Old 09-08-2013, 06:02 PM   #29
mrk1
Drives: Sterling BRZ Ltd
The term back pressure seems to be the forum talk for the concepts like exhaust velocity and scavaging effects. It's a complex concept that some how got shorted to one term.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 09-08-2013, 06:06 PM   #30
mrk1
Originally Posted by BlueDubbinTDI View Post
I'll ask again. Does a resonator increase back pressure or not? I'm not that familiar with them but arent they basically a straight pipe?
Yes a straight through bottle style resonator that uses some type of absorbent material will only have minimal added turbulence inside which won't do much of anything for added "back pressure" or to hinder overall flow
The Build Thread
Old 09-08-2013, 07:04 PM   #31
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Does a resonator quiet down the entire rpm band like a muffler or what? How are they different?
Old 09-08-2013, 07:20 PM   #32
mrk1
A resonator will change the tone of the exhaust more so then the overall volume. Added a resonator will mellow out the sound and depending on the size and placement the tone can be adjusted. Often taking out the rasp and higher pitch sounds can make the exhaust seem quieter as it is less abrasive to the ear.
The Build Thread
Old 09-08-2013, 07:24 PM   #33
BlueDubbinTDI
I really like my Berks sound everywhere except 2200rpm, and in my Auto that's basically where the needle goes every time I touch the gas. I was going to do something to quiet the exhaust a little but really that louder and more irritating spot is what ide like to kill. So recommend a resonator or muffler?
Old 09-08-2013, 07:41 PM   #34
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Yeah, but when people reference back pressure they never actually mean exhaust velocity or ever talk about scavenging effects though.
Old 09-09-2013, 08:54 AM   #35
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
This is true and I'm not trying to take this discussion there... In theory, the muffler delete makes sense. Unfortunately the actual results haven't been good at all.
FA20Club built a full 3" exhaust for their track car knowing that they were going to install a turbo soon. They strapped the car to the dyno only to see that it lost power. The rest of the car was still stock other than a drop in filter. The full 3" is optimal for turbo setups but the car didn't respond well to it NA.
chadstyle is offline   Reply With Quote
Old 09-09-2013, 09:14 AM   #36
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
This was a custom made from my local shop TM-SPL in NY from a berk muffler delete welded on a yashio factory custom tip
GT86drifter is offline   Reply With Quote
Old 09-09-2013, 09:22 AM   #37
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
I like it. What wheels are those?
smbstyle is offline   Reply With Quote
Old 09-09-2013, 09:29 AM   #38
SpeedLab
Drives: White
Where can i get that turn-down. I've been looking for an adequate one for a long while.
Because it didn't break does not mean it's track proven.
SpeedLab is offline   Reply With Quote
Old 09-09-2013, 10:14 AM   #39
Wepeel
Drives: '13 BRZ Ltd
chadstyle, based on what you've seen do any exhaust mods post-cat make any gains (stock ECU)? Any catback, muffler...?
Wepeel is offline   Reply With Quote
Old 09-09-2013, 10:58 AM   #40
stefmiesterb
stefmiesterb's Avatar
Drives: B8 A5
It lost power because the diameter of the entire exhaust was increased, hence increasing the cross sectional area the air flows and decreasing exhaust velocity. An otherwise stock car with a berk/works or muffler delete would not lose as much power as this set up, or any at all.
stefmiesterb is offline   Reply With Quote
Old 09-09-2013, 01:19 PM   #41
SpeedLab
Drives: White
When will people stop with this back pressure nonsense?
People will stop once we start putting supertrapps on these cars MUAHAHA.
The Following User Says Thank You to SpeedLab For This Useful Post:
Andrew025 (09-09-2013)
Old 09-09-2013, 03:58 PM   #42
mrk1
I love turn down tips, they need to make a come back
The Build Thread
how to make FR-S front turn signals stay off when not in use Pavel Cosmetic Modification (Interior/Exterior/Lighting) 15 10-07-2013 06:29 PM
WTB Berk Dual Exit Muffler Delete or Works AB Delete Admired Want-To-Buy Requests 2 09-10-2013 04:20 PM
Muffler Delete sound without deleting muffler sw20kosh Engine, Exhaust, Transmission 10 01-30-2013 05:09 PM
Muffler delete zooplane Engine, Exhaust, Transmission 11 12-16-2012 07:00 PM
