Old 08-29-2013, 04:17 PM   #1
qoncept
qoncept's Avatar
AC weak at idle
I haven't talked to the dealer yet but my AC is very weak at idle and I wanted to make sure it's not normal. It's been very hot here lately. By as little as 1500rpm it's blowing nice and cold but at idle it just can't keep up.
Also, is AC going to be covered under warranty? I'm going to be too busy to talk to the dealer before the weekend.
qoncept is offline   Reply With Quote
Old 08-29-2013, 04:30 PM   #2
PhreshhWun
PhreshhWun's Avatar
Drives: 2013 Subaru Brz Sport-Tech SWP
I have the same problem actually. However whenever I turn my A/C on the idle gets really rough and shaky. I forgot to mention it to the dealership the last time I went for the fuel pump and tail lights but yea.. I think its a common problem though
Mods: 2013 Subaru Outback fog lights, HID fog lights, LED vanity lights, LED dome light, LED trunk light, LED license plate lights, LED door courtesy lights, LED side markers, HID headlights, J2 Engineering test pipe, HKS Drop-In air filter, Window Visors, De-badged, and Diode Dynamics LED side mirrors
Side Chick: 93' 240sx Convertible
PhreshhWun is offline   Reply With Quote
Old 08-29-2013, 04:41 PM   #3
infinite012
Drives: 13 DGM BRZ Ltd
Your car, sitting, at idle, doesn't have much air flowing through the radiator. When you start to move, air passes through your radiator, cooling your stankass.
infinite012 is offline   Reply With Quote
Old 08-29-2013, 04:46 PM   #4
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Ever since the switch away from R12 in 1994, AC has suffered. R134 needs something like three times the condensor area for similar performance, and even then it's almost useless without a lot of airflow.
So, long story short, that's normal. You gotta be moving.
Admiral Ballsy is offline   Reply With Quote
Old 08-29-2013, 05:29 PM   #5
qoncept
qoncept's Avatar
I guess what I meant to say is normal for our cars (and, for the record, the only car I've ever owned on R12 had a seized compressor). I've obviously been in a lot of other cars with AC and this is weak enough that it's NOT normal.
So.. has anyone noticed the twins' AC to be worse than other cars?
Old 08-29-2013, 05:50 PM   #6
Admiral Ballsy
Shorter of breath
I'd say mine is as good as any R134 car I've owned. Better than a lot, but then it's working with a pretty small passenger compartment.
Old 08-29-2013, 06:05 PM   #7
mike the snake
My AC is capable of blowing icy cold, but the compressor cycles on and off so the air goes from cold, to not-so-cold, to cold, etc.
Not blowing super cold at idle is somewhat normal, but the AC fan should make it work OK at idle.
Old 08-29-2013, 06:29 PM   #8
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
I have to be moving to get my car to cool down decent. My '07 Silverado will flat out freeze you out of it...sitting or moving
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
The Following User Says Thank You to 6speed_Sam For This Useful Post:
RevoG (08-31-2013)
Old 08-29-2013, 06:32 PM   #9
mad_sb
Drives: 2013 Asphalt FR-S
I have noticed this too. Only an issue at idle. Really sucks when the car has been in a hot parking lot all day and you hop in for to commute home in slow stop and go traffic. You really need some air ,moving over the condenser to get any cool air in mine.
I'm gonna see if I can edit the ROM to turn the fans on sooner at idle for this very reason.
Old 08-29-2013, 06:34 PM   #10
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I have the same problem to, but i don't really consider it a problem since i don't sit around scratching my balls with the car running. I've been a few cars like this too, 350Z.
Old 08-30-2013, 10:32 AM   #11
brillo
Drives: 2013 Firestorm FR-S
make sure you have the A/C set to recirculate if you want the best A/C performance. I live in Houston and find the A/C to be fine for a small car.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 09-03-2013, 02:34 PM   #12
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
It's pretty standard for 134A cars. You have to get the car moving to get the temperature down. If you were so inclined I suppose you could put a smaller pulley on the compressor, but that sounds like a bad idea. I really wish they'd start making electrically driven A/C compressors standard on sports cars, though. As long as you have a solid electrical system, it's far less of a drag on the motor (although I've noticed the MPG difference with the A/C on in this car is negligible).
DoomsdayJesus is offline   Reply With Quote
Old 09-04-2013, 03:27 PM   #13
SubyRS1
SubyRS1's Avatar
Drives: 2015 Scion FRS-One
My Subarus have always had weak AC's compared to other cars I've owned. But you have to be moving to get best cooling as mentioned.
SubyRS1 is offline   Reply With Quote
Old 09-04-2013, 05:08 PM   #14
mla163
Overthinking it
Drives: BRZ in CS
I have the same thing. It's never stalled on me though.
mla163 is offline   Reply With Quote
Stock brakes too weak? Alabang BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 111 09-13-2013 04:41 PM
Weak Japanese horn mit_peid Scion FR-S / Toyota 86 GT86 General Forum 29 06-13-2013 11:43 AM
Weak battery or bad alternator from factory? empower-auto Issues | Warranty | Recalls / TSB 2 09-21-2012 02:17 PM
weak paint on bumper 1strwdcar Cosmetic Modification (Interior/Exterior/Lighting) 6 08-15-2012 09:19 PM
Why are most stock wheels weak stance? #87 Other Vehicles & General Automotive Discussions 16 12-17-2011 05:15 AM
