Old 09-03-2013, 10:39 AM   #85
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
FYI, the BRZ comes with a lighter crank pulley than the FRS (1lb), so IMO BRZ owners are better spending money elsewhere.
FRS owners will see a slight performance improvement for the $.
mwjcyber is offline   Reply With Quote
Old 09-03-2013, 10:50 AM   #86
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Originally Posted by diss7 View Post
Disagree.
I have a Toda flywheel in my ae86. No chatter.
I also doubt the TRD unit in my 86 will either.
TRD unit keeps your warranty as well (if you care) no other unit will.
That says a lot to me about the quality to expect from the TRD unit.
I'd be pointing to your clutch, and its viscous (compared to stock anyway) engagement, as to the cause of the noises you are experiencing.
When you get your trd try and see who really makes the unit. I'm willing to bet its just another off the shelf exedy unit. The trd may not chatter because its heavier than some of the lightest flywheels. I had my flywheel and clutch cover assemble balanced by a pretty reputable speed shop (r&l engines in Dover). Fwiw, they said the act setup was almost perfectly balanced out of the box.
I really recommend anyone doing their flywheel and clutch to get it balanced as a unit so it doesn't vibrate under load at speed. All things considered, I really couldn't careless about chatter at idle.
industrial is offline   Reply With Quote
The Following User Says Thank You to industrial For This Useful Post:
37 (09-03-2013)
Old 09-03-2013, 01:14 PM   #87
37
degrees
37's Avatar
Drives: 6MT BRZ
If this is your car then I can hear what sounds like gearbox rattle.
[ame="http://www.youtube.com/watch?v=__fWrW7_mDU"]AE86 3sge Beams @ Ruapuna Christchurch NZ 21/12/12 - YouTube[/ame]
Install your TRD and let us know if you hear any noise. I'm genuinely curious.
Viscous engagement? Not sure I follow.
This article explains why a lightweight, single-mass fly can rattle. The TRD uses a single-mass design so it'll be interesting to see if your results are any different. http://www.uucmotorwerks.com/flywheel/gear_rattle.htm
Agreed on the balance check. I must have been lucky since my HDSS+Prolite didn't add any vibrations. Either that or I simply don't notice them.
The rattle doesn't bother me, either. It sounds like a proper gearbox.
Last edited by 37; 09-03-2013 at 02:23 PM. Reason: Added video, moved some thoughts around
37 is offline   Reply With Quote
Old 09-03-2013, 01:54 PM   #88
meeks
slide to unlock
meeks's Avatar
Drives: 2013 FR-S Raven Black
wow really? care to post the info on where you learned this? i thought both engines are the same?!
meeks is offline   Reply With Quote
Old 09-03-2013, 03:58 PM   #89
diss7
Drives: AE86, 2x GT86, TE27
You have a point. When I received the toda clutch and flywheel for the ae86, i saw the clutch was just a rebranded exedy. Which I'd paid almost a grand for through toda, and could've gotten locally for $400.
Agree on your comment on getting the unit balanced as a whole.
To be clear, wasn't dogging the act unit. Have not used or looked into whether they're good/bad.
diss7 is offline   Reply With Quote
Old 09-03-2013, 04:01 PM   #90
diss7
That is my car. That was a test day right after it was tuned and still NA.
I thought the noise you can hear was the exhaust resonating/vibrating at a certain rev point. You could be right though.
I'll definitely review the trd unit once its arrived.
Old 09-03-2013, 04:49 PM   #91
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
So I love my ProLite flywheel. There's a lot of gear rattle, but I'll put up with it. The engine revs a lot faster, rev-matching/double-clutching is easier. It's funny because while my downshifts have become smoother due to better throttle blips, my upshifting took some time to adjust because of thefaster fall-off. And it's not that much easier to stall either. Seriously, this is how the car should have come from the factory. Aside from the noise, there's no reason not to go with the ProLite. I wouldn't even bother with the StreetLite.
The CF driveshaft is butter smooth as well. My mechanic managed to nail the proper clocking first try. No humming or vibrations.
Old 09-03-2013, 05:02 PM   #92
mwjcyber
mwjcyber's Avatar
I've seen it several places, but here's one source.
http://ft86speedfactory.com/perrin-b...black-124.html
"The PERRIN Performance Crank Pulley is 4-pounds lighter (5-pounds for Scions!) than the stock crank pulley.
Old 09-03-2013, 10:34 PM   #93
Turdinator
Señor Member
Turdinator's Avatar
When i bought mt toda flywheel for my TA22 (with a 2TG) the local toda rep said their clutches were just rebadged exedy units and to buy the exedy unit locally.
1974 TA22 Celica
2013 86 GT
Old 09-04-2013, 04:08 AM   #94
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
no issues here....
i just have the light weight water pump pulley and alt pulley...
crank pulley isnt on yet i had trouble gettin it to break loose.... any advice on how to get it off?
NYCsubaruBRZ is offline   Reply With Quote
Old 09-04-2013, 08:08 AM   #95
Hiding
Drives: Hot Lava FR-S
Originally Posted by NYCsubaruBRZ View Post
no issues here....
leave it in 6th gear and give it hell.
There is a good DIY write up here some where.
Hiding is offline   Reply With Quote
The Following User Says Thank You to Hiding For This Useful Post:
NYCsubaruBRZ (09-04-2013)
Old 09-04-2013, 10:54 AM   #96
wootwoot
Drives: FRS
no issues here....
What flywheel do you have? Any gear chatter?
Old 09-04-2013, 07:57 PM   #97
NYCsubaruBRZ
the stock flywheel.
none
Old 09-04-2013, 08:15 PM   #98
NYCsubaruBRZ
prices on a light weight flywheel?
what did you pay for yours shipped to your door?
brand?
model?
thanks 4 the help
Aftermarket Crank Pulley Install Enigmus DIY (Do-It-Yourself) Guides 305 02-04-2019 11:37 PM
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Agency Power Crank Pulley / Clutch Masters Flywheel vividracing Engine, Exhaust, Transmission 67 11-07-2012 02:35 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
