Old 08-18-2013, 09:53 PM   #29
Ross
Drives: 85 corolla gts
Spal has some good fans that flow well for there size. I have not touched a full blown set up so I do not know the measurements. But I would recommend to do some measurements, and see if they have anything to fit the bill. I would also look at some adhesive backed silver heat shielding (higher temp rating then gold) for the fan motor and such. I am assuming you have everything you can exhaust wrapped and coated? Have you looked into hood spacers for letting heat out the bay. They may not be super attractive with the body lines but definitely work for letting heat out the bay. Also if you do the hood spacers pull the weather strip from the hood wiper caw (spelling) area and put clips in the caw (spelling). Also have you done anything ducting wise to make sure air has a dedicated path so it has to blow through the intercooler, condenser, radiator and not around it? Just some ideas, I have not had to deal with heat that high but have had issues with hotter running cars with temps around 100f ambient and some of these have helped.
Ross is offline   Reply With Quote
Old 08-19-2013, 06:01 AM   #30
Alhammadi
Drives: 2013 Toyota FT86
check this out,
I guess its the best solution,
http://www.tunersgroup.com/Products/...ler_spray.html
this system better to have on/off switch, to turn on the traffic or while stopping. it should be cheap and it doesn't need much work to do, water pump, wires, switch, and water injector or what ever can spray the water, water tank.
Alhammadi is offline   Reply With Quote
Old 08-19-2013, 09:33 AM   #31
jamesm
Originally Posted by Dipstik-sportech View Post
So you have to cut the stock fan shroud apart? I tried that but it was just too tight to the turbo
yeah, i didn't have to but rev works did. precisely for this reason: smaller aftermarket fans didn't move enough air, unless you keep one full-size one in there.
Old 08-19-2013, 09:37 AM   #32
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
On our track built evo we relocated the small window sprayer nozzles from the hood to the front of the grill. A fairly cheap but effective mod. I think it should work on the 86 too
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Alhammadi (08-19-2013)
Old 08-19-2013, 09:53 AM   #33
Alhammadi
yeah that's another cheap solution and effective as well =)
Old 08-19-2013, 12:33 PM   #34
Djen
Drives: GT86
a big single fan huh sounds wired duno if there is stronger single fan can pull hot hir harder faster. if u found any give us a post.. don't think big single fan work for this car
Djen is offline   Reply With Quote
Old 08-19-2013, 12:37 PM   #35
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I feel that some upgraded SPAL fans and a thin radiator shroud would be the best solution. Just a thin radiator shroud for the included fans might help as well. I know that my downpipe isn't close to touching my fans, so I am thinking about upgrading both, just haven't gotten around to checking sizes yet.
Old 08-19-2013, 12:40 PM   #36
Djen
Drives: GT86
so every hang I fill water for nozzle stuff sounds this solution more for track drives we wanna make it daily drive car like evo/sti or even GTR those cars can handle it even goin hard on them without heat issues
Old 08-19-2013, 12:45 PM   #37
Djen
Drives: GT86
Agreed SPAL Looks like an excellent and the shroud stuff also effectif
Old 08-19-2013, 12:51 PM   #38
SmsAlSuwaidi
Boosted
He is not using a big single fan, he is retaining one stock fan and another slim fan
Old 08-19-2013, 01:18 PM   #39
Djen
Drives: GT86
all turbocharger cars here in middle east will have heat issues I just done properly burped the rad this should help. but still didn't try it ill keep you guys updated..
Old 08-19-2013, 03:39 PM   #40
jamesm
it still has two fans, only one is aftermarket. the other is the larger stock fan. i've had no issues with this setup, in 100+ heat.
Old 08-19-2013, 03:56 PM   #41
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
we run 2 10" flexalite slim line fans on our shop vw builds. 2.8L, 10.5:1 compression turbo builds (450+HP). we have been doing really well with those for the last few years. even with AC. zero fan failures as well with flexalite.
Old 08-19-2013, 08:14 PM   #42
Alhammadi
@Djen
Today I tried my car for the first time with FBM rad, oil cooler and slim fans. as well as the turbo blanket. That set up worked much better than the factory rad with the slim fans. I can tell you its about 30% more effective. still am facing some heat according to the gauge but AC working fine. now the heat goes down very quickly unlike before.
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 11:50 AM
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 01:49 PM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
