#407 |
When will this be ready for autos?
ScionFrsFan
#408 |
Drives: FRS
#409 |
Drives: FRS
No Openflash tune, stock or otherwise, contains any license code. Nor do they restrict read/write functions. So it should be diagnostically invisible on all levels. Especially if you flash back in your original file which is stock, byte for byte.
#410 | |
Drives: 2013 Asphalt FR-S
~Namaste~ |
#411 | |
Drives: Skoda Yeti DSG diesel 4x4
So unless there's a flash counter it's very stealthy. |
#412 |
Drives: UK GT86
Guys, when you flash the car put it into accessory mode before starting it up and push the accelerator pedal 10 times fully to the floor. It will clear the dead pedal as you calibrate it there and then. This can be done any time when the car is running or in accessory mode but if you do it before you fire up the car it saves you some time.
@shiv@vishnu & @Rombinhood@OpenFlash it may be worth putting this in your instruction. I have done this many times and always works.
.: Stealth 86 :.
Abbey Motorsport/K47 Tuned Sprintex 210 Supercharger Kodename 47 DJ: Soundcloud / Instagram / Facebook Last edited by Kodename47; 09-17-2013 at 06:37 AM. |
#413 |
Alright, just got my ECU read and downloaded to my laptop.. A few concerns:
- Everything is running stupid slow. The laptop is a core i7 with 8gb of ram. When I click on the "Download data" tab it sits there reading for a good 5 minutes. When I click on "Upload data" it sits there doing whatever it's doing (what is it doing?) for 5 minutes. If I do these things along with Shiv's getting started video, the video finishes playing at each step while I wait. - After downloading my stock map, the information window is pretty much empty. No ECU HW, ECU SW, CAL, VIN, etc. - I went through the stage 1 maps and each failed the CRC check until ZA1JA01C. I'm assuming that's my calid but I'm not ready to flash it since I can't confirm.
#414 | |
Drives: Whiteout 6MT FRS
Try restarting your computer after you instal the programs. Best of luck |
#415 |
I just erased all the data on the tablet, went out and read the ECU again. Now it's showing me a calid and VIN. I think the tablet updated the first time I plugged it in to the computer. Whatever it was, it seems to be working correctly now.
#416 | |
I Love custom Turbo kits
Drives: Limited BRZ
#417 |
SAme thing happened to me now that you mention it!
#418 |
might be a good idea to install the OpenFlash Manager application on your computer and connect the tablet so it can check for updates before you plug it into the car for the first time to read your rom.
~Namaste~ |
#419 |
Drives: 2013 raven black fr-s
hmm seems I cannot use winzip on my laptop. Anyone have any suggestions for other similar programs?
#420 |
7zip or winrar
~Namaste~ |
| Tags |
| #lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
| Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 03:48 AM |
| Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 03:15 PM |
| Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 08:11 PM |
| 7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 11:53 AM |
