neutron256, Robftss
Old 08-25-2013, 08:59 AM   #309
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Good lord the engineering going on in this thread. Glad to see progress happening I'm exited to see the final product down the road!
Old 08-31-2013, 01:13 AM   #310
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
For simplicity sake I've decide my first prototype will be a 12V system. I'm also going back to one of my earlier designs because fitting the compressor wheel directly to the motor shaft was proving to very problematic.
I got my motor today so I got busy in CAD on designing all the parts.
Parts for test fitting are hot off the 3D printer (3D printing is awesome!). All the parts fit great so I'll be ordering all the off-the-shelf hardware bits & metal to machine tomorrow.
The parts:
-Backplate (3D Printed White)
-Bearing (3D Printed Clear)
-Shaft (3D Printed Blue)
-Spacers (3D Printed Red) x4
-Screws & Washers x 4
-Compressor Wheel & Nut
-12V Brushless Motor
-Compressor Housing
-O-Ring (Missing)
The bearing is pressed into the backplate. An O-Ring would also be added in the notch but I don't have one yet.
The shaft goes through the bearing
The screws with washers are placed through the backplate and spacers are added to form the motor mount
The motor is attached, and the compressor wheel is then placed on the shaft. A nut on the end of the shaft is tightened with one wrench while a second wrench is used to hold the shaft
The assembly is then placed in the compressor housing and secured with a snap ring
The Following 3 Users Say Thank You to neutron256 For This Useful Post:
DAEMANO (08-31-2013), rusty959 (08-31-2013), SloS14 (08-31-2013)
Old 08-31-2013, 10:57 AM   #311
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Drooool
Old 08-31-2013, 02:48 PM   #312
rusty959
Drives: DGM BRZ limited
Nice, looking good.
What are the specs on the bearing you are using?
The motor change is due to running 12v, correct? What are the specs of this new motor? I don't think I have seen yet.
rusty959 is offline   Reply With Quote
Old 08-31-2013, 03:51 PM   #313
neutron256
neutron256's Avatar
Originally Posted by rusty959 View Post
Nice, looking good.
Yep this is the twelve volt setup. I'm going to be testing two motors. One with higher torque, the other with higher RPMs.
SkyRC Toro SCT 4600Kv
Max Power: 2000w
Max Voltage: 18v
Max current: 180a
Brushless KV: 4600
Resistance: .005ohm
Poles: 4
Weight:220g
SkyRC X8 2650Kv
Max Power: 2200w
Max. Voltage: 17V
Max. Current: 129A
Brushless KV: 4600
Resistance: 0.0062ohm
Poles: 6
Weight: 375g
I'm not expecting the kind of PSI the Phantom SC is seeing from this 12V setup but I figured this is a good start, and it will be a much simpler system system on the battery/charging side of things.
The Following User Says Thank You to neutron256 For This Useful Post:
Old 08-31-2013, 05:15 PM   #314
rusty959
Max Power: 2000w
Max Voltage: 18v
Max current: 180a
Brushless KV: 4600
Resistance: .005ohm
Poles: 4
Weight:220g
SkyRC X8 2650Kv
Max Power: 2200w
Max. Voltage: 17V
Max. Current: 129A
Brushless KV: 4600
Poles: 6
Weight: 375g
Interesting. I'm curious to see what happens with them. What are the specs on the bearing you are using?
Old 08-31-2013, 05:26 PM   #315
neutron256
neutron256's Avatar
I'll be using ceramic bearings from Boca Bearings rated up to 65K RPM. Boca is a great source for just about any bearing you might need.
Old 08-31-2013, 06:00 PM   #316
rusty959
Nice, Boca is definitely the best place I've found so far for looking at bearings. I've found some that look like they will work for me that are rated just shy of 100k. But thats still guessing on size since I haven't started purchasing things yet.
Old 08-31-2013, 09:04 PM   #317
ciro
Drives: Scion FR-S
Thats looking pretty good. Let me know when you want to do direct metal printing.
ciro is offline   Reply With Quote
Old 08-31-2013, 10:17 PM   #318
neutron256
neutron256's Avatar
I'm just waiting on some parts so I can do a final fit test with the O-Ring.
Whats the accuracy and finish of the direct metal printing? I was planning on just milling it but if you're offering...
The shaft will have to be turned on the lathe to get the strength and accuracy needed.
Old 09-03-2013, 07:50 PM   #319
Grantmac
Drives: 2001 NB MX-5
Do you intend on isolating the 12v drive battery so that it's not charged when the ESC is powered?
-Grant
Grantmac is offline   Reply With Quote
Old 09-03-2013, 08:08 PM   #320
neutron256
neutron256's Avatar
-Grant
I'm still deciding on how I want to configure it, but yes most likely I will have a relay that opens separating the positive poles of the batteries when the ESC is active.
DAEMANO (09-03-2013)
Old 09-03-2013, 10:05 PM   #321
rusty959
-Grant
This may not have been directed at me, but I'm not planning on isolating the 12v battery even when its part of my 24v system. Not worth the added complexity/resistance/money.
Old 09-03-2013, 11:47 PM   #322
Grantmac
Are you going to run a 12v parallel to 24v series set-up like I posted? I'm seriously in favor of that option personally. Although I believe a small 12v battery might be required to run the car electronics while the system is in 24v mode.
-Grant
hairdyerperformance, only pulls hard one gear
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 07:42 PM
DUP THREAD MODZ PLZ DELETE KTHX SloS14 Forced Induction 0 07-09-2013 06:41 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 03:47 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 03:16 PM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 10:20 PM
