Old 08-31-2013, 06:27 PM   #477
asnoir
Drives: An old Citroen Xantia TD
Hello ! In Hot Version vol 121 Amuse says and we can see that they have got the seal issue.
asnoir is offline   Reply With Quote
The Following 3 Users Say Thank You to asnoir For This Useful Post:
Carwhisperer (08-31-2013), dabocx (08-31-2013), yuicebox (08-31-2013)
Old 09-06-2013, 07:13 PM   #478
BaeK
BaeK's Avatar
Drives: 2013 Whiteout FRS
After an hour or two of researching on the new "ZA1JA01C" code, I decided to go to my dealership to check the ECU calibration version on my FRS. Until today, I was worried about pushing my car above 5.2k RPM, but now I can push my car without any worries down the road (knock on wood).
Here's a picture of a printout that my dealership gave me:
As you can see, my FRS has the newest ECU calibration version installed. My service advisor was a very nice guy and the whole process took no longer than 10 minutes.
additional info:
Country: USA
Mfg date: April, 2013
If you are worried about your current ECU calibration version, I'd say go to your dealership and have them show/print out a copy of the ECU calibration version installed on your car. This way, you won't have to worry about it while driving your FRS "spiritedly".
Hope this helps a few of you out there.
Cheers.
BaeK is offline   Reply With Quote
The Following 6 Users Say Thank You to BaeK For This Useful Post:
chanomatik (09-18-2013), Demandred7 (09-16-2013), jjaisli (09-07-2013), Marrk (09-07-2013), sprintertrueno86 (09-06-2013), thill (09-06-2013)
Old 09-16-2013, 12:34 AM   #479
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by CamryDS View Post
how do you verify the flash? because I would like to know if I can pull this information out myself
If you buy a ELM327 OBDII to bluetooth adapter on ebay for $10 and download the torque app for droid, you can read it out.
I did it today and my Cal ID is:ZA1J700C
I also emailed my Subaru dealer maintenance manager today to ask about the latest ECU upgrade and I referred to the Toyota TSB shown a few pages back.
However they probably wont respond tomorrow since I think they are underwater (Longmont, CO) ...
I asked the same guy if adding aftermarket parts was an issue.
Here is the exact text of his answer:
"As far as aftermarket upgrades are concerned, any modification will void the warranty for that particular system. If something fails and can be contributed to the specific upgrade/modification will be voided. It does not blanket void the warranty on the entire vehicle. "
The Following 3 Users Say Thank You to stugray For This Useful Post:
CamryDS (09-16-2013), Marrk (09-16-2013), yuicebox (09-16-2013)
Old 09-16-2013, 12:56 AM   #480
yuicebox
Drives: Asphalt FRS
Thanks Stugray, just ordered my ELM327.
yuicebox is offline   Reply With Quote
Old 09-16-2013, 11:13 AM   #481
Blue86
Drives: Sonic Blue 86GT Manual
My Australian 86 is ZA1J700G whatever the G means?
Blue86 is offline   Reply With Quote
Old 09-16-2013, 11:35 AM   #482
thill
G is the region code.
Old 09-16-2013, 11:42 AM   #483
Wepeel
Drives: '13 BRZ Ltd
How did you do this? I've got the adapter and Torque but can't figure out how to pull the CalID without having a DTC/Freeze Frame Data.
Wepeel is offline   Reply With Quote
Old 09-16-2013, 12:26 PM   #484
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
additional info:
Country: USA
Cheers.
Thanks for the post, although I would have somewhat expected a newer car to have the most recent update. I might expect mine to be out of date since I bought it August 2012. I think that I might request mine at my next service. Even more likely is that my VIN falls within the suspect range.
Demandred7 is offline   Reply With Quote
Old 09-16-2013, 01:32 PM   #485
stugray
It is in the "Adapter Status" tab in "Calibration ID"
Old 09-16-2013, 01:57 PM   #486
Wepeel
Drives: '13 BRZ Ltd
Thanks! Well that was easy. I just checked... 01C for me
Old 09-16-2013, 02:13 PM   #487
yuicebox
Drives: Asphalt FRS
If you check and post your calibration please post your build date too!
Sent from my SAMSUNG-SGH-I317 using Tapatalk 4
The Following User Says Thank You to yuicebox For This Useful Post:
strat61caster (09-16-2013)
Old 09-16-2013, 02:16 PM   #488
Wepeel
Drives: '13 BRZ Ltd
May 2013 BRZ
The Following User Says Thank You to Wepeel For This Useful Post:
bestwheelbase (09-16-2013)
Old 09-16-2013, 02:19 PM   #489
yuicebox
Drives: Asphalt FRS
April and May seem to be in the clear. I'm march 2013, so I'll keep you guys posted once I know
Old 09-16-2013, 04:37 PM   #490
EINSTEIN562
EINSTEIN562's Avatar
Drives: 2017 Subaru BRZ
Just checked mine using the Torque app....01C
Jan 2013 build date
Ice Silver 2017 BRZ w/PP 6MT | Driver Mod |
EINSTEIN562 is offline   Reply With Quote
The Following 4 Users Say Thank You to EINSTEIN562 For This Useful Post:
BRZ21 (09-17-2013), strat61caster (09-16-2013), suaveflooder (09-16-2013), yuicebox (09-18-2013)
regalsurinalpost
Raven down! Mechanical failure :( rasec29 Issues | Warranty | Recalls / TSB 151 10-08-2013 11:25 AM
86 rentals - 2013 era bcj AUSTRALIA 11 04-23-2013 10:27 PM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
BC Coilover failure in the past phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-25-2012 05:07 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
