Old 08-19-2013, 05:44 PM   #1
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
To those running 18x9.5" up front..question
So in considering changing my next wheel option TE37SL from a staggered 18x8.5" ft and 18x9.5" rear to a full on 18x9.5" square setup likely 40 offset. Primarily as my "street and looks set". Then I begin to ask myself would putting such wide tires up front somehow feel "sluggish, doggy" in any way? My mind says to some degree it has to given the width but maybe I'm fucked up and there is no concern?
Love to hear from those that went from "stock/anything less then 9.5" in 18s to having 9.5" in front and if there are any regrets or negatives.
The other concern I have is the stress suh a width and weight would have on our existing power steering system and associated bits...
Also please state your tire size and camber to front and back if you know it! Also how much lower then stock you are
Thanks for your time!!
Old 08-19-2013, 06:43 PM   #2
John.Hong
John.Hong's Avatar
Drives: 2013 Ultramarine Frs
I don't think you should have any problems. I'm running 18x9.5 square and its still rather nimble in steering. Having said that, you're going with te37sl which are relatively light so you shouldn't have any problems with putting stress on the steering system.
John.Hong is offline   Reply With Quote
The Following User Says Thank You to John.Hong For This Useful Post:
OICU812 (08-20-2013)
Old 08-19-2013, 07:17 PM   #3
FR-S Matt
18X9.5's square, 245/35's, and Tarmac 0 coilovers. I can corner hard now and have tons of clearance. I absolutely love the feel of it now. Feels much better than stock.
The Following 5 Users Say Thank You to FR-S Matt For This Useful Post:
Carlysh (01-17-2014), CxG (11-05-2019), John.Hong (08-21-2013), Joveen (02-04-2020), OICU812 (08-20-2013)
Old 08-20-2013, 11:16 PM   #4
DAMotorsports
Drives: 2013 Scion FRS "Raven"
we are running 18/9.5 rapped with 275/35 Hankook RS3 and love the set up. we are running a 48 offset, but using a spacers to help with DD, so for DD we are at 42 in the front. its a close fit but we track the car also
DAMotorsports is offline   Reply With Quote
Old 08-20-2013, 11:41 PM   #5
OICU812
Just a dude
OICU812's Avatar
Good to know thanks.
Specifically thinking of TE37SL 18x9.5" (+40) offset with 255/35/18 MPS-AS tires
Obviously this is not a track setup rather a looks DD setup. I just like the concave the width 9.5" gives.
Old 08-20-2013, 11:41 PM   #6
OICU812
Just a dude
OICU812's Avatar
Glad the coils sorted that for you Matt!
Old 08-20-2013, 11:44 PM   #7
DAMotorsports
a 255 will have a bit of a stretched look. We have a member that has 265/35 and the rim sticks oout from the tire and he worries about the curb all the time. FYI
Old 08-21-2013, 12:14 AM   #8
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Keep in mind that not all 265/35's measure to the same tread width.
To the OP, I'm about to go 18x9.5 Forgestar F14s all around. I've been debating on whether or not I should settle with 265/35/18 Michelin PSS or test my luck on 275/35/18 BFG Rivals. The michelins measure out to 10.1" and the rivals are 10.2" in tread width.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
The Following User Says Thank You to Acree For This Useful Post:
OICU812 (08-21-2013)
Old 08-21-2013, 12:26 AM   #9
OICU812
Just a dude
OICU812's Avatar
On my rear RT5s I have now which are 18x9.5" I'm running 255/35/18 tires now and the stretch is very slight, I have 225/40/18s on front on 8.5" I did this to keep closest % to stock rolling ratio. I get what you are saying though for sure I would like abit more meat and have considered upping this to fill out the edge of course that losses some room as well for clearances but I'm also only planning on lowering by an inch to 1.25" at most from stock height to maintain as much strut stroke as possible.
The Following User Says Thank You to OICU812 For This Useful Post:
ShoGun (08-22-2013)
Old 08-21-2013, 12:29 AM   #10
OICU812
Just a dude
OICU812's Avatar
A friend has Michelin PSS in same size as me and oddly like you say his PSS are mucho meatier then mine his actually fill that last void. Please let me know how that works for you and at how much low you go. Honestly I'd be worried past 265 myself but then again "I don"t really know" what fits for tires for this width and this" low" that will be my next thing to get a solid answer.
Old 08-21-2013, 01:21 AM   #11
DAMotorsports
You are right every tire is different. I'm speaking from moths of testing, and years of racing. You don't run a 275/35 squared set up without knowing what you doing. We are running the hankook RS3 now, but tested falcon, BFG R1, and Toyo....
As for the rivals they will fit like the rs3
Old 08-21-2013, 02:14 AM   #12
nix
nix's Avatar
Drives: AVO BRZ
I have 245/35 super sports on 9.5 + 38. Upgrading front sway bar lightened the feel a bit but I wouldn't want to go too much bigger on a daily.
nix is offline   Reply With Quote
The Following User Says Thank You to nix For This Useful Post:
CxG (11-05-2019)
Old 08-21-2013, 11:29 AM   #13
lp87
Drives: 2013 swp brz
I've also been looking into the f14's but want to run a 18x10 probably 42 offset all around. Anyone have any thoughts on this? Plan on running a 255/35 or 265/35.
Any ideas on fender modification? Not too worried about responsiveness, as the f14's are very light for their size, I think under 20 lb
edit: also, would there be any inner clearance issues (ie rubbing fender liners) with kw v3's?
lp87 is offline   Reply With Quote
Old 08-21-2013, 11:33 AM   #14
OICU812
Just a dude
OICU812's Avatar
How much lower then stock are you? At 1" lower 255/35 lots room and you're more stretch you must be really low to be concerned?
"LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" F-T Exterior Parts - Lighting 169 08-20-2016 01:15 PM
Wheel + Suspension Question 18x9 +40 225/40/18 Front 235/40/18 Rear Asphalt~86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-10-2013 07:34 PM
anyone running 18x9 front and 18x10 rear? YDNA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 05-06-2013 12:55 AM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
For those running 18x9.5 all around empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 11-17-2012 11:10 AM
