Old 08-21-2013, 11:43 AM   #15
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by FR-S Matt View Post
18X9.5's square, 245/35's, and Tarmac 0 coilovers. I can corner hard now and have tons of clearance. I absolutely love the feel of it now. Feels much better than stock.
What brand/model are your 245/35s? Can you snap a pic of wheel edge to show how they fill? Tire edge to wheel edge gap "if any"..
Was your reasoning for this size cause you are really low and worried of clearance? I really don't want to stretch more then existing 255 size..
Thx
Old 08-21-2013, 11:54 AM   #16
FR-S Matt
Thx
Continental ExtremeContact DW's summer tires. I should have a pic floating around here somewhere where I showed the tire to rim gap. These weren't stretched hardly at all.
The reason I went with this size is because after using miata.net and the tire tool on here, these were the size that wouldn't throw off my speedometer.
Now that I have coils, I may consider going 255-265 now, but probably stick with 35 sidewall as 40 is probably a bit much and I'd have to adjust ride height again.
Old 08-21-2013, 02:11 PM   #17
John.Hong
John.Hong's Avatar
Drives: 2013 Ultramarine Frs
If this helps at all, I'm running 255/35R18 with my 18x9.5 square. I'm not entirely sure how much lower I am than stock because I did a lot of adjusting. No rubbing during DD at all. Incredible amounts of grip. Slight rubbing on really hard cornering or if the corner is cambered. Im running BFG sport comp 2s. I think they are a truer fit. 265 would be square fit on 9.5.
for reference:
John.Hong is offline   Reply With Quote
The Following User Says Thank You to John.Hong For This Useful Post:
OICU812 (08-21-2013)
Old 08-21-2013, 02:25 PM   #18
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Love to hear from those that went from "stock/anything less then 9.5" in 18s to having 9.5" in front and if there are any regrets or negatives.
No regrets. Negatives are rubbing issues depending on tire size and offset.
Old 08-21-2013, 03:31 PM   #19
lp87
Drives: 2013 swp brz
for reference:
Looks great. A fender to hub measurement would help get an idea of how much it's lowered
lp87 is offline   Reply With Quote
The Following User Says Thank You to lp87 For This Useful Post:
John.Hong (08-21-2013)
Old 08-21-2013, 03:34 PM   #20
loogs
Drives: on cruise control
great thread. im looking to switch from 17x9 to the 18x9.5 setup also
loogs is offline   Reply With Quote
Old 08-21-2013, 06:35 PM   #21
OICU812
Just a dude
OICU812's Avatar
Yes and thanks to all that are offering their experience. Seems if I choose a coil setup with room and stay 255/35/18 "slight" stretch with 9.5" I'd be 100% safe. I wanted really to consider but more sidewall and to get the tire better flush to wheels edge but seems then it becomes "maybe" more then anything.
The Following User Says Thank You to OICU812 For This Useful Post:
Old 08-21-2013, 07:44 PM   #22
g0lden
Drives: 2013 Scion FR-S Argento
for reference:
John, what offset is that you are running?
g0lden is offline   Reply With Quote
Old 08-22-2013, 01:23 PM   #23
loogs
probably +35
Old 08-22-2013, 02:20 PM   #24
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
What kind of offsets and camber are you 18x9.5 guys running?
Does the car camber in enough in front that just front crash bolts will work as you lower it or are camber plates a must?
Just curious.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 08-22-2013, 03:48 PM   #25
John.Hong
John.Hong's Avatar
Im running +35 all around.
Old 08-22-2013, 03:50 PM   #26
John.Hong
John.Hong's Avatar
Just curious.
with +35 all around, the rear natural camber works fine for me but in the front i'm maxed camber which is about -3. the front for me is slightly lower than the rear which is why i need that much camber. I think for the front, you'll need camber plates either way because they will poke with 9.5
Old 08-24-2013, 01:57 PM   #27
lp87
Originally Posted by lp87 View Post
I've also been looking into the f14's but want to run a 18x10 probably 42 offset all around. Anyone have any thoughts on this? Plan on running a 255/35 or 265/35.
Any ideas on fender modification? Not too worried about responsiveness, as the f14's are very light for their size, I think under 20 lb
edit: also, would there be any inner clearance issues (ie rubbing fender liners) with kw v3's?
anybody?
Old 08-24-2013, 08:55 PM   #28
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
If you lower you'll get some negative for free anyway. Depending on the drop it shouldn't be too super pokalicious.
denkigrve is offline   Reply With Quote
"LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" F-T Exterior Parts - Lighting 169 08-20-2016 01:15 PM
Wheel + Suspension Question 18x9 +40 225/40/18 Front 235/40/18 Rear Asphalt~86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-10-2013 07:34 PM
anyone running 18x9 front and 18x10 rear? YDNA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 05-06-2013 12:55 AM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
For those running 18x9.5 all around empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 11-17-2012 11:10 AM
