#449 |
I don't think you're in the clear from my understanding. The printout suave has on this page is most likely the ECM recall, which doesn't address the DI issue.
#450 | |
The lower part of the paper is just an emissions fix for the state of California. That particular update was done before I even purchased the car. |
#451 | |
Drives: '13 FRS - STX
I never assumed I was in the clear, mostly I was posting that going to the dealer would likely be a waste of time for me. Edit: Below suave confirmed below that those vin ranges are for the calibration being discussed, just adding a data point that the range is pre-Dec. 2012, likely back to October. |
#452 |
#453 |
I assume they would not tell you the VIN range for that fix?
#454 |
| The Following User Says Thank You to suaveflooder For This Useful Post: | strat61caster (08-23-2013) |
#455 |
Drives: 22 GR86, 13 FR-S, AP2 S2000
#456 |
Drives: FR-S 6MT
It looks like their system is automated and they can't force an update if the VIN range isn't within the range of VINs affected.. It's going to take an official campaign for those with pre-FEB 13 VIN numbers to get the updated programming. Stupid large corporations.. They have their clumsy fool proof systems that aren't easy to work around..
#457 |
I'm outside the VIN range too.
Someone should check whether all cars that have had DI failures all fall within the "affected" VIN range: - 1700031 - 1707728 - 2700032 - 2707727 @CSG Mike others...?
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | yuicebox (08-23-2013) |
#458 |
Mentat
Drives: 2013 Scion FRS 6MT
My vin is 171XXXX. I guess i cannot get the update
#459 |
Ours is a BRZ, but FWIW, we're not in that range.
#460 | |
It just doesn't make sense there would be a "Campaign" for ZA1JA01C when haven't heard of any TSB or recall. I hope i'm wrong. |
| The Following User Says Thank You to Hanakuso For This Useful Post: | strat61caster (08-23-2013) |
#461 |
Drives: Asphalt FRS
172XXXX VIN here, March 2013 Manufacture date. Pretty sure I'm in the clear, next time I'm in the dealer I'll get them to check the ECU version and write it down.
#462 |
Drives: Scion FR-S/Toyota Yaris
That's just the letter about the CEL flash (the one from last year.) Hopefully the dealers will get a bulletin to flash the newest calibration on our 2012 cars, if not we need to know if there was a part number change somewhere on the engine, like say the heads.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
| Tags |
| regalsurinalpost |
| Raven down! Mechanical failure :( | rasec29 | Issues | Warranty | Recalls / TSB | 151 | 10-08-2013 11:25 AM |
| 86 rentals - 2013 era | bcj | AUSTRALIA | 11 | 04-23-2013 10:27 PM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 08:32 PM |
| BC Coilover failure in the past | phenom86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 10-25-2012 05:07 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) — General Topics | 9 | 01-30-2012 12:25 PM |
