Old 08-16-2013, 02:47 PM   #141
pmccut
Drives: Blue Subarus
Originally Posted by whitefrs View Post
4bar is the beat
I have a 3bar in there now. Good thing it takes about a minute to swap if we want to change.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 08-16-2013, 02:48 PM   #142
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I think a visit to the shop is in order. I need to come check it out.
clayrush is offline   Reply With Quote
Old 08-16-2013, 02:55 PM   #143
pmccut
I'll be here for at least a few hours
Old 08-16-2013, 03:03 PM   #144
clayrush
Ill try to head out about 2
Old 08-16-2013, 09:39 PM   #145
clayrush
It was cool to see how much power you made today.
Old 08-17-2013, 02:17 AM   #146
pmccut
For sure. We left the car hooked up to the dyno so we'll continue iterating on the map in the morning. I'm shooting for 10am.
Old 08-17-2013, 02:41 AM   #147
ft_sjo
Drives: GT86
4bar is the beat
Why is a 4 bar better than a 3 bar?
Old 08-17-2013, 04:55 PM   #148
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Because more is better. We want more we want more.
pmccut (08-17-2013)
Old 08-17-2013, 05:14 PM   #149
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
We really really like it we want more
Old 08-17-2013, 07:18 PM   #150
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
More powaaaaa!!!!!!!!
Old 08-17-2013, 08:44 PM   #151
clayrush
Any luck?
Old 08-17-2013, 09:21 PM   #152
pmccut
Car didn't want to cold start. Even after giving it gas for minutes, it just wouldn't hold idle. LJ knew right away it was a boost leak, but we just couldn't find it until we hooked up an air compressor to the throttle body. Used soapy water everywhere air could've leaked, then we moved onto pb blaster around the hoses connected to the intake manifold...and it started to hold idle for a couple minutes.
It ended up being the PCV hose. It was loose underneath the intake manifold. It was still on...just loose and letting air escape.
Here's the little effer. We're going to clamp these two down once the intake manifold has been removed. That'll be Monday though.
Any luck?
Hopefully this doesn't prevent you from boosting the FR-S
The Following User Says Thank You to pmccut For This Useful Post:
clayrush (08-17-2013)
Old 08-17-2013, 09:23 PM   #153
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That isn't the PCV hose. That looks like the fuel vapor vent hose. I have a hose clamp on all those vacuum hoses under my intake manifold now after I had one blow off at around 15 psi and my car wouldn't run for shit. LJ knew exactly what the problem was.
pmccut (08-17-2013)
Old 08-17-2013, 09:27 PM   #154
pmccut
Doh. Wasn't sure what it was. How many did you have to clamp down? We haven't taken off the manifold yet to see what all needs to be clamped.
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Richmond VA Dyno Day Results 5/4/13 vtmike Engine, Exhaust, Transmission 86 09-17-2013 02:34 PM
Interesting Dyno Results Gen Forced Induction 86 07-31-2013 08:45 PM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Pocket Dyno App Results CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 14 09-12-2012 10:45 PM
