Old 07-20-2012, 05:54 PM   #15
ssmtsx
Drives: Ultramarine 6MT FR-S
Originally Posted by GL4787 View Post
there's an option to turn off DRL's on a scan tool, but when we did it i lost high beams. they come on but at DRL brightness which is way less bright.
Did you see the service bulletin for the DRL disable? Toyota will pay to have the gateway ECM replaced. You'll be able to deactivate your drls and have functioning highbeams.
ssmtsx is offline   Reply With Quote
Old 03-03-2013, 01:20 AM   #16
vault
86TUP
Drives: 86 GT
globe size for fogs/drl anyone? (Aus spec GT)
vault is offline   Reply With Quote
Old 08-28-2013, 03:32 AM   #17
Godzilla35
Drives: Nissan GT-R
if you have your DRL's disabled... is there anyway for them to be turned on with the parking lights (first click)?
Godzilla35 is offline   Reply With Quote
Old 08-28-2013, 04:40 AM   #18
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Re wire it by tapping the power into the parking lights. Or something along those lines.
FRSfan111 is offline   Reply With Quote
The Following User Says Thank You to FRSfan111 For This Useful Post:
Godzilla35 (08-31-2013)
Old 08-28-2013, 12:24 PM   #19
NIKDENG
Drives: RED BRZ
Did this 2 months ago. I just rewired it and tapped the power from the park light as Godzilla35 mentioned. I like the effect:
NIKDENG is offline   Reply With Quote
The Following User Says Thank You to NIKDENG For This Useful Post:
Old 08-29-2013, 01:57 PM   #20
Cameronghanson
Drives: n/a
must be different from US spec because when the parking brake is off and parking lights on this is what it is stock
Cameronghanson is offline   Reply With Quote
Old 08-31-2013, 05:11 AM   #21
Godzilla35
Drives: Nissan GT-R
yeah... that's what I want except I have a FRS lol.
Old 09-01-2013, 10:12 AM   #22
Mikem53
Drives: FR-S 6MT
I find it interesting you can't turn them off. In my last DD (a Chevy) you could disable them by pressing the interior light shut-off button 5 times quickly. It wasn't documented, I discovered it by accident.
Unfortunately you had to do it every time you started the Astro. It may have had that option because the DRLs came on even when the car was in Park.
They can be turned on and off via techstream, you can have your dealer set them for you.. I have the cable and software that does this and many other options on the car.
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
Dadhawk (09-01-2013)
Old 09-01-2013, 10:36 AM   #23
Thanks. That's just makes me even more aggravated by it. If a tech can do it, the owner should be able to do it without having to buy "extras".
For example, in my 2004 Suburban Z71 you can set every single option such as this using the steering wheel controls and the dash display. Not only that but it will track the options for two different drivers based on the key fob.
Yes, I realize we are talking about two different price classes of cars here (although since I bought the Chevy used I paid about 2/3 more for the FR-S than I did the Suburban) but still it should be an owner selectable option.
Old 09-01-2013, 12:56 PM   #24
Mikem53
Drives: FR-S 6MT
They will do it free for you once when you buy the car.. Otherwise it will cost you about $75 to have the dealer set the option. I paid $25 for the cable and downloaded the software from a link on here. Many other options to set via techstream as well, OBDII diags and engine/systems health checks too. Well worth the cost..
Dadhawk (09-02-2013)
The headlights.... Rob_g Scion FR-S / Toyota 86 GT86 General Forum 22 06-24-2012 02:56 AM
Anyone here every pulled headlights apart? DarrenDriven Northwest 16 06-15-2012 05:58 PM
Anyone know how to remove headlights? Memphis Cosmetic Modification (Interior/Exterior/Lighting) 25 06-12-2012 07:31 PM
FR-S w/ BRZ headlights :) Carban FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 30 06-04-2012 11:19 PM
Headlights too dim Franisco Other Vehicles & General Automotive Discussions 10 05-15-2012 04:11 PM
