#309 |
Drives: 2013 FR-S, 2012 MCS
Good lord the engineering going on in this thread. Glad to see progress happening I'm exited to see the final product down the road!
#310 |
Drives: '13 GBS Subaru BRZ
For simplicity sake I've decide my first prototype will be a 12V system. I'm also going back to one of my earlier designs because fitting the compressor wheel directly to the motor shaft was proving to very problematic.
I got my motor today so I got busy in CAD on designing all the parts. Parts for test fitting are hot off the 3D printer (3D printing is awesome!). All the parts fit great so I'll be ordering all the off-the-shelf hardware bits & metal to machine tomorrow. The parts: -Backplate (3D Printed White) -Bearing (3D Printed Clear) -Shaft (3D Printed Blue) -Spacers (3D Printed Red) x4 -Screws & Washers x 4 -Compressor Wheel & Nut -12V Brushless Motor -Compressor Housing -O-Ring (Missing) ![]() The bearing is pressed into the backplate. An O-Ring would also be added in the notch but I don't have one yet. ![]() The shaft goes through the bearing ![]() The screws with washers are placed through the backplate and spacers are added to form the motor mount ![]() The motor is attached, and the compressor wheel is then placed on the shaft. A nut on the end of the shaft is tightened with one wrench while a second wrench is used to hold the shaft ![]() The assembly is then placed in the compressor housing and secured with a snap ring ![]()
#311 |
Drives: 2013 FR-S whiteout
Drooool
#312 |
Drives: DGM BRZ limited
Nice, looking good.
What are the specs on the bearing you are using? The motor change is due to running 12v, correct? What are the specs of this new motor? I don't think I have seen yet. |
#313 | |
SkyRC Toro SCT 4600Kv Max Power: 2000w Max Voltage: 18v Max current: 180a Brushless KV: 4600 Resistance: .005ohm Poles: 4 Weight:220g SkyRC X8 2650Kv Max Power: 2200w Max. Voltage: 17V Max. Current: 129A Brushless KV: 4600 Resistance: 0.0062ohm Poles: 6 Weight: 375g I'm not expecting the kind of PSI the Phantom SC is seeing from this 12V setup but I figured this is a good start, and it will be a much simpler system system on the battery/charging side of things.
#314 | |
#315 |
I'll be using ceramic bearings from Boca Bearings rated up to 65K RPM. Boca is a great source for just about any bearing you might need.
#316 |
Nice, Boca is definitely the best place I've found so far for looking at bearings. I've found some that look like they will work for me that are rated just shy of 100k. But thats still guessing on size since I haven't started purchasing things yet.
#317 |
Drives: Scion FR-S
Thats looking pretty good. Let me know when you want to do direct metal printing.
#318 | |
Whats the accuracy and finish of the direct metal printing? I was planning on just milling it but if you're offering... ![]() The shaft will have to be turned on the lathe to get the strength and accuracy needed.
#319 |
Drives: 2001 NB MX-5
Do you intend on isolating the 12v drive battery so that it's not charged when the ESC is powered?
-Grant |
#320 |
I'm still deciding on how I want to configure it, but yes most likely I will have a relay that opens separating the positive poles of the batteries when the ESC is active.
#321 |
This may not have been directed at me, but I'm not planning on isolating the 12v battery even when its part of my 24v system. Not worth the added complexity/resistance/money.
#322 | |
-Grant |
| Tags |
| hairdyerperformance, only pulls hard one gear |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 06:42 PM |
| DUP THREAD MODZ PLZ DELETE KTHX | SloS14 | Forced Induction | 0 | 07-09-2013 05:41 PM |
| Electric Turbocharger | Shankenstein | Forced Induction | 91 | 06-24-2013 02:47 PM |
| Electric 86 | frosty86 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-10-2012 02:16 PM |
| WRX Electric turbo | Neilus | Engine, Exhaust, Transmission | 42 | 05-03-2012 09:20 PM |
