Old 08-14-2013, 10:24 PM   #15
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
The Visconti flex fuel kit burns all the fat from the car.
Heh...
Old 08-14-2013, 10:42 PM   #16
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Heh...
Oh snap.
Wise is offline   Reply With Quote
Old 08-14-2013, 10:59 PM   #17
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
Heh...
Too soon
Old 08-14-2013, 11:00 PM   #18
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Heh...
Instant weight loss into a 10 min car
But yeah driver weight loss and getting a Ti exhaust would help and a CF driveshaft. gutting your interior would help if you want to be drastic
Old 08-14-2013, 11:04 PM   #19
dem00n
dem00n's Avatar
Drives: Scion FRS
Honestly, take a look at your battery boys.
You could save some weight with those lightweight batteries that go for mucho $$$$.
Lithium ion? Something like that.
Old 08-14-2013, 11:05 PM   #20
FRSBRZGT86FAN
Smile
But anyway, I heard someone was able to equal the mt times at an autocross track with an at car and equal the 0-60 times, by pulling out the spare tire and tool kit. Brakes with stainless steel line, wheels and tires would be another good way to lose the weight. FT86 speedfactory makes a very nice lightweight braille battery, but its not the best idea if you live in cold climates or use the car as a Daily driver in those cold climates. A full exhaust with headers if you can emissions allowing. PST makes a nice carbon fiber driveshaft or an aluminum one from another source can be close to the same weight as the carbon fiber one. A full pulley kit from say Go fast bits will take some rotational mass off the front end. If you're willing to go really hardcore you can pull the rear seats and put in a lightweight fly wheel in because apparently a heavy percentage of weight is in that flywheel and it would really help make this engine even more rev happy. Others here can elaborate other techniques, but by doing all that you could easily take 100+ lbs of the car, and even better gas mileage and what not is gained along with handling.
Old 08-14-2013, 11:15 PM   #21
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
My weight savings are muffler delete, lightweight crank pulley, spare tire removed, stripped everything from backseats to trunk, and 16' forged wheels. Don't think I can lose weight myself or the wind would take me away.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 08-15-2013, 10:18 AM   #22
PR FR-S
Drives: 2013 FR-S, Asphalt
I've added weight...
HAHAHAHA!!
Me too...
PR FR-S is offline   Reply With Quote
Old 08-15-2013, 12:04 PM   #23
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by John.Hong View Post
Muffler delete with a nameless performance or berk track pipe sheds 23lbs off the rear in like 5 minutes and $100. Rear seats I believe with base and back weighs around 63 pounds. Spare tire and tools what not lose upto 40 lbs i believe. So for about $100, you shed upto 150lbs. Also cf parts on the exterior of our car dont do much since everything is lightweight. cf doors might help but our factory hood weighs equal to or less than aftermarket hoods so dont waste your money there.
Those are pretty big numbers. Rear seats weigh in around 20. Spare and tools in trunks weigh 30. And the rear muffler weighs 23, so unless your track pipe is weightless that can't be accurate.
OP check these threads:
http://www.ft86club.com/forums/showthread.php?t=42555
http://www.ft86club.com/forums/showthread.php?t=7881
Old 08-15-2013, 12:07 PM   #24
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
Two words. Helium balloons.
oldpueblo is offline   Reply With Quote
Old 08-15-2013, 01:45 PM   #25
John.Hong
John.Hong's Avatar
Drives: 2013 Ultramarine Frs
oh wow. Thanks for correcting me. i thought i read somewhere the rear seats completely off is like 60 lbs. whoops lol
John.Hong is offline   Reply With Quote
Old 08-15-2013, 02:02 PM   #26
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
What about the seats? Swap in some $$$$ CF racing seats I'm sure you'd save some weight.
Aluminum monoblock brake calipers and 2 piece rotors is another expensive option.
Removing the stereo would also help.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 08-16-2013, 12:13 AM   #27
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Replace: wheels, tires, brakes, lug nuts, battery, driver's seat, glass with lexan, aluminum and plastic body panels with carbon fiber, pulleys, headers, front pipe, exhaust, steering wheel, coilovers may be lighter (not sure though)
Remove: spare tire, jack, all other seats, bumper beams, wipers, wiper fluid reservoir, A/C, sound system, dash, the center piece thing that covers your shifter and e-brake area, shifter boot, e-brake lever plastic, upholstery, fat, poop, pee, hair, clothing, shoes, eyewear, heavy thoughts, appendix, spleen, majority of intestines, teeth, every other finger, least favorite eyeball, and... if you're serious... castration
Other: acid dip your chassis, always drive dehydrated, only put the exact amount of gas you plan to burn in your tank, drill holes in everything
That's all I can think of right now, but that should be enough to get you started. If you need some more ideas when you're done with all this, send me a bottle of Stolichnaya, and I'll come up with all sorts of ingenious ideas.
Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere. ACBC
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 08-16-2013, 12:15 AM   #28
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
Drive your car naked
mechaghost is offline   Reply With Quote
Oil filter threading stripped davtbaum Issues | Warranty | Recalls / TSB 53 06-03-2017 01:10 PM
HELP! Lug nut and wheel stud stripped! jaydee_do_work Scion FR-S / Toyota 86 GT86 General Forum 17 07-26-2015 01:50 PM
Weight..... icemang17 Tracking / Autocross / HPDE / Drifting 2 07-02-2012 06:24 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 07:16 AM
Weight of FT-86? Levi Engine, Exhaust, Transmission 38 06-14-2011 10:43 PM
