Drives: 2-door
DRL & Headlights
Just curious if anyone has looked into getting the DRL to run at the same time as the Headlights? More for aesthetic purposes then anything
#2 |
Drives: 2012 Toyota GT 86 Manual
I'm going to be looking into this for the AUS version. We have the fog lights/DRLs down under the indicator, and they turn off once the headlights turn on. So frustrating. This is on the GT model mind you, not the GT-S.
Current: '12 Toyota GT 86 Pearl White Manual
Previous: '96 Toyota Supra SZ-R |
#3 |
Drives: Ae86,X2 , Scion FRS
The FRS DRL is the high beam ran at a lower voltage by a relay under the hood pulling the relay means ditching your high beams for us in the states. Im curious to see about maybe swapping pin locations in the fuse/relay box under the hood to disable the drl's. But I am now at work and will have to try it when i return home .
#4 | |
Unfortunately you had to do it every time you started the Astro. It may have had that option because the DRLs came on even when the car was in Park. |
#5 | |
Drives: 2-door
#6 |
Drives: 2013 Scion FR-S 6MT
Just wondering what bulb drl/high beams fRS require. I know the low beams are h11 but if anyone can Lmk what's the high beams are its be much appreciated thnx in Advance
![]() Sent from my iPhone using Tapatalk
I don't always drift every corner, but when I do, I drift FRS
. Stay drifty my friends ![]() 2013 Scion FRS Whiteout 6MT |
#7 |
Drives: 2-door
Bump!
has anyone looked into getting the DRLs to run with the headlights? I'm no electrical expert but I'm wondering if its something as simple as grounding a wire? |
#8 | |
Drives: Attitude
To be clear though, aren't DRLs on ALL the time? DRL is the LED strip above the fogs on the (USDM) BRZ models, whereas the "boomerangs" are parking lights, from what I've read on the forum anyway. |
#9 | |
Drives: 2-door
#10 |
Drives: Attitude
In that case it might be as simple as PULLING the signal wire that grounds them out. Might.
#11 |
Trident Motorsports Owner
Drives: DGM. DD for my EvoX
is the boomerang on at the same time as the headlights?
previous cars:1998 chevy s10 2001 Prelude SH 1992 (JDM)RX7 FD Current Cars:2010 Mitsubushi Evo X GSR 2013 Subaru BRZ Sponsors:Mishimoto/Flossy/Tomei
Craig.tridentms@gmail.com |
#12 |
Toyota Service Writer
Drives: Whiteout M/T, 2003 Duramax
there's an option to turn off DRL's on a scan tool, but when we did it i lost high beams. they come on but at DRL brightness which is way less bright.
Whiteout Manual
I'm a service writer at a Toyota/Scion dealership, if I can help at all let me know. |
#13 |
Drives: WRB BRZ limited 6MT
What is the bulb size?
#14 |
Kouki-Monster
There's already a write up on this forum about how to remove the DRL resistor box. Search more people.
Rich Anderson
EMPOWER AUTO |
| The headlights.... | Rob_g | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 06-24-2012 02:56 AM |
| Anyone here every pulled headlights apart? | DarrenDriven | Northwest | 16 | 06-15-2012 05:58 PM |
| Anyone know how to remove headlights? | Memphis | Cosmetic Modification (Interior/Exterior/Lighting) | 25 | 06-12-2012 07:31 PM |
| FR-S w/ BRZ headlights :) | Carban | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 30 | 06-04-2012 11:19 PM |
| Headlights too dim | Franisco | Other Vehicles & General Automotive Discussions | 10 | 05-15-2012 04:11 PM |
