Old 09-16-2013, 11:19 PM   #407
ScionFrsFan
When will this be ready for autos?
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 09-16-2013, 11:58 PM   #408
Rombinhood@OpenFlash
Drives: FRS
I'd estimate 1-2 weeks. Nothing is stopping us from supporting 6at now. We just wanted to get the 6mt rolling forward smoothly first. Which seems to be the case based upon feedback today
Rombinhood@OpenFlash is offline   Reply With Quote
The Following 2 Users Say Thank You to Rombinhood@OpenFlash For This Useful Post:
enwave (09-17-2013), ScionFrsFan (09-17-2013)
Old 09-17-2013, 12:09 AM   #409
Drives: FRS
Originally Posted by sierra View Post
There was lots of talk about Ecutek not being visible to dealer inspection but it wasn't convincing. Is this obvious to a dealer ECU check, either with the modified map or the original map replaced?
No Openflash tune, stock or otherwise, contains any license code. Nor do they restrict read/write functions. So it should be diagnostically invisible on all levels. Especially if you flash back in your original file which is stock, byte for byte.
Old 09-17-2013, 12:09 AM   #410
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by Rombinhood@OpenFlash View Post
I think there is some throttle position adaptation that needs to occur after every reflash or ecu reset. Basically the ecu needs to recognize the TPS voltage that represents 0% throttle. Doesn't take too long for it to sort itself out though. All it needs to record is minimal TPS voltage during a drive cycle.
It takes a drive cycle or two for the pedal resoponse off idle to come back to pre flash conditions. This is due to the drive by wire system re learning the closed and open throttle position values.
The Following User Says Thank You to mad_sb For This Useful Post:
Rombinhood@OpenFlash (09-17-2013)
Old 09-17-2013, 12:41 AM   #411
sierra
Drives: Skoda Yeti DSG diesel 4x4
That makes sense. The original is identical and the modified tune would only be visible by comparing the altered settings to stock. I wouldn't even bother going back to stock for a service but I would for certain warranty issues.
So unless there's a flash counter it's very stealthy.
sierra is offline   Reply With Quote
Old 09-17-2013, 06:10 AM   #412
Kodename47
Kodename47's Avatar
Drives: UK GT86
Guys, when you flash the car put it into accessory mode before starting it up and push the accelerator pedal 10 times fully to the floor. It will clear the dead pedal as you calibrate it there and then. This can be done any time when the car is running or in accessory mode but if you do it before you fire up the car it saves you some time.
@shiv@vishnu & @Rombinhood@OpenFlash it may be worth putting this in your instruction. I have done this many times and always works.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 5 Users Say Thank You to Kodename47 For This Useful Post:
akyp (09-17-2013), enwave (09-17-2013), mad_sb (09-17-2013), PoorMansRacing (11-25-2013), Rombinhood@OpenFlash (09-17-2013)
Old 09-17-2013, 06:57 AM   #413
qoncept
qoncept's Avatar
Alright, just got my ECU read and downloaded to my laptop.. A few concerns:
- Everything is running stupid slow. The laptop is a core i7 with 8gb of ram. When I click on the "Download data" tab it sits there reading for a good 5 minutes. When I click on "Upload data" it sits there doing whatever it's doing (what is it doing?) for 5 minutes. If I do these things along with Shiv's getting started video, the video finishes playing at each step while I wait.
- After downloading my stock map, the information window is pretty much empty. No ECU HW, ECU SW, CAL, VIN, etc.
- I went through the stage 1 maps and each failed the CRC check until ZA1JA01C. I'm assuming that's my calid but I'm not ready to flash it since I can't confirm.
qoncept is offline   Reply With Quote
Old 09-17-2013, 07:15 AM   #414
Pooverdam
Pooverdam's Avatar
Drives: Whiteout 6MT FRS
Your laptop is way faster than mine and I had no issue. My upload/download took about as long as the video. Could be a driver issue? Also, when you click upload and let it sit for a second it displays your cal ID. Shiv explains this in the video. There is a safety built in so you can't upload a flash with the wrong cal Id.
Try restarting your computer after you instal the programs.
Best of luck
Pooverdam is offline   Reply With Quote
The Following User Says Thank You to Pooverdam For This Useful Post:
qoncept (09-17-2013)
Old 09-17-2013, 08:15 AM   #415
qoncept
qoncept's Avatar
I just erased all the data on the tablet, went out and read the ECU again. Now it's showing me a calid and VIN. I think the tablet updated the first time I plugged it in to the computer. Whatever it was, it seems to be working correctly now.
The Following User Says Thank You to qoncept For This Useful Post:
Pooverdam (09-17-2013)
Old 09-17-2013, 08:29 AM   #416
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I guess you had also tried it with ECUtek? Also, does it need to be in ACC mode or can it also be in the ON position?
Old 09-17-2013, 08:38 AM   #417
Pooverdam
Pooverdam's Avatar
SAme thing happened to me now that you mention it!
Old 09-17-2013, 08:59 AM   #418
mad_sb
might be a good idea to install the OpenFlash Manager application on your computer and connect the tablet so it can check for updates before you plug it into the car for the first time to read your rom.
The Following 2 Users Say Thank You to mad_sb For This Useful Post:
qoncept (09-17-2013), Vmax911 (11-30-2013)
Old 09-17-2013, 09:01 AM   #419
bakerr6
Drives: 2013 raven black fr-s
hmm seems I cannot use winzip on my laptop. Anyone have any suggestions for other similar programs?
bakerr6 is offline   Reply With Quote
Old 09-17-2013, 09:08 AM   #420
mad_sb
7zip or winrar
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
