Old 09-04-2013, 08:37 AM   #15
Taro
You call him Dr. Jones!
Taro's Avatar
Drives: 2013 Twin Mish-Mash
Silly suggestion, but maybe it's the licence plate against the trunk?
Taro is offline   Reply With Quote
Old 09-04-2013, 03:57 PM   #16
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Dropped it off at the dealership and they can't see anything wrong with it.
Sent from my Q10
Old 09-04-2013, 04:22 PM   #17
SkullWorks
Drives: SSM LT MT BRZ
did you look at any of the help provided above and ask your dealer to check your axle nut tension?...im going to bet you didn't, then I'll make another bet that says that is the issue.
Old 09-04-2013, 10:50 PM   #18
Accurate Race Shop
Drives: Scion FR-S
I did show them the video and the posts and I talked to 2 engineers at toyota who are keeping an eye on this issue sense it is becoming more and more common. At first look the nuts seemed tight so they told me that was not the problem. After I urged them to take a second look they got it back on the lift later in the day and it was pretty much the problem. They did not properly stake the nut during assembly so it was retorqued and properly staked.
Sent from my Q10
Old 09-04-2013, 11:28 PM   #19
Carwhisperer
Drives: A lot of supercars.
The dealership won't even acknowledge the noise so they said nothing is wrong. Guess nothings wrong then!
Carwhisperer is offline   Reply With Quote
Old 09-04-2013, 11:55 PM   #20
Accurate Race Shop
Drives: Scion FR-S
Something is deffinitly up if the car starts making a noise it never did before. I would open a case with toyota. Unfortunitly we are the large scale testers for this platform and when some say not to worry about it us letting the company know about the problems allows them to correct them and also let's them know that as a consumer we are unhappy. I have been in business for awhile and nothing makes me more fusturated then a mad customer who didn't give me the chance to make it right.
Sent from my Q10
Clanking metal sound from rear!!!! 808Raven Issues | Warranty | Recalls / TSB 7 09-21-2017 11:09 AM
Light buzzing sound from driver-side dash BRZprime Issues | Warranty | Recalls / TSB 51 08-21-2015 10:34 PM
More sounds; metal whirring sound braking to stop in neutral l0aded Issues | Warranty | Recalls / TSB 2 07-13-2013 03:05 AM
Hawks HP Plus metal clip on the wrong side cityhugo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-01-2013 02:28 PM
Mr. Sociable's BRZ Daily Driver (slow) Build Mr. Sociable Member's Car Journals 23 11-01-2012 10:46 AM
