Old 09-16-2013, 05:02 AM   #1
PantsDants
Drives: Scion FR-S A/T, Whiteout
Wire FR-S turn signals (LED switchbacks) as DRL?
I've got LED switchbacks for my turn signals, and I was wondering if anyone knew of a way to get them to light up white as DRLs, not just when the headlights are on. Ideally this would disable the DRL functionality on the high beams as well. I know you can modify the ECU via techstream to disable DRLs completely, but that's not what I'm going for here; I just want different lights to come on.
PantsDants is offline   Reply With Quote
Old 09-16-2013, 06:00 AM   #2
vincent201089
vincent201089's Avatar
Drives: frs
The stalk has 3 settings, 1st is all light off except DRL, 2nd is side markers, license plate, and will also turn your turn signal on too, 2rd is headlight.
Don't rewire it, just turn it to the 2nd settings.
vincent201089 is offline   Reply With Quote
Old 09-16-2013, 07:01 AM   #3
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Is there a way to make the lights in the second and third setting use the brightest filament all the time? Such as the turn going dimmer when its changing lanes instead of brighter or something?
Old 09-16-2013, 10:00 AM   #4
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
...but then your brake lights go on and your interior displays dim.
Old 09-16-2013, 01:41 PM   #5
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
this is exactly what I do when i just want my turn signal turn on and keep the DRLs.
Old 09-16-2013, 08:45 PM   #6
vincent201089
Drives: frs
I'm using flash back turn signal fom Hid-powerhouse but never seen them lighter or brighter during flashing. if you decide to go with flash back, good choice. the white led acts like foglight and really bright at night. I dont want my to be dimmer during flashing and back to normal again.
yeah. I used to to this but I dont mind the break light is on and during daytime. interior light is ok to me. I dont even notice it.
Old 09-16-2013, 09:30 PM   #7
boredom.is.me
Custom User Title
I personally don't care if my brake lights are on, but the idiot behind that is texting may not realize when they go bright.
Old 08-11-2014, 05:35 PM   #8
afoust50
afoust50's Avatar
Drives: 2014 Scion FR-S
Old thread REVIVAL!!! Anybody figure this out? I want to do the same.... What about just connecting the stock positive wire for the DRL to the green wire connected the the turn signal/parking lights? Any reason this won't work?
afoust50 is offline   Reply With Quote
FS: LED Amber Turn Signals NorCal_Guy Exterior Parts (Aero, Lighting, Etc.) 11 02-24-2014 04:33 AM
FS: LED Turn Signals Dual Color Switchbacks *SOLD! NorCal_Guy Exterior Parts (Aero, Lighting, Etc.) 7 09-12-2013 01:44 PM
Does 6k HID's Go well With the Turn Signal Switchbacks J-Money Cosmetic Modification (Interior/Exterior/Lighting) 17 01-29-2013 10:41 PM
FS: Wire taps + resistors (for LED turn signals) Laika Exterior Parts (Aero, Lighting, Etc.) 0 01-13-2013 09:50 AM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
