Old 08-28-2013, 10:06 PM   #29
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
You don't need any of those fancy tools at all really, that helps but not essential
It's very simple if you can create access
Undo mount bolts for motor mounts, right?
Jack up motor two inches from oil pan with care, another inch when you're clear!
Be sure you clear stuff loosen exhaust check wires hoses etc based on your build, if you need to be told nitty gritty details I'm not the guy to do that sorry
Slide jack left or right and its under twenty minutes per side
Just did it well mostly the same job this weekend, pulled off more than plugs, pulled the entire cam cover in an hour for my project
no more than two hrs for the both sides if you go slow
Pulling cover took an hour and requires more than the room needed for plugs
I used basic hand tools, it's too tight for air tools, and a few smaller things like swivels and wobble stuff make it that much easier but once you gain access needed to pull the coils you're there, having the right plug sockets will be key, it's tight in there.
You can do it too, lifting the motor makes the needed access space, hope that helps
448hpsti is offline   Reply With Quote
The Following User Says Thank You to 448hpsti For This Useful Post:
Dezoris (09-01-2013)
Old 08-31-2013, 04:57 PM   #30
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Not to be a **** but this is exactly what the average guy doesn't know shit about. What the fuck is a wobbly extension? 10mm ? what if its 12? What coil? What is a coil? rinse and repeat, I'm not washing the car.
If you need to ask those questions you have no business under the hood of a car.
Living life one HPDE at a time
Touge Monster is offline   Reply With Quote
The Following User Says Thank You to Touge Monster For This Useful Post:
448hpsti (09-19-2013)
Old 09-01-2013, 12:29 AM   #31
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
If someone donates a car, I will do a DIY
@Sportsguy83? hahahaha
F1point4 is offline   Reply With Quote
The Following 2 Users Say Thank You to F1point4 For This Useful Post:
stevo_12v (11-02-2013), whitefrs (09-01-2013)
Old 09-01-2013, 06:28 AM   #32
mad_sb
Drives: 2013 Asphalt FR-S
Well it isn't an oil change, but it also isn't done every 5,000 miles either. These plugs should last 100,000 miles. Mine looked great after 10,000 miles of Full Blown boost.
How were the gaps on the stock plugs?
Old 09-01-2013, 09:21 AM   #33
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
When
When you coming down to MIA??
The Following User Says Thank You to Sportsguy83 For This Useful Post:
F1point4 (09-01-2013)
Old 09-01-2013, 12:45 PM   #34
Dezoris
Dezoris's Avatar
I cannot possibly see how there is enough clearance to pull coils without bending the hell out of them. Much easier to losen the two subframe bolts and lift motor to get clearance as mentioned it would take less time then fighting in a tight space and getting pissed off.
Old 09-01-2013, 01:58 PM   #35
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
It's possible. Thy don't go yanking the moor, an I swear I dint use not specialty tools
Old 09-01-2013, 02:42 PM   #36
jamesm
It's very easy. The coils are the simple part. Removing the ecu and shielding give you plenty of room. There is absolutely no need at all to lift the engine. It may or may not be the same effort as just lifting the motor, but its definitely not when you have a front mount turbo that'd have to come off to lift the motor.
Old 09-01-2013, 03:43 PM   #37
Dezoris
Dezoris's Avatar
Ok will try without it. Have the plugs just been holding off on it.
Old 09-01-2013, 05:20 PM   #38
utekineir
blowhard
Drives: frs, project forester
hated doing plugs on my forester before removing the subframe spacers
i see this as more of the same.
plenty doable just a pita until you get the extension/tool sequence down.
utekineir is offline   Reply With Quote
Old 09-01-2013, 07:56 PM   #39
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
They were all real close to factory gap. I gapped them down .001 less with feeler gauges.
Old 09-06-2013, 11:41 AM   #40
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
So I finally got under the car and pulled the guard off...
I'm sad to say that there's no other way. The engine MUST be lifted in order to change/check the plugs. Really, that is awfully annoying. Just when I thought my MR2 was bad to work on, this is probably just as bad if not more annoying!
It would've been nice to have a service hole through the frame or something. But having to undo an onslaught of items for a simple spark plug check/change is quite ridiculous.
I seriously hope these plugs can handle a good amount of boost for a long time because who the hell has the time to lift a damn engine periodically!
Ughhhhhhhhhhhh....
/rant
hmong337 is offline   Reply With Quote
Old 09-19-2013, 10:27 AM   #41
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
All stuff can be made to clear, and a well designed kit will still leave clearance, plus as you lift up radiator support clearances increase. You shouldn't run into any interference if you're careful, I don't suggest you lift 5-6 inches like I think I read somewhere.
I lift with microfiber cloth under my oil pan my jack has a nice rubber pad. Use old car mat if your jack isn't smooth like mine.
Raise car five minutes for me max, you take more time to read this thread.its your job to do this part safe, and in my opinion the hardest and most critical part of the job in my driveway.
Once the car is supported entirely by the frame, Just simply loosen the two motor mount bolts or nuts iirc that's what oe was, I use air tool so this takes one minute or about two by hand, more time looking for excuses, its not hard I promise.
Lift it just enough so you can move it left or right that's about two minutes. Once you lifts up that two inch you can slide jack left or right enough to pull out coils and plugs. Have a helper a pry bar ya know, basic stuff shops have. Loosen exhaust bolts can help. Little more depemding on your setup, i take off my airbox. Watch ac hard line.
You guys are making easy work seem hard. All done with basic tools, your local autozone will sell you a wobble 2" and I used a regular deep 14socket and stuff you find at sears.
I wouldn't try to do it without lifting it or waste time looking for tools to do that. Just sayin.
Old 10-30-2013, 05:40 PM   #42
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
I will try to do a DIY with pics soon. As i am thinking i may need to replace mine, or at least check them out. Started getting CEL---- P0300, and P0301 codes now.... Believe thats a generic misfire, and a misfire on cylinder 1.
Are these a concern occasionally? I just started noticing them on the last tune my tuner sent me..Maybe flash back and see if that fixes things.
Any thoughts?
gdrider77 is offline   Reply With Quote
spark plugs change... fistpoint Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 53 02-23-2022 10:37 AM
Spark plugs for turbo whitefrs Forced Induction 88 05-05-2018 10:18 PM
need help in Long Island to check spark plugs whitefrs NY / NJ / CT / PA 0 08-09-2013 10:29 PM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 12:24 PM
Jowett Jupiter/spark plugs aspera Engine, Exhaust, Transmission 6 02-25-2010 06:47 PM
