Drives: 2013 Scion FR-S 6MT Raven
HID Relay needed?
I purchased an HID kit less then a month ago. Product has a 2 year warranty on it. Apparently burned a ballast. I am interested to know if I need an HID relay. Any thoughts or advice would be greatly appreciated. Thanks in advance!
A.Corvino
http://www.streetmasters.com/ |
or even a canbus or harness... not really too sure amongst the difference but still need a solution to prevent further damage or faulting
A.Corvino
P i N O Y P R i D E
Drives: 86 C7P MT
i dont think u need a relay on HID. probably low quality ballast? thats the 1st time i heard burning of ballast. somebody told me that if u plug the HID on correct polarity since toyota cars needs to be reverse polarity, u would blow up ur lighting fuse.
Kouki-Monster
you buy a shitty DDMtuning kit or what?
Rich Anderson
EMPOWER AUTO |
Drives: Whiteout FR-S
Someone else on the forums got a faulty ballast from a vendor and just got it replaced (under warranty from the seller). I'm thinking you're having the same problem. What happens when you try to turn on the headlights? Does one side flicker and then just not turn on?
#6 | |
A.Corvino
it worked just fine for 3 weeks then just suddenly stopped working today
A.Corvino
AutoX-10/10ths every run
No need for a relay on the HIDs I bought from @KI_ZN6 a.k.a. HID_Powerhouse.
#10 |
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Haven't heard of Autovision, is it the digital slim ballasts? It just sounds like a bad ballast to me, it happens even with the more expensive German kits. Get a replacement and you should be fine. If you're really worried about the relays, you can get a complete new kit from one of the vendors here on the forums - they're all high quality kits with no need for a relay, plus a lot of us have already bought and tried the vendor kits so you know they'll work w/o relay.
#11 |
#12 |
Our HID kits do not require running any relay harnesses. Relay harnesses are commonly used for vehicles that utilize high/low beam headlight setups or if there are wire modifications to the headlights.
#13 |
If you have warrnty issues and have to buy new go with Ken from hidpowerhouse.
Should have no drama.
| Blinker/Hazard Relay Location | EmilGH | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 09-10-2015 01:20 PM |
| LED lighting upgrade and Flasher Relay. | jadewbj | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 07-22-2013 08:44 PM |
| Relay Sound Coming From Passenger Side | jjkerr626 | Issues | Warranty | Recalls / TSB | 0 | 10-06-2012 10:29 AM |
| Delete | driver01 | Canada Classifieds | 0 | 09-21-2012 02:52 PM |
| Internet Relay Chat (IRC) Channel | Sony | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 11-03-2011 10:36 PM |
