Old 09-24-2013, 03:09 PM   #1807
ft_sjo
Drives: GT86
You need to disable another DTC in the calibration to stop P0420 being generated.
I'm interested in seeing dyno graphs from those with UEL headers installed.
Old 09-24-2013, 03:38 PM   #1808
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Thanks ft_sjo... I will pass that to my tuner if it trips again.
Old 09-24-2013, 05:24 PM   #1809
xjohnx
Grip>Slip
xjohnx's Avatar
Just waiting on the map sensor and a tune that has been adjusted for the IAT sensor.
Old 09-24-2013, 05:27 PM   #1810
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
Originally Posted by DarrenDriven View Post
RevWorks UEL on mine.
...and uh-oh, CEL P0420: Catalyst System Efficiency Below Threshold (Bank 1)
Cleared the three identical codes and it hasn't tripped again. Maybe a fluke?
I know with my header code will come on and off... every few days... I forgot to have Delicious Tuning disable 420 code. I might ask them to do that when I send some him some logs of my car for a touch up.
JesseE is offline   Reply With Quote
Old 09-24-2013, 07:33 PM   #1811
Ethan
Drives: Subaru BRZ
What size pulley is that?
Ethan is offline   Reply With Quote
Old 09-24-2013, 08:23 PM   #1812
xjohnx
Grip>Slip
xjohnx's Avatar
70mm
Ethan (09-24-2013)
Old 09-25-2013, 12:18 AM   #1813
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Very nice, just waiting for mine as well.
Map sensor obviously goes on top? Can't see the hole with the angle of your pic.
What size map sensor you fitting.
Ryan86 is offline   Reply With Quote
Old 09-25-2013, 12:32 AM   #1814
xxscaxx
Drives: 2013 SWP BRZ
it goes right next to the IAT sensor, to the right of it in that pic.
Would have to guess OMNI 3 Bar MAP Sensor.
xxscaxx is offline   Reply With Quote
Old 09-25-2013, 01:04 AM   #1815
ft_sjo
Drives: GT86
For those with charge coolers fitted, keep an eye on the de-gas hose near where it goes back up to the overflow tank. It can rub on the fuel injector cover and wear the hose down. Mine lost a couple of mm in just one week! Needs reinforcement or tying up somewhere.
Old 09-25-2013, 01:12 AM   #1816
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Serial number and dat sexy supercharged engine bay.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
The Following User Says Thank You to Khorne For This Useful Post:
DarrenDriven (09-25-2013)
Old 09-25-2013, 01:22 AM   #1817
ft_sjo
Drives: GT86
@Khorne - What antifreeze is that?
Old 09-25-2013, 03:51 AM   #1818
Ryan86
Road Warrior
Ryan86's Avatar
Identified the problem, map sensor loom/harness for the 2.5 map had a pin missing. Harness was under the manifold so could not identify while checking.
I've heard rumor this problem has been identified, so double check your harness before connecting.
Old 09-25-2013, 07:43 AM   #1819
xjohnx
Grip>Slip
xjohnx's Avatar
Using the OMNI 3 Bar right now, however that may change in the near future. details to come in a bit.
Old 09-25-2013, 08:05 AM   #1820
ft_sjo
Drives: GT86
Mine had a pin missing too.. but not the same as yours, but the IAT one!
The Following User Says Thank You to ft_sjo For This Useful Post:
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
