Old 08-21-2013, 01:50 PM   #309
xxscaxx
Drives: 2013 SWP BRZ
Forgot I had this pic from the allthingsproper photoshoot i did.
xxscaxx is offline   Reply With Quote
The Following 4 Users Say Thank You to xxscaxx For This Useful Post:
chanomatik (09-10-2013), ShoNUFF (08-21-2013), Staticz (03-27-2014), Wes (08-21-2013)
Old 08-23-2013, 04:23 PM   #310
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
dont use glass cleaner on lexan or any other plastics. if it has ammonia in it. it will cause tiny little cracks every where
Originally Posted by Prooks View Post
Update:
I used 2000 grit wetsand, glass cleaner (windex), then sprayed 2 coats of red with 15-20 minutes in bewteen. Then cleaned the new red coats and applied 2 clear coats with the Krylon Fusion clear coat for plastics. I also masked off the signal lights with masking tape.
I'm very happy with the results! I still like the valenti leds but this will do until I can afford those (unless someone wants to buy these of me)
Here's a quick cell phone shot:
Bones36 is offline   Reply With Quote
Old 08-25-2013, 01:08 PM   #311
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
duplicolor metalcast and rustoleum crystal clear
GT86drifter is offline   Reply With Quote
Old 09-09-2013, 02:08 PM   #312
xxscaxx
Just wanted to add another photo of my setup. Metalcast red /spramax 2k Urethane Clear coat.
Clean Culture OC Meet by xxscaxx, on Flickr
chanomatik (09-10-2013), Jive Turkey (09-10-2013), MaXimus (04-06-2014), Wes (09-09-2013)
Old 09-09-2013, 07:22 PM   #313
smbstyle
smbstyle's Avatar
Has anyone tried buffing after wetsanding before the clear goes on? The wetsanding will still dull out the finish a bit, and I figured it would look better if you do a machine polish step after wetsanding before the clear goes on, then wetsanding/buffing the clear.
Also, how long are you all typically waiting between coats? I'm thinking 2 hours should be good.
smbstyle is offline   Reply With Quote
Old 09-09-2013, 07:51 PM   #314
smbstyle
smbstyle's Avatar
looks awesome. did you wetsand between red paint and the clear?
Old 09-10-2013, 01:09 PM   #315
xxscaxx
I wetsanded between the red if I needed it, but i think i only did on the second to last coat. Then applied my final coat of red, then applied the clear. Did not wetsand the clear, only two small spots that I accidentally ran the clear.
Old 09-10-2013, 01:41 PM   #316
ihaskrayon
The Comedian
Drives: SWP BRZ Limited
That looks great! So clear and very OEM
ihaskrayon is offline   Reply With Quote
Old 09-10-2013, 02:04 PM   #317
smbstyle
smbstyle's Avatar
Great, thanks! How many coats of clear did you use? Looks freaking gorgeous. Could never tell it wasn't OEM
Old 09-10-2013, 02:09 PM   #318
xxscaxx
Thanks man! Everyone who sees them in person thinks they are oem, and don't believe me that I painted them lol.
I used like 3-4. The Spraymax only offers 24 hours of usage after opening, so I applied a crapload because it was going to go to waste haha.
Old 09-10-2013, 04:07 PM   #319
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
How's the success rate on wrapping these? I'm going to get it done professionally but even so that fin thing looks truly difficult to get perfect.
Old 09-10-2013, 04:09 PM   #320
qoncept
qoncept's Avatar
I tried it and it didn't work out. But I've never wrapped anything in vinyl before and I'm not really good at detail work anyway, but I did manage to do a pretty decent job on my dash trim. The fin part wasn't really a problem.
qoncept is offline   Reply With Quote
Old 09-11-2013, 06:50 PM   #321
smbstyle
smbstyle's Avatar
Here's what I used:
Duplicolor Metalcast (2 cans used)
4 medium coats (45-1 hr in between)
light wetsand (2000 grit)
1 medium/light coat
Do not be alarmed when your lights look like this after the red coats...
Rustoleum 2x Clear (2 cans used)
light wetsand 2000 grit and polish/buff
1 medium coat
light wetsand (2000 grit) and machine polish w/ abrasive polish
After the final coat of Clear:
I'm pretty happy with the final result - still a little bit of orange peel in the paint/clear which you really can't see unless you look at the lens surface from the side, and may end up doing a few more coats of clear at a later time, followed by some more and heavier wetsanding, but overall I think they look good, but most importantly, better than stock.
reflection in the tail lights are just clouds:
Old 09-11-2013, 08:07 PM   #322
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
I'm tempted to mail mine to you and pay you to make them look like yours. hahaha But, I do like doing SOME projects myself, so I think I might tackle this myself. Maybe try to run to the store this weekend to pick up the supplies you listed. Thanks for this pic!
The Following User Says Thank You to chanomatik For This Useful Post:
xxscaxx (09-13-2013)
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 10:02 AM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 02:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 03:30 PM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 07:20 PM
