Old 08-09-2013, 12:16 PM   #505
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
Just coz its "OEM" doesnt mean its stock. Im guessing he's using EJ bearings and some modifications.
Originally Posted by Diggitydog89 View Post
yeah true..... this engine is truely un-heard of.... I honestly beleive one day it will be a 2jz replacement as soon as the support parts come into play in the coming years.
I wouldnt compare the FA20 to a 2jz. Maybe a 1uz.
JackSmiley is offline
The Following User Says Thank You to JackSmiley For This Useful Post:
Guff (08-28-2013)
Old 08-09-2013, 12:17 PM   #506
Opposed
Drives: 2013 Asphalt FR-S
Well, if it can outdo the F20 S2000 engine, then we can talk. Those are pushing 800+ on stock internals. But I do think this engine is stronger than people give it credit for. Taking 600 on stock internals is no joke...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
The Following User Says Thank You to Opposed For This Useful Post:
lexusb3 (08-09-2013)
Old 08-09-2013, 12:27 PM   #507
Diggitydog89
Drives: 2005 Chrysler Crossfire
Yeah even tho it wont last long that is seriously impressive.... I can only imagine what kind of power it can dish out with forged internals and sleeved and bore....
Diggitydog89 is offline
Old 08-09-2013, 12:28 PM   #508
Diggitydog89
I honestly like the FRS more than an S2000... S2000 isnt practical at all and its not comfortable to drive..... if i wanted a car that I was going to be cramped inside I'd go with an Aerial Atom.
Old 08-09-2013, 12:29 PM   #509
lexusb3
Drives: FRS
@Frs300 ppl are assuming so much lol I think everyone shall just wait and see
lexusb3 is offline
Old 08-09-2013, 02:07 PM   #510
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Not even an LS can replace a 2jz
SmsAlSuwaidi is offline
The Following 2 Users Say Thank You to SmsAlSuwaidi For This Useful Post:
Nothing (08-10-2013), Sbeezy (08-09-2013)
Old 08-09-2013, 02:16 PM   #511
Diggitydog89
Well maybe this engine will be in a league of its one one day.
Old 08-09-2013, 02:19 PM   #512
cf6mech
Drives: FRS Silver LS1 swapped.
Ok, here again,...do some research folks,...please don't think I'm trashing FRS300 build because I do believe he is running stronger than what comes equipped in the FA20 bearing wise and I believe they are doing it right. I have no skin in the game (except my own car) but every shop and tuner does and they are very hesitant in telling the truth about things,...you can opine why they don't share info for yourself. What better way to see whats what with this car than to talk to someone actually racing this platform, it gives you an idea in the future what to expect from this engine by ringing it out in a short time what we will do in a longer time span. They are running a TRD supercharger at low boost,...first off this tranny is only rated at 210ftlbs of torque, if your planning at anytime to put slicks or semi slicks on this car and run boost, or exceed 210ftlbs and run street tires don't expect the tranny to last long,(good news upgradable gear sets are being made as we speak in Australia)...Hewland has provided a tranny for this race team,....Don at AP has gone to a Tremec after two blown trannies,....none of the drift teams even consider this transmission let alone this engine,...almost all of them swap out the engine and tranny even tho it is capable to produce drift horsepower levels , just maybe not enough at a professional level......don't know not a drifter.
Rod bearings,.Yours truly,...Crawford,....Don,....and the above mentioned race team have either spun or crushed rod bearings, so no isolated incidence here with varying power levels with various tunes, weakness in bearings?,...fuel issue with the OEM ECU knock sensor?,...or oil starvation....its anybody's guess,...the race team isn't taking any chances,...they have now a Motec stand alone.....and have gone to a dry sump system....recommended to me by this race team for cheap insurance run at least a accusump system.
This car was built to a price point,....I don't wonder why a a turbo version wasn't made, the upgrades it would need to support it would put it out of reach for the youthful target it was intended for.
cf6mech is offline
The Following 3 Users Say Thank You to cf6mech For This Useful Post:
Frs300 (08-09-2013), Sbeezy (08-09-2013), Sportsguy83 (08-09-2013)
Old 08-09-2013, 03:29 PM   #513
mike the snake
I know that when I was researching transaxles for my race car, the addition of a transmission oil cooler raised the torque rating of the gearbox by quite a bit.
Unless abused, I bet adding an oil cooler to our transmissions would help keep them together better for turbo applications.
Keeping the heat down inside the gearbox definitely helps when big power is applied, because a lot more heat is produced.
Simple systems can be installed with lines going into a tapped drain plug and into the filler plug.
mike the snake is offline
Old 08-09-2013, 04:22 PM   #514
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
(Current max HP)(current max torque)
(_____________________________) X(miles ran at that power level) = motor score.
(Stock max HP)(stock max torque)
Ie vortech
(263x209) 54967
_______ = _______ = 2.344 x 12000 = 28128
(175x134) 23,450
So my motor score is 28,128.
And since I just kicked it up to 274 whp, I have to redo my score, but my mileage will be alot lower, with this method it takes account how long the motor has lasted.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline
Old 08-09-2013, 04:40 PM   #515
lexusb3
Drives: FRS
^^^?? what
lexusb3 is offline
Old 08-09-2013, 04:55 PM   #516
lexusb3
Drives: FRS
the race team isnt taking any chances but i am !!! i have heard crawford and the others have blown there motors for what ever reason it was. but for example mine was never built. IM sure these do have a weak point like every stock motor! but it has held up so far so good!! this is the main reason for the route that i have been taking with the car i have the funds to have three of them and boosted and built but that makes no sense. I have abused it given rides to many ppl on the forum. and have alot of turbo miles on my car!! and still starts up perfect. I even now consider holding off of the build to add alot more miles on my kit to show people how it can last im here to HELP!!
lexusb3 is offline
The Following 2 Users Say Thank You to lexusb3 For This Useful Post:
Floggin Tires (08-09-2013), Sportsguy83 (08-09-2013)
Old 08-09-2013, 04:58 PM   #517
Calum
That Guy
Drives: 2013 asphalt FRS MT
Rating and actual ability have proven very different in many applications. I'm not saying the tranny is any different then what you're saying, just that the rating is next to useless without real world experience.
Sent from my GT-S7560M using Tapatalk 4
Calum is offline
The Following User Says Thank You to Calum For This Useful Post:
Old 08-09-2013, 06:49 PM   #518
Adeets
OEDC
Adeets's Avatar
Originally Posted by lexusb3 View Post
^^^?? what
It's called maths. It's kinda important.
The only way to compare 2 different things is find a common denominator. Ie current HP/stock HP x miles ran as such to get a number that can be compared. So is the 2jz better? Use the equation and find out.
My BRZ FI Build
Adeets is offline
#car in litigation?, #ferris bueller ferrari?, 12 year build, 5 month engine build, are we there yet?, edging, fantasy, innovate thread pt.2, its happening!!!!, keep calm and carry on, maybe tomorrow?, not today, not viscontiqued ftw, the neverending build, unicorn!, vaporware
Full Blown Stage 1 Short Block FullBlown Forced Induction 116 03-22-2019 07:29 PM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
How often to rebuild coilovers or stock shocks? stockysnail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 12-24-2012 12:54 PM
2013 FR-S / BRZ (The R&D has Begun) Cotnoir CANADA 10 06-26-2012 03:08 PM
PM Spammers, it's begun! Beast Off-Topic Lounge [WARNING: NO POLITICS] 11 01-30-2010 01:13 PM
