Old 06-14-2013, 06:41 PM   #1
AceNiNe
AceNiNe's Avatar
Drives: Scion FRS Raven Black 6MT
Camber bolts question
Just recently got lowering springs installed and am looking at getting camber bolts to fix the camber when i get the alignment done. Are the camber bolts the same for the front and the rear? I haven't found any that specified. Thx in advance
AceNiNe is offline   Reply With Quote
Old 06-14-2013, 06:43 PM   #2
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Yes if you search camber bolts you should get the part number as well. They are 5 bucks a piece
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 06-14-2013, 06:47 PM   #3
N_I_N
N_I_N's Avatar
Drives: FR-S [Hot Lava]
I have a question... Are camber bolts the best way to accomplish that? Do they have issues moving?
N_I_N is offline   Reply With Quote
Old 06-14-2013, 06:50 PM   #4
AceNiNe
AceNiNe's Avatar
Good question. I would like to know as well, but I suppose i will just post updates after having them installed
Old 06-14-2013, 06:53 PM   #5
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
If you're talking factory crash bolts being the "camber bolts" then no, they aren't the same front and rear.
The ones people are using in the rear are aftermarket cammed bolts that they've modified slightly to fit.
SubieNate is offline   Reply With Quote
Old 08-14-2013, 01:03 AM   #6
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
do you need to check alignment if all you did was install camber bolts and put them at max negative camber. will this make the front toe in and by how much?
garfull is offline   Reply With Quote
Old 08-14-2013, 10:33 AM   #7
console_cowboy
console_cowboy's Avatar
Drives: 2013 Black BRZ Limited
Yes, you should check your alignment after any adjustment to the camber on our car. For every deg of neg camber, our car toes in by about 3/32 if what I've read is correct. Personally, I get a lifetime alignment on any car I work on and then take it in and get it on the rack whenever I want to make adjustments. This car seems particularly sensitive to alignment changes, so I think any benefit you would gain from camber would be overshadowed by the change in toe-in in the front. I really like how this car feels with 0 front toe.
console_cowboy is offline   Reply With Quote
Old 08-14-2013, 10:37 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
What are these fabled lifetime alignment places? I always hear people talk about them so I went to firestone and bought it. They took my car in and a few minutes later came back and said you can't get lifetime alignment on this vehicle, it has modified suspension parts. So I called around and couldn't find a place that offered lifetime alignment to modified cars. Which makes sense but I still see people say they get this service and I wonder where...
Old 08-14-2013, 10:41 AM   #9
console_cowboy
I guess your Firestone has an annoying manager. I get my lifetime alignment at Firestone and they have no problem working on my modified vehicle. Honestly, I don't know why they would complain (Unless you have coilovers... Lots more adjustment there), even with my rear LCAs, my car is super easy to adjust. I've only added a single adjustment (rear camber) that isn't on the factory car and it honestly makes the alignment easier for the tech. Firestone even lets me go in the back and tell them what to do and how I want it adjusted. If a garage acted like that towards me though, I wouldn't go to them for my alignment.
Old 08-14-2013, 10:50 AM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
It wasn't just the one, I called around after and none would allow it. I found a place that charged $60 and will do whatever spec you want with any mods. They spent an hour to do mine and I was very happy after having no luck with a couple other shops. I'll keep going there until someone can find me a lifetime place in NYC area.
H&R Camber Bolts deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-08-2013 10:00 PM
Where to buy Whiteline Camber Bolts whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-26-2013 03:05 PM
Whiteline Camber bolts question (KCA416) ML Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-02-2013 12:25 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-28-2013 12:38 AM
