Old 09-17-2013, 12:26 AM   #57
TRD-X
TRD-X's Avatar
Drives: Da-Big Banana
Originally Posted by s0sl0w View Post
Which is why it has a Subaru derived flat four cylinder, and the suspension bits mirror other Subarus, and all the enginnering mule prototypes were subaru cars, and the engineering teams that designed the mechanicals were composed of (primarily) Subaru engineers.
I've said it before and I'll say it again. The only parts of this car that are Toyota are:
1) The styling
2) The transmission
3) The rear differential
4) The dual injection system
5) The general "spirit" of the car
It is a true joint effort car, without either company the car would be very different than it is and probably not as good (if all toyota) or non-existant entirely (if all subaru). But don't kid yourself, the lions share of the engineering that went into the car was/is Subaru derived, which is exactly what Toyota intended.
Yeah those Subaru parts are why I have those damn crickets..!!
You do understand I'm just out of something to do so I'm talking trash.
Oh here's those damn crickets.....
[ame="http://www.youtube.com/watch?v=K8E_zMLCRNg"]Cricket Sound - YouTube[/ame]
Old 09-17-2013, 12:28 AM   #58
ZionsWrath
Thanks
ZionsWrath's Avatar
Truth and truth. I'm glad that Toyota wanted the car because had they not I wouldn't have bought another Subaru.
Truthfully? I'd rather not drive a vehicle wearing brand engineering exercise badge, I don't care for the Scion manufactured brand image. I'm also no toyota man, in fact I tend to strongly dislike Toyota's. Combined with the fact that the scion didn't have the features I wanted (Bi-xenons and Keyless start) was more common, was a Scion, will likely be wrecked more and have higher insurance rates the decision was fairly easy.
Do I dislike the FR-S? Hell no, I do wish that it had been badged as Toyota here just as it is everywhere else and that Toyota would just give up on "youth marketing". But I'm very well awre that the BRZ and the FR-S are at their core the same car, however the BRZ is (IMO) the better version of said car.
But that's just, like, my opinion man.
In short I'd drive a Subaru before I'd drive a Toyota and I'd drive a Toyota before I'd drive a Scion. Because reasons.
Says he bought BRZ for bi-xenons
BRZ doesn't have bi-xenons
Got trolled in real life
That, or he just trolled me
Either way
Old 09-17-2013, 12:30 AM   #59
Luis_GT
Either way
It doesn't???? Wow that sucks... LMAO
Old 09-17-2013, 12:35 AM   #60
s0sl0w
Proud of Boxer
All good mate
It wouldn't be a subaru if it didn't have some stupid first year problem!
although we could make the case for the crickets being toyota's fault since the fuel injection system is Toyota sourced
Either way
Le sigh... do I have to educate all of you tonight?
http://www.bmw.com/com/en/insights/t...eadlights.html
http://ask.cars.com/2008/10/bi-xenon-hid.html
http://en.volkswagen.com/en/innovati...einwerfer.html
The BRZ most certainly does have Bi-Xenon headlights.
s0sl0w is offline   Reply With Quote
The Following User Says Thank You to s0sl0w For This Useful Post:
ZionsWrath (09-17-2013)
Old 09-17-2013, 12:39 AM   #61
ZionsWrath
Thanks
ZionsWrath's Avatar
Links everything but Subaru
Have someone sit in your car, turn on lights, then high beams. You will see the HID doesn't change, only the high beam light bulb comes on.
This link http://ask.cars.com/2008/10/bi-xenon-hid.html
On new cars, most xenon-equipped headlights are only offered as a low-beam headlight with a halogen bulb for the high beam. Bi-xenon headlights offer xenon-light output for the low and high beams, and they’re housed in the same headlight capsule/projector.
Yes it is semantics at this point but its funny because you are arguing (trolling?) so hard
Old 09-17-2013, 12:42 AM   #62
Luis_GT
and where is the high beam bulb located on the BRZ?
