking it in this weekend.
they couldnt reproduce it last time so they asked if i can get some video so they can have proof when they contact subaru.
when they hooked up my car, they said the logs showed no errors or warnings at all.
Old 10-02-2013, 01:12 AM   #7
JayV
JayV's Avatar
Drives: Subaru BRZ
I have the forth brake light installed 2 days ago and today that same thing happened to me.... It has to be something with the light thing. I too installed it off my left taillight....
JayV is offline   Reply With Quote
Old 10-02-2013, 01:46 AM   #8
DarkestBuddha
i found that the Black wire that was tapped was loose.
check all your connections and make sure they aren't loose.
Old 10-02-2013, 10:49 AM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Have a read. http://www.ft86club.com/forums/showthread.php?t=24246
The Following User Says Thank You to Sportsguy83 For This Useful Post:
DarkestBuddha (10-02-2013)
traction control and abs lights coming on after 20mins? UnLeasHer AUSTRALIA 28 02-23-2015 10:52 AM
Gauge Lights Change Color In Traction Off Mode dkrou351 Cosmetic Modification (Interior/Exterior/Lighting) 12 04-18-2013 09:49 PM
VIDEO on TRACK: VSC ON vs. TRACTION OFF MarkMash FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 04-02-2013 12:46 AM
CEL/Traction Control Lights artizhay Issues | Warranty | Recalls / TSB 5 11-04-2012 11:33 PM
