Old 09-03-2013, 11:20 AM   #1
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
New TSB for camshaft sensor
thanks to my bro that works at toyota
The Following 6 Users Say Thank You to whitefrs For This Useful Post:
FRS1010 (09-03-2013), JDKane527 (09-03-2013), Nightbringer (09-03-2013), Sigh-on-Rice (09-03-2013), spitz (09-03-2013), wu_dot_com (09-03-2013)
Old 09-03-2013, 12:07 PM   #2
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
This supposed to fix the idle dip problems? Mine sometimes stumbles but not to the point where I'm worried.
lickitysplit is offline   Reply With Quote
Old 09-03-2013, 12:32 PM   #3
radroach
Drives: car
Copy/paste from the TSB article:
Some 2013 model year FR-S vehicles may exhibit intake and/or exhaust camshaft position sensor
related and/or engine misfire DTCs (P0340, P0341, P0345, P0346, P0365, P0366, P0390, P0391,
P0301, P0302, P0303, and P0304) due to the camshaft position sensor clearance being out of
specification. In addition, some vehicles may also experience rough idle or extended cranking. This
bulletin provides inspection and repair procedures to address this condition.
This bulletin applies to vehicles produced BEFORE the Production Change Effective VIN shown
below.
MODEL PRODUCTION CHANGE EFFECTIVE VIN
FR-S JF1ZNAA1#D#008792
Old 09-03-2013, 02:04 PM   #4
CSG Mike
CSG Mike's Avatar
Nothing for Subaru?
Old 09-03-2013, 02:14 PM   #5
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Nothing for Subaru?
I posted the Subaru one on TSB thread a little bit over a month ago.
11-130-13R
And, thanks OP for the document. I'll add it to the TSB thread.
Old 09-03-2013, 02:22 PM   #6
CSG Mike
CSG Mike's Avatar
11-130-13R
Ah, thank you! I missed it.
Old 09-03-2013, 02:50 PM   #7
TRD_86
Drives: 2013 86 white
Should we print this and bring the car in or wait for the TSB mail ?
TRD_86 is offline   Reply With Quote
Old 09-03-2013, 02:58 PM   #8
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Tsb is not a recall
If no cel they wont do anything
Sent from my iPhone using Tapatalk - now Free
Old 09-04-2013, 12:51 PM   #9
Carwhisperer
Drives: A lot of supercars.
Ah! Got a feeling when the toyota tech flew in a week ago and trouble shooted with my P0351 he might have just reflashed. I couldn't ever feel the car miss under WOT in higher rpms but it would throw that code. Now my car starts right up ( much faster than it used to ). Runs a lot smoother as well.
Carwhisperer is offline   Reply With Quote
Old 03-11-2014, 10:41 AM   #10
sfarrah
Drives: FRS
Has anyone been having this problem and did the TSB resolve the issue? Toyota has has my FR-S for about a month now and still can't fix the issue after 3 attempts. They tried shimming the sensor twice and then tried changing out a fuel injector and appear stumped at this point. Each time I pick up the car and don't even make it home before the check engine light is back on.
I really need to get the car back as I have new billet front lower control arms that I need to get tested.
sfarrah is offline   Reply With Quote
Old 03-11-2014, 10:44 AM   #11
White64Goat
Sounds to me like they should give you a new car if they can't fix it. Time to call corporate and get a case going.
Old 03-11-2014, 11:17 AM   #12
sfarrah
Drives: FRS
Yeah, I'm getting pretty frustrated at this point. If it was just a second car I bought for a toy then I wouldn't mind as much but since it was purchased to be used for R&D for our suspension parts (SPL Parts) then it seriously impacts our business.
Old 03-11-2014, 11:27 AM   #13
andrew20195
Drives: 2013 Subaru BRZ
Do you know which code you're seeing?
andrew20195 is offline   Reply With Quote
Old 03-11-2014, 02:54 PM   #14
sfarrah
Drives: FRS
Dealer just called and they're supposed to call me back with the code after talking with the tech. Told me they think it might be an issue with a valve and they're going to pull the head off tomorrow to inspect it.
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
02 Sensor mjsivee Engine, Exhaust, Transmission 4 06-13-2013 01:58 PM
Camshaft Bolt Coming Loose After Perrin Pulley Install WhiteBRZ Engine, Exhaust, Transmission 25 09-20-2012 08:07 AM
Bad MAF Sensor paulieblaze Scion FR-S / Toyota 86 GT86 General Forum 3 08-23-2012 10:34 PM
