Old 09-06-2013, 10:58 AM   #1
B_Rad
B_Rad's Avatar
Drives: 2013 Scion FR-S/Raven Black/6 sp mt
IG2 Relay issue
So like an idiot I pulled out my IG2 Relay with the battery still connected. Now the car has no power. I have horn, lights, radio, windows etc. Everything except gauges and check lights. If I turn the key to start I get nothing. What do I need to do to fix this???
B_Rad is offline   Reply With Quote
Old 09-06-2013, 11:00 AM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
I assume you checked the fuse?
Old 09-06-2013, 11:07 AM   #3
B_Rad
B_Rad's Avatar
yes all the fuses are good.
Old 09-06-2013, 11:29 AM   #4
infinite012
Drives: 13 DGM BRZ Ltd
Put the relay back in.
infinite012 is offline   Reply With Quote
The Following User Says Thank You to infinite012 For This Useful Post:
B_Rad (09-06-2013)
Old 09-06-2013, 11:48 AM   #5
B_Rad
B_Rad's Avatar
^really the relay is back in. Everything is back in the factory position, no fuses blown. getting ready to test the relays to see if they are working properly.
Old 09-06-2013, 11:49 AM   #6
infinite012
I have nothing. Good luck.
B_Rad (09-06-2013)
Old 09-06-2013, 12:24 PM   #7
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Wondering if that would trip some security routines. My suggestion is to disconnect the battery for a few minutes and re-try.
Edit: Security light would be flashing if so... from your description you have no dash lights. Try battery but I'd recheck all fuses and fusible links.
FRSFirestorm is offline   Reply With Quote
Old 09-06-2013, 12:39 PM   #8
B_Rad
B_Rad's Avatar
the Security light does the normal flash. I've had the battery disconnected to reset everything and still nothing. If i plug in an OBDII code ready it cannot connect to the CPU so there is no power getting to the ECU. I did a quick check of all the relay's and they all seem to be working. About ready to have it taken to the dealership.
Old 09-07-2013, 01:11 AM   #9
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
did you check main fuse?
Old 09-07-2013, 12:35 PM   #10
B_Rad
B_Rad's Avatar
Is it located in the main fuse box under the hood? If so then yes. The car is currently at the dealership for diagnostics.
Old 09-08-2013, 11:10 AM   #11
zc06_kisstherain
Drives: SWP BRZ
Thats weird. Gl w/ fix and jeep us updated
Sent from my Galaxy Nexus using Tapatalk 2
Old 09-11-2013, 08:26 AM   #12
B_Rad
B_Rad's Avatar
Got the car back from the Dealer yesterday after work. Nothing major was harmed. Ended up the Gap on the Relay clip for the #3 terminal was opened to far. It was causing lower voltage to trickle to everything down stream.
DRL/dome light relay (15 pin plug) Zardoman Cosmetic Modification (Interior/Exterior/Lighting) 1 11-05-2013 05:24 AM
BeSpoke Backup Camera on Relay l0aded Electronics | Audio | NAV | Infotainment 33 08-07-2013 07:20 PM
WTB: OEM Flasher Relay CanibeatNoel Audio/Visual, Electronics, Infotainment, NAV 2 05-01-2013 03:58 PM
WTB: OEM Flasher Relay CanibeatNoel Interior Parts (Incl. Lighting) 1 03-23-2013 02:19 AM
HID Relay needed? corvino26 Cosmetic Modification (Interior/Exterior/Lighting) 12 01-04-2013 10:16 PM
