Old 08-19-2013, 04:06 PM   #1387
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
4.7 PSI from this thing?! Subscribed!!!!
Old 08-19-2013, 04:08 PM   #1388
Robftss
Drives: VW
@Robftss since it seems like a lot of us have different ideas about how to improve/modify this have you considered selling a 'Tuner' kit that just had the compressor and motor at a discounted price?
Just a thought.
Presently the compressor head and electronics are matched. Thermal, voltage, rpm and load limits in the controller provide a relationship with the brushless motor to achieve safe, efficient operation.
Robftss is offline   Reply With Quote
Old 08-19-2013, 04:42 PM   #1389
mid_life_crisis
Drives: FR-S 10 #103 AT
Just a thought.
Someone who's more concerned with putting out a safe, reliable product than making a buck.
@Robftss did you ride in on a unicorn stallion?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-19-2013, 04:44 PM   #1390
Grantmac
Drives: 2001 NB MX-5
Originally Posted by Calum View Post
Grant, that is brilliant! Do you have any plans to take it beyond the design phase? I'd love to see that come to market.
I'm more of an "ideas" rather than "plans" guy
I tried to learn CAD once and it didn't go so well. I keep being told that Sketch-up is decent and I should give it a try but computers aren't really my thing.
I was looking at adding it to a relatively small power diesel and I wasn't that worried about intake restriction.
Look at the secondary venturi in a big carb. Something like that within a straight section of tubing would likely do the job. Or even a slightly flared section of tubing if you were worried about flow.
Or find an old side-draft carb then wire it open, plug everything but the main-jet, remove the needle and pressure feed the float bowl (floats removed). Only problem might be finding one large enough to not be a restriction since most of those applications were ITB.
Of course if you are willing to pressurize the tank then you really don't need much for a pump. Even a washer pump will do. It's not like this is a high-boost application.
-Grant
Grantmac is offline   Reply With Quote
Old 08-19-2013, 05:02 PM   #1391
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
-Grant
Too funny because when you fist explained it I was thinking isn't that basically just a carburetor.
Old 08-19-2013, 06:43 PM   #1392
jamesm
-Grant
Sketch up is alright, but its super basic to the point that a more flexible tool is actually easier to use. I'd recommend you try out autodesk inventor. I had been using solidworks at work for a couple years when we switched over, and I find it a lot easier to make multipart assemblies (and do cool things with them) in inventor than in solidworks. Solidworks still has better tools for building individual parts though IMHO.
I believe autodesk has a free version aimed at DIY types.
Old 08-19-2013, 10:16 PM   #1393
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Here's an article about pump-less meth kit.
http://www.alcoholinjectionsystems.c...icle_info.html
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 08-19-2013, 10:38 PM   #1394
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
Originally Posted by Wild Weasel View Post
Technically, it would provide a little control but I have my doubts as to how noticeable it would be. The difference in the restriction of the TB between 75% and WOT is probably somewhat negligible compared to the difference in power you're going to get when the FTS kicks in. I think the bigger advantage will be simply in the feel of it. You won't have to feel like you're mashing the pedal to the floor to get the power boost you want.
OK, so I'm only on like page 39/1000000asdfjklashdf so If this is answered later, I apologize. I think it's a big deal for us AT guys because of the shift points. If I WANT the low end torque, and the sluggish bla and unlocked torque converter of AT non sport in D mode, its just nice to have that diesel style application of torque? Wow this sounds so dumb, don't know how to explain it better though. Ok, so zipping around, I want to hold about 4k rpm and the car accelerates. TCs allow that, it sort of rubberbands. With the car N/A, it makes noise, but doesn't really accelerate. I love the relentless low end surge of turbo'd AT cars. I know it's odd, but diesels, and I drive an F150 ecoboost from time to time, and it's just fun. The f150 in particular is more fun to keep at say 60-70% throttle, below 4k. (scale that from a 5500rpm redline to 7500rpm, and we're talking below 5.5-6k) I just don't want to have to be in TC locked, or jumping gears trying to get to power, since I want forced induction specifically so I DON'T need to jump gears all the time. I mean, simple solution, I could just punch it in manual mode.
