Old 08-11-2013, 03:06 AM   #113
pmccut
Drives: Blue Subarus
I got the car back Friday night. Pete@WORKS spent a couple more days working on it. The fuel trims at idle are now in the mid to high teens, so I think we still need to do a bit more work to get it closer to 0. Since it's still on the 7lb spring the plan is to drive it around for a week and go back for more fine tuning and upping the boost. It definitely drives a lot smoother now.
I don't feel it's entirely consistent or smooth with the power delivery, but we'll keep working on it.
The car pulled 293whp and 236lb/ft on their dynapack. With just a perrin resonated exhaust the car hit 140whp on the same dyno.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 08-11-2013, 08:14 AM   #114
charged86
charged86's Avatar
Glad to see things are turning around for ya!
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 08-11-2013, 09:30 AM   #115
mike the snake
It sounds like that dyno reads very low, maybe explaining the lower numbers after the turbo was installed.
In reading about and looking at stock dyno numbers from other dynos, most are in the 155-170 range, so maybe your 293 is actually 300+ on any other dyno.
Old 08-12-2013, 02:11 PM   #116
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
If that is true, then you are making more power than me. Get that thing on a Dynojet.
Old 08-12-2013, 04:39 PM   #117
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
I think thats to much power for m that low psi.
Pics or didnt happen
Old 08-12-2013, 04:43 PM   #118
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
and he is on 91 correct ?
Old 08-12-2013, 05:06 PM   #119
pmccut
Pete@WORKS met me in Oakland, CA @ 8PM to swap cars. I think he only had power/torque plotted and not the AFR/boost with him sadly. I'll be back for those next time I'm up @WORKS. He hasn't changed the 7lb spring (which peaks just under 8psi). Let me see if it's in my backseat somewhere...
E85 all day.
Old 08-12-2013, 05:08 PM   #120
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
ohh shit lol nvm e85 is a whole different story
Old 08-12-2013, 05:30 PM   #121
SmsAlSuwaidi
Boosted
oh e85... Thought you still tried fixing the 91 tune
Old 08-12-2013, 05:41 PM   #122
pmccut
I didn't notice the 'Correction Met Fly Wheel' until now. The stock graph shows the same and is 140hp, so I hope this is really whp and not inflated. I'll have to get one with stock power on the same graph.
Here's the old stock vs turbo map.
The Following User Says Thank You to pmccut For This Useful Post:
clayrush (08-12-2013)
Old 08-12-2013, 05:43 PM   #123
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Those are some of the weirdest plots I have ever seen. Your torque curve and corresponsing horsepower is all over the place. What are your AFRs and timing between 4000 and 5000 RPM?
Old 08-12-2013, 05:47 PM   #124
pmccut
Agreed. It's not smooth at all. On the old maps the fuel trims were crazy high (30-40), now they're between 10-20%, which is obviously still way too high at idle. The plan is to bring it back after living with it for a week and try fine tuning. Is this all MAF scaling if the fuel trims are so high?
I'll try and plot the boost/afr on my AEM wideband. I don't have the plot you want from the dyno run, but I'm sure he has it saved. They're 70+ miles away from me though
Old 08-12-2013, 05:49 PM   #125
King Tut
NASA SpecE30 Racer
King Tut's Avatar
MAF and injector scaling are the two primary things. I have talked to many tuners now, and it seems that getting the injector scaling correct for these Bosch 550cc injectors is not easy.
Old 08-12-2013, 06:01 PM   #126
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
IMO
I would go with a diferrent tuner
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Richmond VA Dyno Day Results 5/4/13 vtmike Engine, Exhaust, Transmission 86 09-17-2013 02:34 PM
Interesting Dyno Results Gen Forced Induction 86 07-31-2013 08:45 PM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Pocket Dyno App Results CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 14 09-12-2012 10:45 PM
