Old 05-13-2013, 03:08 PM   #29
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Originally Posted by GChislett View Post
Hey guys,
I found a setting called... wait for it... "Echo". I toggled it to "off" obviously, and it is 100% better. I have no idea WHY there would be a setting for Echo "on". Duh. I'll see if I can figure out the route to take to get there again. I found it by accident.
US Spec?? Don't we have different headunits than our Maple bros to the north?
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 05-13-2013, 03:19 PM   #30
GChislett
Drives: '13 BRZ
Okay, I just checked. It wasn't that hard to find....
"Home"
"Settings" (bottom right of the screen)
"Bluetooth Settings"
"Echo Cancel" Set to "ON". duh.
GChislett is offline   Reply With Quote
Old 05-13-2013, 03:19 PM   #31
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
I have iPhone 5, it works perfectly fine with the bluetooth & OEM mic. No problem. when I am making calls, people can hear it as clear as it is over the phone./
Old 05-13-2013, 03:20 PM   #32
GChislett
Drives: '13 BRZ
Nope, Cdn car. Not sure what the US has. Mine's a base BRZ.
Old 05-13-2013, 03:21 PM   #33
GChislett
Drives: '13 BRZ
It's possible yours had the correct setting (ie. echo off) from the factory. For Shits/Giggles, check it out to see what it's set at.
Old 08-19-2013, 11:42 AM   #34
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Does anyone know the part number for the USDM (or EUDM) BRZ stock microphone which is integrated into the headliner? I think it looks so much better than the stock one for GT86/FRS which is usually mounted on the steering wheel column or sometimes even on the top-left corner of the windshield. I asked my dealer not to install the mic at all to save the interior and now thinking about installing the one from BRZ and trying to marry it with the stock Toyota unit. Have anyone thought about doing it?
Efferalgan is offline   Reply With Quote
Old 08-19-2013, 04:42 PM   #35
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
I'm confused. The mic for the FR-S is integrated into the headliner.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 09-01-2013, 02:50 PM   #36
Efferalgan
Wow! Did not know that (because never seen an FR-S in person actually ). In European GT86s it's an ugly attacment on the top of the wheel column:
http://2013toyotareviews.com/marango...a-gt-86-coupe/
Anyway, the question stays - what's the Toyota or Subaru part number for the item which goes into the headliner?
Old 09-01-2013, 02:52 PM   #37
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
@lexusb3 can you help this guy out?
Old 09-01-2013, 02:58 PM   #38
lexusb3
Drives: FRS
i will get the part number for you. parts is close Labor day so down time will be a day after i just sent the email for it. send me a PM and it will be a FRS idk if brz has the same part numbers
lexusb3 is offline   Reply With Quote
Old 09-05-2013, 10:57 AM   #39
lexusb3
Drives: FRS
email sent with part numbers and pictures of the the mic @Efferalgan
Old 09-05-2013, 12:18 PM   #40
DSlayerZX
Drives: 2010 Corolla, 2013 Fr-s
that's interesting, I own an FR-S, and so far my co-worker/family members and friends has not complained about the sound quality.
Maybe it's the phone it self? some phone does a better job at filtering the back ground noise in a phone call better than others
DSlayerZX is offline   Reply With Quote
Old 03-29-2014, 11:48 AM   #41
Moletheus
Moletheus's Avatar
Drives: Raven 2014 FR-S
I haven't had a single complaint in my 2014 FRS and I use it every day to and from work for the past 6 months. Im actually worried it wont sound as good when I install an aftermarket head unit. People can say they hear my engine noise when accelerating but thats about it. I never have to yell.
Moletheus is offline   Reply With Quote
Old 02-06-2015, 01:17 AM   #42
dssence
Drives: Toyota FT/MT 86
Originally Posted by luan87us View Post
Not unless you can create a PCB or a network of resistor/capacitor to lets the mic work with your HU.
Hey Listen I have a toyota 86 and wanted to switch to the FRS stereo. Problem is I bluetooth doesn't work unless it detects a mic. so I bought a microphone en electret microphone. But I think this requires more electronics can you help me out ?
I also bought this
http://www.aliexpress.com/store/prod...966377353.html
which is some sort of mic for surveyllance cameras., it's got inside an LM386 OpAMP but it's not working, has three wires red,black ,white .
Red I suppose was power .. from the specs on aliexpress says it requires 9- to +12vcd, then black GND, and white suppose was mic input.
so I tried wiring it this way.
MACC ---> supplies +5 vdc so useless
MIN+ --> tried first MIN+ to white did nothing
MIN- ---> tried then MIN- did nothing I also tried both
SGND --> signal ground --> wired to BLACK
sO no ideas.. if you can help would be great!
dssence is offline   Reply With Quote
replace flywheel? Jeong Engine, Exhaust, Transmission 41 05-19-2022 11:08 AM
Anyone replace rotors yet? NickFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-16-2013 02:38 PM
Looking to replace my sedan carbonBLUE Other Vehicles & General Automotive Discussions 5 01-11-2013 08:41 PM
Which ones do you like to replace the stock rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 11-11-2012 09:53 PM
Replace the speedometer for a gauge TIE Pilot Electronics | Audio | NAV | Infotainment 11 10-03-2012 09:19 AM
