Old 08-19-2013, 12:27 PM   #1
swift996
swift996's Avatar
02 Sensor Socket Size?
I bought one and forgot what size it is...does anyone know? I have to install something that calls for a 27mm socket and that sounds right/close.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 08-19-2013, 12:33 PM   #2
d1ck
Drives: Black 2013 FRS
Most O2 sensors are 22mm / 7/8". I've never taken the sensor out of the twins but I'd bet that it's the same size.
d1ck is offline   Reply With Quote
The Following User Says Thank You to d1ck For This Useful Post:
swift996 (08-19-2013)
Old 08-19-2013, 12:37 PM   #3
swift996
swift996's Avatar
You're correct, I do recall buying a 7/8" socket. Thanks, guess I'll run to AutoZone and pick up a 27mm socket.
Old 08-19-2013, 01:06 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Get a 6 point socket if it is for what I think it is. Apparantly it helps.
Old 08-19-2013, 01:25 PM   #5
swift996
swift996's Avatar
It's to tighten up the themostat adapter plate on my Perrin Oil cooler. I just picked up a 27mm socket at AutoZone. My socket sets only go to 19mm so anything above I forget what is what.
Old 08-19-2013, 01:26 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That is what I knew it was for. It is a very difficult nut to get the socket on due to the design of the adapter plate.
Old 08-19-2013, 09:30 PM   #7
swift996
swift996's Avatar
You were not kidding, that adapter design is not socket friendly!
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Socket set and torque wrench Ty89m Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 07-29-2013 12:46 AM
Can't torque my lug nuts socket too shallow :( chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 07-25-2013 10:25 AM
What socket size and what torque amount for stock alloy wheels? Takeshi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-01-2012 10:25 PM
Think all tires of the same size ARE the same size? Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 08:41 PM
