Old 06-16-2013, 07:22 PM   #29
wparsons
wparsons's Avatar
Originally Posted by Doborder View Post
This kit is just for the ducts alone
No piping pt backing plate
http://aprperformance.com/index.php?...=330&Itemid=44
I emailed FT86speedfactory and they confirmed that you get both the inlets and the outlets in the APR kit that they sell, just add piping.
flickr
Old 06-17-2013, 02:07 AM   #30
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
Originally Posted by RehabJeff86 View Post
PMu was great at MRLS w/o fading but like CSG Mike said, it makes brake pads more effective and lowering overall cost....im seriously considering this kit
We'll talk after my first track day in the BRZ... too many unknowns... I don't want to get something unless I know I need it.
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 06-25-2013, 11:07 AM   #31
orthojoe
If you can't get the brakes to fade or overheat at MRLS, which neither Jeff or I have, then you're ok. MRLS is about as brutal as it gets with brakes. However, that could change if you upgrade grip and power. For mine, yours, and Jeff's current setup this kit will only help with longevity by keeping things cooler. However, I'm impressed with the durability of the PMu CR pads even without. We only lost a few mm of pad thickness at MRLS, compared to >1/2 of the pad's original thickness when I tracked my Evo there. My guess is that we'll never need to use cooling ducts unless power is upgraded significantly on our cars.
I'd get the cooling duct kit for your GTR first, Mike.
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 08-21-2013, 05:08 PM   #32
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Just an update from my 3rd track day with this kit:
It's working great; only losing 1/32" of pad material per track day, can't even measure the rotor thickness drop with my micrometer, so should be good through the rest of the year on these pads (Hawk DTC-60s).
No brake fade at all with Michelin Pilot Super Sports on, normal heat checking but after 3 full days no cracks that can be caught by a finger nail, and there don't appear any more or worse heat check cracks than there were at the end of my first session on the first track day. These stock rotors should last me a while (knock on wood).
smbstyle is offline   Reply With Quote
The Following 3 Users Say Thank You to smbstyle For This Useful Post:
amram (01-09-2014), CSG Mike (08-21-2013), Touge Factory (08-23-2013)
Old 08-21-2013, 05:15 PM   #33
CSG Mike
CSG Mike's Avatar
How much would you attribute to the brake setup, and how much to the ducts?
Old 08-21-2013, 05:23 PM   #34
smbstyle
smbstyle's Avatar
I definitely attribute the lack of fade to the ducts, because I compared open vs. closed ducts and noticed a significant difference, as after two laps with them closed off I had fade, but when open I can run full sessions without any fade at all.
Compared to what others have experienced with horrible rotor wear and complete cracking on the first or second track day (Dave_ROR and LDadrenaline), I would say that I am fairing much better than them, with the main difference being I have the brake ducts. However, it would be hard to say that is directly correlated with me having ducting and they don't, as there is a difference in driving style, brake pad material used, etc.
I am not sure what kind of wear people are having with pads, but I'm happy with losing 1/32" a day.
I think my next pads are going to be Cobalts; I've always wanted to try them, and hear they are hard on rotors, so we'll see how long I can get these bad boys to last.
Also, to update on the little issue I had with the location of the speed sensor wire contacting the duct backing plates with the wheels at centerline, I solved the issue with putting some heat tape around the wire in the location it rubbed, and some heat tape on the piece of metal that the wire contacts. No wear/issues with that at all now.
The Following 2 Users Say Thank You to smbstyle For This Useful Post:
amram (01-09-2014), Touge Factory (08-23-2013)
Old 08-21-2013, 05:26 PM   #35
CSG Mike
CSG Mike's Avatar
I definitely attribute the lack of fade to the ducts, because I compared open vs. closed ducts and noticed a significant difference, as after two laps with them closed off I had fade, but I can run full sessions without any fade at all.
What pads are you using?
I know @Dave-ROR has cracked a rotor, but we haven't, and our rotors have easily seen 100+ deep heat cycles.
Old 08-21-2013, 05:30 PM   #36
smbstyle
smbstyle's Avatar
I am using DTC-60s, and I am using the brakes HARD.
Old 08-22-2013, 02:24 PM   #37
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
You guys want to see pictures of my DTC-60's? This is what 3 different sets did to me...
PRO86 | WTCC | STL
Old 08-22-2013, 02:26 PM   #38
rice_classic
No more Hawk pads for this guy.
I have now sold my soul to Raybestos for brake pads. The ST series got to "11".
I use ST43's and 42's depending on track. (42's for tracks that are easier on brakes and 43's for when I'm racing in Hell)
PRO86 | WTCC | STL
Old 08-22-2013, 03:34 PM   #39
CSG Mike
CSG Mike's Avatar
but the DTC is so (relatively speaking) inexpensive!
Old 08-22-2013, 04:55 PM   #40
smbstyle
smbstyle's Avatar
wow, that's horrific. any explanation from Hawk on that issue?
Old 08-22-2013, 05:58 PM   #41
rice_classic
Negative. Never pursued it. But I'm not the only one to have this happen. I was warned before I bought them, did it anyway.
No damaged occured, pad material stayed put until the pad itself was removed from the caliper. Not catastrophic failure. If there was a braking failure while on track you can bet your ass I would have contacted Hawk but...
Since there's multiple brands out there that "do it better", it's just easier to not buy Hawk again than worry about hassling with them.
I was paying $145 for the Hawks, now I pay $220 for my Raybestos. The Raybestos pads are good for 1500 degrees, they are "relatively" kind to rotors (the 42's are insanely kind to rotors), they will never give up and they wear like iron. They out perform and last more than twice as long on my under-braked race car than ANY OTHER PAD I've used. So when I sit down and calculate the cost per life of pad and rotor replacement... The Raybestos ST series are a superior value.
Sometimes the things that cost more, end up costing you less. This is one of those times.
p.s. you really want to extend the life your pads... Flip them between sessions. It's really easy on single or double piston floating calipers, takes all of 5 minutes and keeps your pads from tapering! Think how much money you can save when you're not throwing them away due to taper.
PRO86 | WTCC | STL
The Following 3 Users Say Thank You to rice_classic For This Useful Post:
amram (01-10-2014), clintavo (01-08-2014), CSG Mike (08-22-2013)
Old 08-22-2013, 06:01 PM   #42
CSG Mike
CSG Mike's Avatar
I've seen the same with the DTCs...
Your description of the Raybestos sounds almost exactly like my favorite pad.
TF Brake Duct Cooling Kit Touge Factory Tracking / Autocross / HPDE / Drifting 77 06-11-2015 07:01 AM
Wheel Directory: Vossen VVSCV3 19x8.5 +32 / 19x10.0 +36 mike@vossen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 106 01-18-2015 01:36 PM
TF Brake Duct Cooling Kit Touge Factory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 02-19-2013 06:04 PM
APR Performance brake cooling solution whataboutbob Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-18-2013 01:33 PM
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 01:37 PM
