Old 09-13-2013, 08:00 AM   #309
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by Adeets View Post
I don't think over spinning is the proper term, over pressurizing would be better.
Yeah I wasn't sure - I was tempted to use "overboost" but went with "overspin".
Old 09-13-2013, 09:40 AM   #310
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Originally Posted by regal View Post
Do you find your Vortech "lacking" in mid-range torque needing the wastegating? The complaint with centr. chargers has always been that for the money you don't gain much in a bigger powerband, mainly just up top (in comparison to a pos disp or turbo.)
The wg allows for smaller pulley yes, that equals lots more oomph at mid power band, why else do you think I'm playing with it?
448hpsti is offline   Reply With Quote
Old 09-13-2013, 10:10 AM   #311
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
By that I mean wastegating at 9psi which means it can run 93, 5.4psi at 2500, 9 psi around 4200rpm
When can I see a 3rd gear boost plot that shows 5.4 psi at 2500 RPM?
Old 09-13-2013, 11:41 AM   #312
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Math, 16psi @7400.... (16/7400)2500 = 5.4 (full boost/max rpm)desired rpm = psi@desired rpm if psi>wastegate psi then psi@desired rpm = wastegate psi.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 09-13-2013, 11:43 AM   #313
whataboutbob
AutoX-10/10ths every run
I think most people who think of the innovate sound heard it thru @robispec and his videos, but with the ton of light weighting he's done I don't think the growl would be nearly as loud in a normal car.
Here you go. With an Invidia N1 and Invidia high flow catted front pipe too. All of the car's interior parts are still in place/OEM.
[ame]http://youtu.be/dSDWsX22daE[/ame]
Build thread:Here
Old 09-13-2013, 01:13 PM   #314
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Nice maths. I would still like to see a boost curve plot please.
Old 09-13-2013, 01:26 PM   #315
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
It's hard to do it like that because with the stock pulley I see 1psi around like 3k. Boost doesn't start from 0
Sent from my Nexus 4 using Tapatalk 4
Nolan
pheoxs is offline   Reply With Quote
Old 09-13-2013, 01:41 PM   #316
fenton
Only thing that makes that boost down low is the Electric supercharger. Doesn't make nearly as much up top though, for obvious reasons.
Bob at drift office tuned one with full boost starting at 1800rpm
Does anyone know if running a larger pulley on vortech increase parasitic power loss across the rev band? Like does it actually take more HP to turn the supercharger, or is it just the step to installing the actual charger that introduces the loss?
Anyways boost down that low is fun but you don't really use it that much.
My current setup makes 180tq at 2000 rpm with 4.5psi.
fenton is offline   Reply With Quote
Old 09-13-2013, 04:19 PM   #317
Adeets
OEDC
Adeets's Avatar
Every boost graph I've seen of any centri is pretty much a completely flat line, from 0 to its red line, it's not a turbo or PD it's not gonna have a dynamic shift in pressure. 0 is 0, red line is max psi, everything in-between is a not a straight line, but is an ever so slight concave to it....
So 3psi at 2.5k
My BRZ FI Build
Old 09-13-2013, 04:49 PM   #318
fenton
Its not really a straight line there are loses at the low end that aren't made up until the top end.
This is mostly due to the impeller design if I'm not mistaken ... I am not a expert though
Sent from my HTC One using Tapatalk 4
Old 09-13-2013, 04:54 PM   #319
Adeets
OEDC
Adeets's Avatar
Already note in the post, read the last 2 sentances.
My BRZ FI Build
Old 09-13-2013, 05:46 PM   #320
Robftss
Drives: VW
7400/2500= 2.96:1 ~1/3
So its the 3rd root of 16psi = 2.52 psi @ 2500 rpm.
Pressure is square of impeller rpm. (ideal).
Robftss is offline   Reply With Quote
Old 09-13-2013, 09:05 PM   #321
Adeets
OEDC
Adeets's Avatar
Though your conculsion seems correct wouldn't that mean the blower has an exponential gain? Kinda like would u rather have a million dollars up front or a penny a day and double the sum everyday for 2 months?
My BRZ FI Build
Old 09-13-2013, 09:08 PM   #322
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
spot on sounding to me
N/A power output potential as race setup? rice_classic Engine, Exhaust, Transmission 67 12-17-2013 07:03 PM
Abbey Motorpsort GT86 Sprintex installation Mark@Abbey m/s Forced Induction 18 09-07-2013 04:11 AM
WA Next meet Sun 30th June - Sprintex Test Drive AND A One Audio display plus special invisage Australian Meets & Events 2 07-22-2013 03:20 AM
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 06:11 AM
