Old 10-25-2012, 11:27 AM   #1
phenom86
phenom86's Avatar
Drives: Scion FRS Asphalt
BC Coilover failure in the past
I've been reading through different forums about how BC coilovers failed in customer's cars under normal conditions in the past, hope its made better now.
Evo X owner (2010):
The main threaded tube snapped when he went over a bump at just 65mph.
Edit: The driver ran over rumble strips
Mazda 3 owner (2009):
Hit an uneven surface
phenom86 is offline   Reply With Quote
Old 10-25-2012, 11:31 AM   #2
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
now im scared
Old 10-25-2012, 11:46 AM   #3
Dustin@Dynosty
we have been selling BC Racing coilovers for many years now and not once had a failure, if you spend the time you can search through find failures for just about every company out there... i spent 2 minutes looking for a failure on a KWs and found this... i could probably do the same for many others...
http://volvospeed.com/vs_forum/topic...need-help-wtf/
When someone has an issue with a product they are quick to post up about their bad experience and how terrible they think a product may be but that may be 1/1000 or 1/10000 failure rate (not saying that either is acceptable), but no manufacturer is perfect, they can not control all of the variables to ensure their product is installed and used properly, and not abused. While we are a big supporter of BC im not stating that they can not or will not have issues at times but I am just making it clear that there is not a "perfect" manufacturer out there and BC is normally quick to stand behind their product when an issue does arise and that is the more important issue.
Dustin@Dynosty is offline   Reply With Quote
Old 10-25-2012, 11:50 AM   #4
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
You gotta pay to play.
Brand X - 800-1,200
Brand Y - 2,500-3,200
Which one do you think is gonna be better?
I've only heard good things about BC. But if it seems to good to be true, you know the rest.
Ninja edit: Just did a quick Google on Brand A-Z Coilover Failure. Not really surprising to see which ones have the most failures.
Beyer Subaru is offline   Reply With Quote
Old 10-25-2012, 11:54 AM   #5
#87
I usually post drunk
#87's Avatar
Brand X - 800-1,200
Is this like comparing PC to Mac?
#87 is offline   Reply With Quote
Old 10-25-2012, 12:12 PM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
no
because the interface and packaging is the same
the question is of material choice, thickness and quality of welds
also seal quality
while i personally don't have any support for BC coilovers, i'm of the opinion that pretty much all of these horror stories are a result of of a combination of incorrect installation or use.
for instance, over-torquing, slamming, driving like a fool, etc.
Old 10-25-2012, 12:30 PM   #7
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
I have known a ton of people using BC and nobody I know has had a failure. I think Slamming, or improper installation or use were probably factors.
jadewbj is offline   Reply With Quote
Old 10-25-2012, 12:34 PM   #8
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
I dont know the story on the Evo but i am sure he wasn't just going over a "bump".
That Mazda 3 guy hit a bag of concrete or something at Highway speeds.
The BC coilovers are perfectly fine and safe for street use. I used them on 3 of my personal cars and I wouldn't hesitate to do it again.
Realistically this is just a Troll post.
Circuit Motorsports is offline   Reply With Quote
The Following User Says Thank You to Circuit Motorsports For This Useful Post:
_F-R-S_ (10-25-2012)
Old 10-25-2012, 12:43 PM   #9
phenom86
phenom86's Avatar
Here is the information that i got from Lancer Register..
http://www.lancerregister.com/showpo...1&postcount=12
"My issue was never knocking. My BC units covered about 3000 miles from new, mainly road miles whilst running in new engines, a few hundred track miles in sprints and 1 tarmac rally on a flat airfield. When I drove the car over the rumble strips at Teeside at approx 65mph with the steering straight, as I would expect to do with any car, they sheered at the main tube and caused me to crash. This was the first and last time I'd driven over such rumble strips with BC-Racing coilovers."
Old 10-25-2012, 01:19 PM   #10
Circuit Motorsports
You'll never know thew whole story, he said he did a few hundred track miles, sprints and rallies.
He could have damaged the suspension at anytime, maybe cracked it, and the rumble strips were what caused the final failure. An off, a jump, etc. Anything could have caused it.
A car that is going to be driven hard and "raced" needs to have it's suspension checked over periodically to check for any issues.
The BC kits are going to be the same structurally as pretty much any of the Asian coilovers; Tein, Megan, Ksport, D2, Cucsoc, Greddy, Tanabe, etc.
I'm just posting this so people are aware and can be properly educated.
The Following 2 Users Say Thank You to Circuit Motorsports For This Useful Post:
armythug (10-25-2012), karma003 (11-01-2013)
Old 10-25-2012, 01:19 PM   #11
chutrain
chutrain's Avatar
Drives: WRB BRZ
Usually you get what you pay for. The more expensive stuff tend to use better technology such as quality materials and better valving and spring rates. They do the R&D necessary to find the best balance. The lesser tend to copy the higher end. Not necessarily inferior all the time, but there are some sacrifices to bring costs down. If used correctly, there should be no reason for any brand to fail prematurely. By prematurely I mean by the company's standards.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 10-25-2012, 01:43 PM   #12
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
KW had an issue as well. Anything can happen depending on the conditions.
http://www.6speedonline.com/forums/9...ar-spring.html
Old 10-25-2012, 01:46 PM   #13
Beyer Subaru
Yerp. This reminds me of the motivational posters of Volks breaking. "Where's your god now?".
Old 10-25-2012, 02:10 PM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Agreed that everything can fail.
Although I'd rather have a spring break than a damper body
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
RRnold (10-25-2012)
Raven down! Mechanical failure :( rasec29 Issues | Warranty | Recalls / TSB 151 10-08-2013 11:25 AM
Is HellaFlush a thing of the past? RYU Off-Topic Lounge [WARNING: NO POLITICS] 67 10-13-2012 02:46 PM
Drove past a GT-86 convoy creation Scion FR-S / Toyota 86 GT86 General Forum 0 07-20-2012 07:58 AM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
A pessimist's take on sales success / failure Mess11 Scion FR-S / Toyota 86 GT86 General Forum 137 11-24-2011 01:10 PM
