Old 09-17-2013, 08:13 PM   #43
charged86
charged86's Avatar
I pulled my throttle body. charge pipe and ac compressor. in about 45mins worm clamps in three locations. on the way to the gym. bro
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
SkAsphalt (04-08-2014)
Old 09-17-2013, 09:23 PM   #44
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
avishenoy1 (04-14-2016), Cessblood (09-17-2013), charged86 (04-08-2014)
Old 09-18-2013, 01:31 AM   #45
charged86
charged86's Avatar
Do you even lift bro. Hahahaa
Sportsguy83 (09-18-2013)
Old 09-18-2013, 02:30 AM   #46
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
If you stare into the gif long enough you start to trip
Or maybe that is just me. Too many sunshines.
448hpsti is offline   Reply With Quote
The Following User Says Thank You to 448hpsti For This Useful Post:
Old 10-02-2013, 09:04 AM   #47
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
PSA: Clamping EVAP hoses under Intake Manifold, the easy way..
Moved the AC compressor and to my surprise, all the evap lines were already clamped from the factory, including the one under the throttle body towards the passenger side.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 10-02-2013, 09:50 AM   #48
Sportsguy83
Drives: Limited BRZ
That's a first!!! Maybe they do read the forums and have upgraded their assembly line!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
ecko04 (10-02-2013)
Old 10-02-2013, 05:13 PM   #49
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
I'll add I picked my car up around March so i'd venture to say it was built at the beginning of the year.
I was shocked when I saw everything had been clamped, mainly because I needed something to do that day, but maybe it was a "rolling change", who knows.
The Following User Says Thank You to ecko04 For This Useful Post:
Sportsguy83 (10-02-2013)
Old 01-03-2015, 04:50 PM   #50
xDanger_208x
xDanger_208x's Avatar
Drives:
What are the symptoms when this happens??
I clamped my lines when I installed the KW kit, but have recently encountered problems and I'm wondering if one of them came off.
xDanger_208x is offline   Reply With Quote
Old 01-03-2015, 05:50 PM   #51
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Did mine today. Pulled the intake though. Wasnt a bad job. Just a little time consuming.
Sent from HTC M8 while in burnout mode
cruizin01 is offline   Reply With Quote
Old 01-05-2015, 11:03 AM   #52
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The symptoms are a struggling idle and a very loud and very noticeable hissing sound from under the manifold.
Old 01-05-2015, 11:04 AM   #53
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Exactly. Nice to see I am not the only one that wanted to pull the manifold to do it.
Old 01-18-2015, 03:51 PM   #54
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
I removed the AC compressor and still was a bit annoying to removing and reconnect the solenoid only to find out that i need to remove again because the line under the manifold is still lose.. i only clamped the two lines on the solenoid. How the hell do you get the line under the manifold? Do you have to remove the TB? Thanks
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 01-18-2015, 04:08 PM   #55
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Yep, A/C compressor and TB need to be taken off.
EDIT: Here's a photo of how easy it is with the TB off:
alexand3r is offline   Reply With Quote
The Following User Says Thank You to alexand3r For This Useful Post:
Old 01-18-2015, 04:42 PM   #56
yomny
yomny's Avatar
Did you have to replace the tb gasket? You have any pics of it? Thanks a million bro, you've saved me a headache as its pretty tough to find info on things like that.
DIY clamping the evap vacum ports under the manifold!! charged86 DIY (Do-It-Yourself) Guides 9 04-08-2015 06:56 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Aluminium intake manifold? Hempo Engine, Exhaust, Transmission 18 06-27-2013 01:19 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
Custom Hello Kitty Intake Manifold Cover (seriously?) Hancha Group Cosmetic Modification (Interior/Exterior/Lighting) 6 04-01-2013 01:36 PM