Old 09-17-2013, 12:50 AM   #63
s0sl0w
Proud of Boxer
You can't possibly be this stupid... can you?
I linked the other because they neatly and authoritatively defined what a Bi-Xenon lamp is.
The BRZ has one HID Xenon Capsule per side, inside that capsule there is a shutter that moves to dim or allow the single bulbs full output. That is what a Bi-Xenon lamp is. The BRZ has Bi-Xenon lamps. Please stop being willfully stupid.
The Following 3 Users Say Thank You to s0sl0w For This Useful Post:
Luis_GT (09-17-2013), onefitz (09-17-2013), ZionsWrath (09-17-2013)
Old 09-17-2013, 12:50 AM   #64
ric342
FR-S driver
ric342's Avatar
Drives: ULTRAMARINE Scion FR-S
I'm a mechanical engineer and I'm telling you he's wrong. But let's introduce some common sense into the equation.
Does it make sense that two cars that are produced in the same factory by one company and engineered by the same teams for both and are the same in every single design detail and almost every single styling detail would have the engine moved in any direction relative to the other car? Do you know how much work and engineering would have to be done to do that? It wouldn't exactly be easy.
Furthermore what about keyless start, dual zone climate controller and bi-xenon headlamps make you think that those options would require fundamental design changes? This is not as simple as some guy steered you wrong, this goes to a level that displays a complete lack of critical thinking ability and simple rational thought. I actually feel kind of bad for you because your life cannot be easy if you're truly that simple, illogical, and gullible.
when he told me about the engine being forward, thoughts running through my mind were, the Subaru has a stiffer suspension then the scion.So a engine moved forward could facilitate the comment and help the 50/50 balance witch for the scion I believe is a 53/47. They both run on McPherson struts and they both have double wishbone suspension, so the thought of the engine being pushed forward is far from impossible, and when he told me moved forward it would have been no more than a mm. Im not gullible just trust too much and if he is wrong which all of you are saying then fine. Still I must get to the bottom of this because like I said he hasn't steered me wrong.:happy0180:
ric342 is offline   Reply With Quote
Old 09-17-2013, 12:51 AM   #65
ZionsWrath
Thanks
ZionsWrath's Avatar
I am stupid ahahah
please forgive my intoxication
The Following 3 Users Say Thank You to ZionsWrath For This Useful Post:
Luis_GT (09-17-2013), ric342 (09-17-2013), s0sl0w (09-17-2013)
Old 09-17-2013, 12:54 AM   #66
Luis_GT
I love my Bi-Xenon headlights!
The Following User Says Thank You to Luis_GT For This Useful Post:
Old 09-17-2013, 12:56 AM   #67
s0sl0w
Proud of Boxer
Maybe pictures will help...
Old 09-17-2013, 12:56 AM   #68
ZionsWrath
Thanks
ZionsWrath's Avatar
Going to 7-11 for more beer so I can forget this thread :P
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
onefitz (09-17-2013), s0sl0w (09-17-2013)
Old 09-17-2013, 12:58 AM   #69
s0sl0w
Proud of Boxer
There is no "bottom to get to" The engines are positioned exactly the same, period.
Old 09-17-2013, 01:03 AM   #70
Originally Posted by DMDominator View Post
Had a "know-it-all" type hit me with a 23 grand comment once. Told him I wish it had been that cheap, lol.
Well now, this thread sure did get spicy .....
OP, most people that have commented on my FR-S, think it costs more than it did .... I consider that a good thing ..
DMDominator (09-17-2013)
"idiot", look son an idiot, soslow somad
Safe amount of boost on stock engine? Octane Forced Induction 51 12-06-2017 07:25 PM
Safe/reliable amount of Hp range for BRZ Howardwei Forced Induction 74 07-29-2013 03:50 AM
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-13-2013 11:46 PM
What socket size and what torque amount for stock alloy wheels? Takeshi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-01-2012 10:25 PM
Now I am getting paid to do it! Tanuki Off-Topic Lounge [WARNING: NO POLITICS] 2 05-21-2010 03:30 AM
