Old 09-06-2013, 10:44 AM   #99
peteralfonso
Drives: Scion FRS
Originally Posted by NYCsubaruBRZ View Post
prices on a light weight flywheel?
what did you pay for yours shipped to your door?
brand?
model?
thanks 4 the help
http://www.revworksinc.com/ACT-HD-Cl...-S-_p_592.html
peteralfonso is offline   Reply With Quote
The Following User Says Thank You to peteralfonso For This Useful Post:
NYCsubaruBRZ (09-06-2013)
Old 09-06-2013, 05:32 PM   #100
CyberCT
Drives: RSX
I'm sitting here at work calculating all the steps and cost I'll be taking for an FRS to reduce drivetrain weight.
My RSX, which will be my winter beater after I buy an FRS, has a 8lb flywheel and RPF1s and Continental Extremecontact DW tires. In otherwords, LIGHTWEIGHT drivetrain. 34lbs per corner. I also have a 5.1 FD in my trans and a quife LSD. Anyhow, I absolutely love the way the car drives with the reduced weight and shorter gears. I just hit the gas and the car takes off without any hesitation. It also slows down fairly quickly, which I like for taking turn after turn in mountain roads. It's an absolute blast to drive.
So for the FRS going with the new RPF1s in 17 x 7 +42 and same tires above, I will be at 34lbs per corner (stock 40.6). Then I'm going to get the Aluminum driveshaft for an added 12 lbs off the drivetrain. So this will reduce drivetrain weight by 37.6lbs BEFORE going with a lightweighth flywheel. I will in the future, but probably just do the mods above first so I don't need to drop the engine or trans.
And getting used to a lightweight flywheel isn't hard at all, and will feel "normal" after a few days. Gonna sell my RSX aftermarket parts and go stock to hopefully cover the cost.
CyberCT is offline   Reply With Quote
Old 09-06-2013, 08:26 PM   #101
mike the snake
When you refer to gearbox rattle, where/when are you hearing this?
I had a Porsche race car with a Tilton multi-disk clutch, and when I jacked the car up and put it in gear while running it sounded like it was throwing a rod out of the engine, the clutch rattled so bad.
I assume with the light flywheel, it's not spinning in a fluid, smooth motion, more like speeding up, and slowing down per each stroke, so the gearbox could clatter at idle, but do the gearboxes rattle or clatter at high rpm's?
Old 09-06-2013, 09:00 PM   #102
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I only hear the rattle at idle with the clutch in and the ac on. Which is to say, everytime a cute girl is handing me an ice coffee at the drive through.
Don't really care or notice any other time.
industrial is offline   Reply With Quote
Old 09-07-2013, 10:37 PM   #103
frsdiy
Drives: frs-2013 raven
no issues here....
i just have the light weight water pump pulley and alt pulley...
crank pulley isnt on yet i had trouble gettin it to break loose.... any advice on how to get it off?
I did it by using at least a 24 inch breaker bar and starting as far right as possible. You will feel a squishy 90 degree rotation before it breaks loose. That's why I had to start as far right as possible. This was with a manual in 6 gear and parking brake on. With a automatic you will need some tool to lock the crank pulley in place.
I thought this youtube video (below) was a brilliant way to keep the crank from rotating until I read one of the posts who ruined their alternator using the method. You have been warned! This method will cause alternator damage.
[ame="http://www.youtube.com/watch?v=teaB2JAfVi0"]http://www.youtube.com/watch?v=teaB2JAfVi0[/ame]
frsdiy is offline   Reply With Quote
The Following User Says Thank You to frsdiy For This Useful Post:
cfusionpm (09-08-2013)
Old 09-07-2013, 11:06 PM   #104
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We run, Lightweight Pulleys ( almost all of them ) , Lightweight flywheel, Carbon Drive Shaft, and have zero CEL's or issues. Plus lightweight wheels and lightweight brakes compared to stock.
There should be NO problems with any lightweight item in the rotating mass of the car if it has been balanced which 9.999999 times out of 10 they are.
Plus a Vortech supercharger...
FT-86 SpeedFactory is offline   Reply With Quote
Old 09-07-2013, 11:28 PM   #105
wootwoot
Drives: FRS
Are you saying you are running a light weight flywheel that is NOT making any additional gear noise or chatter?
Old 09-08-2013, 06:25 AM   #106
Turdinator
Señor Member
Turdinator's Avatar
A multi-disk clutch setup will rattle way more than any single plate and flywheel combination.
I haven't installed my light flywheel on my 86 yet so I can't be 100% sure but every other car I've driven with a light flywheel hasn't made any extra noise above idle.
1974 TA22 Celica
2013 86 GT
Old 09-08-2013, 01:26 PM   #107
FT-86 SpeedFactory
We run the act kit and I didn't notice anything.
Old 09-08-2013, 02:36 PM   #108
wootwoot
Drives: FRS
Really?! I think you are the first person I have talked to that says this. Everyone else describes the ACT being very noisy...
Old 09-09-2013, 03:05 PM   #109
37
degrees
37's Avatar
Drives: 6MT BRZ
My ACT is quiet. It's the trans that makes a bit of noise as a result.
Either way, I wouldn't call the trans rattle "very noisy" and my exhaust is still stock. I DD my car and have no issues with the noises it makes. I'm not a kid, either, for whatever that's worth.
@FT-86 SpeedFactory might not notice any additional noise given all the other items in their cars that would induce various NVH characteristics.
37 is offline   Reply With Quote
Old 09-11-2013, 07:43 PM   #110
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I'll just drop this here.
[ame]http://youtu.be/JOLmmJxcD2w[/ame]
Old 09-11-2013, 07:55 PM   #111
peteralfonso
Drives: Scion FRS
I also have the ACT clutch and flywheel and mine sounds exactly the same. Stock ECU or do you have a tune? Also are you getting any check engine lights?
Old 09-11-2013, 08:04 PM   #112
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I have an ecutek tune from moto-east. No CELs in over 10k miles with the lightweight flywheel & pulleys.
Aftermarket Crank Pulley Install Enigmus DIY (Do-It-Yourself) Guides 305 02-04-2019 11:37 PM
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Agency Power Crank Pulley / Clutch Masters Flywheel vividracing Engine, Exhaust, Transmission 67 11-07-2012 02:35 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
