Old 08-06-2013, 07:58 AM   #29
fstlane
fstlane's Avatar
Drives: BRZ Limited
Originally Posted by garfull View Post
are you maxed out negative on the camber bolts?
No, this is running the factory bolts and alignment. I had hoped to add some negative camber with crash bolts but it looks a little tight.
fstlane is offline   Reply With Quote
Old 08-06-2013, 08:19 AM   #30
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by fstlane View Post
I'm curious also. I'm running 17x9+42 Rota Titans with 245 Direzza Z2 tires and I have about 4mm of clearance. This is with stock struts, camber bolts and alignment. The only thing I replaced was the springs with RCE Yellows.
Do you happen to know your alignment specs in the front? Looks like there's very little space to dial more negative camber in.
raul is offline   Reply With Quote
Old 08-06-2013, 11:53 AM   #31
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Originally Posted by Mach V Dan View Post
Yes, these pictures are of stock suspension. That was the original subject...
--Dan
Mach V
Will your wheels rub with 2 degrees of negative camber? ...let's say with a 255/40/17 tire.
I'm essentially looking for something that will not rub at full lock, yet having the ability to clear everything even with mild drop springs later down the road when I decide to lower the car and add camber bolts.
hmong337 is offline   Reply With Quote
Old 08-06-2013, 01:21 PM   #32
fstlane
fstlane's Avatar
Drives: BRZ Limited
No, I'm sorry I haven't had it aligned yet as I'm waiting on camber plates to arrive. I'm guessing it's pretty close to zero or whatever the factory specs is though. I doubt you could dial in any significant camber with bolts unless you used a 3mm wheel spacer to add a little more perch clearance.
Old 08-06-2013, 01:27 PM   #33
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Originally Posted by whataboutbob View Post
Are you are on stock suspension/ride height? If so, ok. I couldn't get a 255 on a 17x9et35 on my car with the RCE springs/factory struts, Whiteline camber bolts, and COMCs.
With camber from the Com-C top hats, no. I have that now.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 08-06-2013, 09:50 PM   #34
hmong337
Emperor JDM
hmong337's Avatar
--Dan
Mach V
Love the license plate! Lol
How many degrees are you running with the top hats?
Old 08-07-2013, 09:36 AM   #35
Mach V Dan
About 2 degrees.
--Dan
Mach V
Old 08-12-2013, 12:15 AM   #36
peachch
Drives: White 86 Sport Plus
How much camber are you running?
I am running -1.2deg with 18x8" ET 49 , 235/40R18. I am planning to switch to 17"x9" et 40, but clearance is too narrow now.
peachch is offline   Reply With Quote
Old 08-12-2013, 09:31 PM   #37
fstlane
fstlane's Avatar
Drives: BRZ Limited
I am running -1.2deg with 18x8" ET 49 , 235/40R18. I am planning to switch to 17"x9" et 40, but clearance is too narrow teenow.
I'm sorry I haven't had it aligned yet as I'm waiting on camber plates to arrive. I'm guessing it's pretty close to zero or whatever the factory specs is. Your et40 offset is about an ideal compromise between tire poke and strut clearance with a 9" wheel. Which wheel were you considering?
The Following User Says Thank You to fstlane For This Useful Post:
peachch (08-13-2013)
Old 08-12-2013, 10:02 PM   #38
NoppyNop
NoppyNop's Avatar
Drives: 2017 Subaru BRZ, 1994 Mazda Miata
Here is mine with 17x9 +45 offset with 225/45/17 tires.
NoppyNop is offline   Reply With Quote
Old 08-13-2013, 01:13 AM   #39
peachch
I am thinking of TE37
Old 08-13-2013, 08:00 AM   #40
fstlane
fstlane's Avatar
Drives: BRZ Limited
Those are really nice wheels!
Old 08-14-2013, 02:27 PM   #41
svodka
Drives: 2013 BRZ 6MT
Very nice, any rubbing at all? Been looking at 17x9 +45s but hearing that it rubs at full lock on stock suspension..
svodka is offline   Reply With Quote
Old 08-15-2013, 04:44 PM   #42
NoppyNop
NoppyNop's Avatar
So far no rubbing, I took it to the track last weekend and no problems.
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
Picture Request: Stock Turanzas on 8" wide wheels Robmilkshakes Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-17-2013 06:05 PM
WORK Emotion CR Ultimate (Kiwami) - 17x9 +38mm 5x100 IN STOCK NOW RavSpec Wheels and Tires 14 12-01-2012 12:26 AM
17x9 with stock tires? Lee358 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 08-09-2012 04:36 AM
Stock Rims Request Double4Free FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 03-03-2012 03:10 PM
