Old 09-16-2013, 11:20 PM   #393
Trigonx
Drives: WRB BRZ
Originally Posted by shiv@vishnu View Post
The Getting Started page is now live. Which means video tutorials, baseline maps and links to user software available. The only thing that is not posted up is the definition file (XDF) which will allow users to modify their maps. I'll post it up once I get confirmation that everything is working as it should. Don't want to unnecessarily complicate things right off the bat
So please confirm that you can successfully upload maps to your tablet and then flash them your ECU successfully by following the instructions If you have any suggestions with regards to the instructions, please let me know. If all is good, I can post up the definition files tomorrow so you guys can start playing around with the maps!
Cheers,
shiv
The link to download the maps is wrong on the website. Comes up to a 404 Error(page not found).
Trigonx is offline   Reply With Quote
Old 09-16-2013, 11:33 PM   #394
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Looks like the file names I used were too long so they weren't uploading to the server. Should be fixed now. Try again... sorry!
Shiv@Openflash is offline   Reply With Quote
Old 09-16-2013, 11:44 PM   #395
Pooverdam
Pooverdam's Avatar
Drives: Whiteout 6MT FRS
So i downloaded my map, uploaded the stage1 stock airbox map, and wrote it to the ECU. Started it up and let her idle for a bit per instructions. Definitely more peppy. Launch control is nice, although set a bit too high for my liking but you can adjust it. One thing that is very noticeable is the gas-peddle feel. There seems to be a bit of a dead spot for the first 1cm or so. I almost stalled because it was that different from stock. @shiv@vishnu is this normal?
Otherwise I am very pleased so far. I have a header back exhaust so I am waiting for their OTS stage 2 map. so far just the stage one maps are available for download.
Pooverdam is offline   Reply With Quote
Old 09-16-2013, 11:48 PM   #396
Semprini
Spline Reticulator
Semprini's Avatar
Drives: 2013 FR-S Whiteout
I just reset my ecu after an intake swap and have that same pedal feel so it's probably just the learning period. See how it feels with some miles on it.
Sent from my GT-I9505G using Tapatalk 4
Johnny was a chemist's son, but Johnny is no more.
What he thought was H2O was H2SO4.
Semprini is offline   Reply With Quote
Old 09-16-2013, 11:48 PM   #397
Rombinhood@OpenFlash
Drives: FRS
I think there is some throttle position adaptation that needs to occur after every reflash or ecu reset. Basically the ecu needs to recognize the TPS voltage that represents 0% throttle. Doesn't take too long for it to sort itself out though. All it needs to record is minimal TPS voltage during a drive cycle.
Rombinhood@OpenFlash is offline   Reply With Quote
The Following User Says Thank You to Rombinhood@OpenFlash For This Useful Post:
Pooverdam (09-16-2013)
Old 09-16-2013, 11:48 PM   #398
akyp
Drives: 2012 86
@Rombinhood@OpenFlash,
Is there a rough timeframe for support of non-US cars? (Mine is ZA1J700G)
Do the maps online include the fix which protects the DI seals?
Thanks in advance and look forward to purchasing it (once support for my car is confirmed).
akyp is offline   Reply With Quote
Old 09-16-2013, 11:49 PM   #399
Drives: FRS
Lol you beat me to it
Old 09-16-2013, 11:50 PM   #400
sierra
Drives: Skoda Yeti DSG diesel 4x4
That's how it feels when you re-set the ECU and it has to go through the learning process again. It could be the same and will go after a few days?
Throttle delay.
sierra is offline   Reply With Quote
The Following User Says Thank You to sierra For This Useful Post:
Old 09-16-2013, 11:51 PM   #401
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Excited to give this a shot when 6AT comes. Keep up the great work, and can't wait to hear the user feedback!
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 09-16-2013, 11:51 PM   #402
Semprini
Spline Reticulator
Semprini's Avatar
Oo do I win a tablet? ;-)
Old 09-16-2013, 11:52 PM   #403
enwave
enwave's Avatar
Throttle delay.
This, happens after every reflash. Give it two drive cycles and it will work itself out. If it isn't gone after about an hour or two of driving time, then you can start worrying about the map... Maybe
The Following 3 Users Say Thank You to enwave For This Useful Post:
mad_sb (09-17-2013), PoorMansRacing (11-25-2013), Pooverdam (09-16-2013)
Old 09-16-2013, 11:58 PM   #404
sierra
This all sounds very reassuring to use. You don't need a laptop and if you stuff it up loading the new map you can go back to the stock one. I have the start button on my GTS and assume I turn the ignition on by pressing it without my foot on the clutch?
Can we save the stock map to our computer in case the tablet craps itself, for a belt and braces type reassurance?
Old 09-17-2013, 12:01 AM   #405
Pooverdam
Pooverdam's Avatar
yes, that's step one of this whole process
The Following 2 Users Say Thank You to Pooverdam For This Useful Post:
Rombinhood@OpenFlash (09-17-2013), sierra (09-17-2013)
Old 09-17-2013, 12:16 AM   #406
sierra
There was lots of talk about Ecutek not being visible to dealer inspection but it wasn't convincing. Is this obvious to a dealer ECU check, either with the modified map or the original map replaced?
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 04:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 04:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 09:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
