Old 07-11-2013, 07:51 PM   #127
vgi
Drives: frs
Originally Posted by vgi View Post
will post as I get them
just see a pending charge from blackstone on my cc, hopefully soon I'll see the results
vgi is offline   Reply With Quote
The Following 2 Users Say Thank You to vgi For This Useful Post:
civicdrivr (07-11-2013), Hanakuso (07-11-2013)
Old 07-14-2013, 11:28 PM   #128
vgi
Drives: frs
got my results:
https://docs.google.com/file/d/0B4i3...it?usp=sharing
i also noticed that for the past few weeks the coolant level stays about the same, just a tiny loss. considering that for the first month I lost about an inch I'm inclined to think it might have been the poor factory bleeding. i will continue to monitor it though.
The Following 4 Users Say Thank You to vgi For This Useful Post:
civicdrivr (07-15-2013), DylanFRS (07-15-2013), Lonewolf (07-15-2013), Septic (07-15-2013)
Old 07-15-2013, 02:56 AM   #129
Lonewolf
Lonewolf's Avatar
Drives: Moped
got my results:
Awesome, thank you for posting this...
Old 07-15-2013, 01:48 PM   #130
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
got my results:
Flabbergasted
ineedyourdiddly
Old 07-15-2013, 01:53 PM   #131
vgi
Drives: frs
thanks for suggestion to do it for my piece of mind, i do have it now
Old 07-15-2013, 01:55 PM   #132
vgi
Drives: frs
Flabbergasted
should i just add coolant to my oil before sending for testing next time just to see them "Flabbergasted"?
Lonewolf (07-15-2013), strat61caster (07-15-2013)
Old 08-31-2013, 07:55 PM   #133
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
I'm still having coolant issues and coolant smelling hvac when I first start it up. Spoke with the dealer about paying for a pressure test and if they find anything that will warranty it. Still haven't back from them and this is the third time I've mentioned it. I also have pictures documenting the reservoir tank level dropping. And they still won't do anything about it. Does anyone have any information on how to properly do a pressure test yourself-I'm very mecanically inclined so I just need the actual procedure for this car as well as any documentation of getting to the heater core? I have the sport-tech (limited-I.e auto climate control). I'm also getting an oily residue on my windshield fairly quickly which maybe implies a heater core, but I'm not sure. Any ideas?
Gords_zenith is offline   Reply With Quote
Old 08-31-2013, 09:47 PM   #134
vgi
Drives: frs
my coolant has pretty much stabilized. it's dropping but barely noticeable now almost the same level. i am inclined to think that it was poor bleeding from the factory.
Old 09-01-2013, 01:56 AM   #135
Texaz Boy
Drives: 2016 FR-S (RS-2 #734/1000) MT
I've had my car for two months and it has 3600 miles on it. I noticed the coolant was not completely full. And I just checked it about an hour ago and its at the low mark. I'll will check in the morning after its been sitting for 12 hours. Any thoughts as to why this is happening? When I've gotten off the highway I can smell coolant when I stop at a light. Anyone have any thoughts?
Texaz Boy is offline   Reply With Quote
Old 09-01-2013, 02:00 AM   #136
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
that reservoir is a vented overflow tank, so evaporation is normal, using that as an indicator isnt 100% at all
check the depth of fluid in the radiator fill when parked on level ground dont go by overflow tank level!
448hpsti is offline   Reply With Quote
Old 09-01-2013, 02:07 AM   #137
Gords_zenith
How much evaporation would you consider normal? 3 inches from the reservoir tank every 15000km, doesn't seem normal to me! Coolant doesn't just evaporate like that, unless this new super coolant does, idk for sure. All I know is its a sealed system and shouldn't need topping up really at all.
Old 09-01-2013, 02:09 AM   #138
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
We own two of these brz, and one of ours has 30k miles, and is 7 months old. I've had to add about a pint to a quart of coolant, so I consider that normal, I also reside in the hottest part of the US: arizona
Old 09-01-2013, 02:20 AM   #139
Gords_zenith
Hmm. thanks for the info. I'm going to push forward with a simple pressure test and go from there, I don't think it's normal, not mention the coolant smell coming from the vents when the power is turned on for the fan. I'm sure its the heater core having a small leak and vaporizing. Idk anymore if I should keep worrying about it or just simply keep topping it off and pretend there's no issue.
Old 09-01-2013, 02:21 AM   #140
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
if you smell it, there is a problem!
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 07:34 AM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 08:50 PM
Engine Coolant? L3P47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-14-2013 12:33 AM
Alright to use 5-6 old coolant? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-11-2013 09:47 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
