Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Checking your spark plugs?
I figure this is probably the best place to post as being more modified requires you to investigate your plugs more closely and frequently.
So have you guys found an easier way to check your plugs? This is why I always stayed away from Subarus. A 5 minute job on 90% of cars to check/replace plugs is like a 5 hour job on these cars! Looking to see if anybody has developed a short cut. Thanks.
NASA SpecE30 Racer
With the right tools you can do it without jacking the motor up. I jacked my motor up, and still pulled all 4 and regapped them and the whole process was under 3 hours.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | suaveflooder (10-30-2013) |
NASA SpecE30 Racer
Well it isn't an oil change, but it also isn't done every 5,000 miles either. These plugs should last 100,000 miles. Mine looked great after 10,000 miles of Full Blown boost.
- King Tut
it's pretty easy with the right tools as mentioned above. a couple of wobbly extensions and a small ratchet is really all you need to accomplish the job in under a half hour. The key is removing the ecu thing on the passenger side and metal shielding on the driver's side to give yourself some room to work.
| The Following User Says Thank You to jamesm For This Useful Post: | charged86 (12-26-2014) |
#6 | |
Thanks
#7 | |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Hopefully someone posts up a DIY with pics and what tools they managed it with. (Lengths of various extensions to get the right combinations).
Nolan
| The Following User Says Thank You to pheoxs For This Useful Post: | hmong337 (08-28-2013) |
#8 | |
the job itself is pretty self-explanatory. it's pretty obvious where the spark plugs are and what you have to do to get to them. the gist of it is:
you may need to feed on one more extension depending on how long yours are, but make sure to use the smallest ones possible. you don't want to put a longer (3" or more) one in the and not be able to get it back out. smaller ones that wobble afford you the flexibility you need. |
| The Following User Says Thank You to jamesm For This Useful Post: | normancw (04-07-2014) |
Drives: 2013 frs
Good thread idea
This will be useful to know once its time for me to change my plugs down the road Thanks |
#11 | |
Thanks
| The Following User Says Thank You to ZionsWrath For This Useful Post: | YouShallKnow (12-10-2014) |
#12 |
I Love custom Turbo kits
Drives: Limited BRZ
Not to be an as*-hole but if you don't understand this terminology, you shouldn't be trying to do the plugs. Take it to a reputable shop, show them this write up and let them do it.
| The Following 8 Users Say Thank You to Sportsguy83 For This Useful Post: | Akari (08-15-2014), andrew20195 (08-28-2013), Calum (08-28-2013), Dipstik-sportech (04-23-2015), j122987 (08-15-2014), rallysrt (02-16-2015), suaveflooder (10-30-2013), tmichel (12-28-2014) |
#13 |
NASA SpecE30 Racer
A wobbly extension has a joint on the end that allows the socket to wobble on the end of it. He is talking about buying multiple 3/8" size and probably under an inch long extensions. The coil bolts to the valve cover and provides the spark to the spark plug. You can't get to the spark plugs without removing the coils. There is one coil for each spark plug.
- King Tut
#14 | |
NASA SpecE30 Racer
- King Tut
| The Following User Says Thank You to King Tut For This Useful Post: | Sportsguy83 (08-28-2013) |
| spark plugs change... | fistpoint | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 53 | 02-23-2022 09:37 AM |
| Spark plugs for turbo | whitefrs | Forced Induction | 88 | 05-05-2018 09:18 PM |
| need help in Long Island to check spark plugs | whitefrs | NY / NJ / CT / PA | 0 | 08-09-2013 09:29 PM |
| spark plugs | subaruferrucci | Engine, Exhaust, Transmission | 22 | 04-10-2013 11:24 AM |
| Jowett Jupiter/spark plugs | aspera | Engine, Exhaust, Transmission | 6 | 02-25-2010 05:47 PM |
