Old 09-16-2013, 04:51 PM   #491
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Originally Posted by EINSTEIN562 View Post
Just checked mine using the Torque app....01C
Jan 2013 build date
Well, this flies in the face of my theory about different coasts getting different tunes. So far I'd noticed that all the guys with 01C had been on the east coast where better gas is available.
Decay107 is offline   Reply With Quote
Old 09-16-2013, 06:57 PM   #492
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Jan 2013 build date
Good to see on a nother 01/13 car. I'm going to check mine tomorrow.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 09-16-2013, 07:02 PM   #493
suaveflooder
Jan 2013 build date
Happen to know a date? Mine is an early January build
suaveflooder is offline   Reply With Quote
Old 09-16-2013, 07:40 PM   #494
EINSTEIN562
EINSTEIN562's Avatar
Drives: 2017 Subaru BRZ
No, but I will be going to the dealer for an oil change soon and I can find out then.
Ice Silver 2017 BRZ w/PP 6MT | Driver Mod |
EINSTEIN562 is offline   Reply With Quote
Old 09-16-2013, 08:22 PM   #495
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
it's in the door jam : Manufacturing date MM/YY
smbstyle is offline   Reply With Quote
Old 09-17-2013, 04:33 AM   #496
Freude am Fahren
01/13 Build date with 01C according to Torque.
Old 09-18-2013, 10:59 AM   #497
stugray
Drives: 2013 GBS BRZ Limited
I also emailed my Subaru dealer maintenance manager today to ask about the latest ECU upgrade and I referred to the Toyota TSB shown a few pages back.
The response from the dealer was: "I checked for available reflashes from subaru, the only ones I have available at this time are for 2013 fed/cal at/mt update for obdII thermosat monitoring with dtc poo17, poo19, p1235 with cal ID ZA1JA00D AND ZA1JA00C. What we might want to do is do that particular reflash and see if ti takes care of it, sometimes there are multiple items it reflashes in the one reflash file so it might help you."
So I can get flashed up to ZA1JA00C but not 1C.
So it looks like I will get an Openflash tablet and upgrade to 1C myself (or Shiv's stock reflash).
Old 09-18-2013, 12:35 PM   #498
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
Originally Posted by DarkSunrise View Post
I'm outside the VIN range too.
Someone should check whether all cars that have had DI failures all fall within the "affected" VIN range:
- 1700031 - 1707728
- 2700032 - 2707727
@CSG Mike
others...?
So I just checked my car and I have the vin# of 1706467, FUCK!! I guess I'm kind of confused and I'm trying to figure out what's exactly going wrong here. So does my car not have a functioning DI system now or something? God fucking dammnit!
SkitterSkotter is offline   Reply With Quote
Old 09-18-2013, 02:39 PM   #499
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
I'm juuuuuuust outside the first range.
Evil Jesus is offline   Reply With Quote
Old 09-19-2013, 04:20 PM   #500
Decay107
Decay107's Avatar
It is in the "Adapter Status" tab in "Calibration ID"
I'm having trouble finding these menu options, the closest I have is "OBD Adapter Information" under the "More" menu in the bottom corner. When I do click here I am taken to a page of links to compatible adapters. I have a few questions
1. Is everyone here using the pro version? (I have the free version right now)
2. Does it have to be the ELM327 Adaptor? I have the BAFX one and it seems to communicate just fine and I'm not sure how changing a bluetooth adapter would affect the menu choices within an app.
I have a March '13 build and would really like to know which calibration I have.
Old 09-19-2013, 10:41 PM   #501
yuicebox
Drives: Asphalt FRS
March 2013 Build date, 01C! Thrilled right now.
yuicebox is offline   Reply With Quote
Old 09-19-2013, 10:42 PM   #502
yuicebox
Drives: Asphalt FRS
Yeah I'm fairly certain you need the pro version. The interface is different, it's a circle which you can rotate and there's one option that's ODB Adapter Settings or something
Old 09-19-2013, 11:15 PM   #503
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
I'm relatively new to this topic so if this might have been previously answered. I just want to know this:
If my car is outside of the VIN range, does this automaticaly mean that I dont have 01C? if so does that mean my car is at risk?
The cars in the VIN range are eligable for the update and should be A+?
headlikeahole is offline   Reply With Quote
Old 09-19-2013, 11:30 PM   #504
yuicebox
Drives: Asphalt FRS
Being outside Vin range means nothing. Past that I suggest reading older posts in this thread (if I knew it all id tell you) and buying an odbii blue tooth adapter and checking your calibration yourself
regalsurinalpost
Raven down! Mechanical failure :( rasec29 Issues | Warranty | Recalls / TSB 151 10-08-2013 11:25 AM
86 rentals - 2013 era bcj AUSTRALIA 11 04-23-2013 10:27 PM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
BC Coilover failure in the past phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-25-2012 05:07 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
