Old 09-27-2012, 07:56 AM   #1
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Talking Replace the speedometer for a gauge
Just an idea. I was thinking since I want to intall a plx dm-200. Where will you install it? No space in the center console, don't like the stand alone options. Crazy idea, I never look the at the analog speedometer because I just keep an eye at the digital one. So for me thats a dead space besides the 5 indicator and warning lights (cruise control, door open, tire pressure, headlights). Wouldn't be nice to have a multi gauge that you can scroll and see the information you want to seen even custom gauges.
For example:
TIE Pilot is offline   Reply With Quote
Old 09-27-2012, 08:46 AM   #2
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
I have one of those in my MR2. Really nice gauge (and a good WB O2 sensor too). I created a custom gauge image set to look like my other Autopower Phantom series gauges in the car. Not sure how to imbed a facebook video, but here's a link to it on my motorsports page:
https://www.facebook.com/takubanmotorsports/videos
It's the video that looks like a gauge. haha. I don't think that style would work well in the FR-S/BRZ since it has more of a white background.
I don't know if it will sit right at that location since the clear plastic is angled. I agree that the speedo is pretty much useless since it gives the speed digitally by the tach. I have mine mounted in a center cubby-lid gauge pod location in my MR2. I don't see the same type of spot on this car. Maybe down by the AC controls or something? I mounted the controller for the gauge to a blank plate where things like the coin holder and stuff would go. That's in a spot close to the steering wheel and easily accessed. So I could see the same location for that piece on this car, but I don't know about the actual gauge.
What modules were you planning on hooking up to the PLX display?
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 09-27-2012, 09:10 AM   #3
TIE Pilot
TIE Pilot's Avatar
two sm-fluid temp to begin
Old 09-27-2012, 05:51 PM   #4
Synack
Boosted
Synack's Avatar
Drives: Sideways
Maybe I'll figure out a way to stack 2 rectangular gauges in that spot. Maybe boost/AFR. Or oil temp.
Old 09-28-2012, 02:17 AM   #5
TonyJZX
Drives: VN Commode
i'd be suggesting an old android phone with torque and a obd dongle
somehow rig it into place and get it to display a gauge etc.
TonyJZX is offline   Reply With Quote
Old 09-30-2012, 01:03 AM   #6
Synack
Boosted
Synack's Avatar
Drives: Sideways
Would be tough because you can't touch anything with the glass there.
Sent from my Galaxy Nexus
Old 09-30-2012, 09:36 AM   #7
jstans84
Drives: Scion FR-S
There is a guy who hooked up a Nexus 7 tablet where his head unit goes and it connects to his bluetooth OBD dongle and can display gauges.
jstans84 is offline   Reply With Quote
Old 09-30-2012, 02:50 PM   #8
xwd
I was planning on mounting one of those newer Greddy multi-DA gauges right there, because I think in the 3 months I've owned the car I've looked at the analog speedo 1 time...
The PLX are nice because the gauges are so thin, but I wish they made them in a little larger size. The Greddy multi gauge is 62mm. It also has a nice junction box for everything both in the engine bay and inside the car, so you are just running one cable between the engine bay and interior. I don't like how the PLX has different boxes for different sensors, although the digital readouts are way more flexible than the Greddy multi-DA gauge.
One thing you can't get through OBD2 is oil pressure which is what I wanted to monitor. Most everything else though you can. I was planning on monitoring oil pressure, oil temp, and water temp. Oil temp and water temp are available through OBD2 with good accuracy.
Old 10-01-2012, 04:59 PM   #9
TIE Pilot
TIE Pilot's Avatar
@dwx i took a look at Greddy multi. Very nice options and features like you said. Where will u install this if you do?
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
Old 10-02-2012, 12:27 PM   #10
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Somebody needs to make a kit for or a swap in option for this exact thing. The analog spedo is useless.
jadewbj is offline   Reply With Quote
Old 10-02-2012, 01:16 PM   #11
d1ck
Drives: Black 2013 FRS
I wonder if some analog to digital circuit could be made to replace the actual speedo signal with a new signal and change out the background of the gauge. A large analog AFR gauge would be very cool.
d1ck is offline   Reply With Quote
Old 10-03-2012, 09:19 AM   #12
Broderick1
Drives: Honda Civic 2009
Before you take anything apart you need to know if there are still areas available.
I recommend if they still are available, that you confirm what areas you need. Keep in thoughts that as well as the wire devices, there are also generate areas in the real estate to which the wire joins. A metal equipment on the outcome base, and a nasty generate equipment in it's own real estate which the speedometer wire joins.
Broderick1 is offline   Reply With Quote
GT Spec - Speedometer issue Loki556 AUSTRALIA 88 05-05-2015 05:14 AM
My limp speedometer bothers me FastLap Scion FR-S / Toyota 86 GT86 General Forum 29 08-27-2012 02:30 PM
Speedometer Accuracy MTeator Scion FR-S / Toyota 86 GT86 General Forum 16 08-22-2012 08:39 AM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
Just replace door speakers? industrial Electronics | Audio | NAV | Infotainment 0 08-02-2012 02:57 PM