Also, I'm in CO Springs.... SO about 6200ft. This car is SLOW at this altitude. Especially off the line. The AT really wasn't bad in Tucson, I could still get sideways from a stop making a right turn or whatever, spun up to only 3k rpm. Now? almost impossible on pavement without have balls much bigger than mine, and using momentum. Just drove to Salt lake, and even there, HUGE difference in low end power. This freaking intake manifold man... SUBARU!!! FIX IT. anyhow. Would the part throttle, ug, forgot what you guys called it, My brain is overload with awesomeness, been reading for a few hours now. But the pulsing to maintain Atm., would that be able to negate the effects of altitude? could it be adjusted a bit higher to see that it does?
@fenton , @Robftss
And lastly, Since flooring below 3000 rpm can't be done on stock tune... does this completely screw me having an auto essentially? Haha. The torque possible at 2200rpm (about where the auto stall is) is immensely intriguing!! I wouldn't have to wait 5 seconds to go anywhere.... I can keep up with other N/A cars in this area (further supporting how shitty altitude is -.- Took a 4.6 Mustang to about 105 from 50) but really off the line, I can floor it, and other "normal" cars just walk away, that aren't even racing... No joke, I seriously was thinking of electric power after being beat to about 35 by an Effin PRIUS. HELP ME.
Thanks a ton for the new product and choice!
zohare is offline   Reply With Quote
Old 08-19-2013, 10:48 PM   #1395
fenton
@fenton , @Robftss
You have to go wot for the system to engage. Yes Drag reduction will help a bit but it references atmospheric pressure to match... so it would match the shity altitude and performance.
I'm intrigued to see how this will work on a auto. It should be pretty seem less. Want to go faster, go wot and you get a quick gear change and your off.
If you want to roll around like a diesel car would you need to lock in gear and just go wot everywhere, you would have a nice surge of torque non stop and is actually surprisingly smooth. Keep in mind with that much torque you will be breaking the speed limit very quickly even if leaving the revs low.
Sent from my HTC One using Tapatalk 4
fenton is offline   Reply With Quote
Old 08-19-2013, 10:55 PM   #1396
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
Attachment 48613
1400 $... omg. Someone is on crack.
Toma is offline   Reply With Quote
The Following 2 Users Say Thank You to Toma For This Useful Post:
TIE Pilot (08-20-2013), zohare (08-20-2013)
Old 08-20-2013, 01:21 AM   #1397
zohare
zohare's Avatar
Hahaha not SOO concerned about that. Thanks for the fast reply. Yeah it'd be fast as hell with the auto... I'm curious with taller gears, and seamless torque how it'd drive. On one hand, other than from a stop, I don't think I'd have to worry about a below 3k CEL because the kickdown, and if I'm driving in M than I'm not at 3k rpm.... Really want to try this, I wish I was closer. I think the AT is going to prove to be really strong. All the FI AT guys have had no issues, and for being N/A I've been plain mean to mine, and it's fine. You guys should find an AT tester. I'd love to, but I'm sure I'm also not the first to volunteer. Note: I am more intelligent than I appear, but I've been on the road since 7am. (I seriously DRIVE my car, so as a tester, not a bad option?) Sweet product though, I can't wait to see the final release, I'm definitely down. I'd probably see what I could do with UniChip and this, I think they'd make a pretty cool budget outta the box type deal. I mean off the showroom floor, you could drop the two in, and off you go!
Old 08-20-2013, 01:53 AM   #1398
sw20kosh
Drives: 2013 Black FR-S
I wouldn't worry about charge temp at 4.7 psi on a centrifugal compressor.
The meth will allow more timing though so you will make power there.
Old 08-20-2013, 02:04 AM   #1399
fenton
Ya I wouldn't expect much other than its increased octane rating. But 15 to 20 HP would be worth it if the price was right
Old 08-20-2013, 02:26 AM   #1400
sw20kosh
Check my build thread in my sig for the system I am using. It is working well.
The 400 cc/min flow rate I am using on the twin screw is allowing for 3-4 more degrees of timing advance.
The problem with this simple inexpensive system is that I must keep it off until boost is at 4-5 psi which translates to about 3.5k rpms WOT. If it comes on sooner the engine loses power and "bogs" untill the airflow gets high enough. I assume the spark is being quenched by the water concentration.
Since this ESC makes 4.7 psi instantly I see you having the same problem with a boost switch or a WOT switch.
You can spend 200 more $ on a MAF based progressive controller if it turns out you are quenching the spark in the lower rpms.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
