Old 08-01-2013, 04:07 PM   #57
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
btw, the stock exhaust system is 2.118" ID
http://www.importtuner.com/powerpage...s/viewall.html
supramkivtt2jz is offline   Reply With Quote
The Following User Says Thank You to supramkivtt2jz For This Useful Post:
Anthony (08-02-2013)
Old 08-01-2013, 05:54 PM   #58
Captain Insano
Invidia resonated midpipe (used on both the N1 and Q300): 8.6 lbs
Invidia catless resonated frontpipe: 7.2 lbs
Captain Insano is offline   Reply With Quote
The Following User Says Thank You to Captain Insano For This Useful Post:
Old 08-01-2013, 07:45 PM   #59
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Here are some more weights for you Anthony
Avo Turbo world Ceramic Coated 2.5" overpipe =2.94 lbs
Avo Turbo World front pipe 2.5" with 5" high flow cat = 9.00 lbs
I suspect of course the non catted version front pipe would be much much lighter but this is certainly acceptable.
The Following User Says Thank You to OICU812 For This Useful Post:
Old 08-01-2013, 08:10 PM   #60
8686
8686's Avatar
Drives: 86
Amuse single exit 8 lb
http://www.ft86club.com/forums/showp...37&postcount=4
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 08-01-2013, 10:10 PM   #61
KyShro
KyShro's Avatar
Drives: 1993 RX-7 R1
Originally Posted by 8686 View Post
OMG, wow! That's the first time Ive seen the Amuse single Ti
KyShro is offline   Reply With Quote
Old 08-01-2013, 11:55 PM   #62
FT86RGV
I think I read somewhere that invidia uses 2.5" tubing for the q300 and N1. the 60mm is the inner diameter.
FT86RGV is offline   Reply With Quote
Old 08-03-2013, 01:23 AM   #63
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Well, we have a new lightest over pipe! Although, only by 0.06lbs. And most people don't get that meticulous with their weights, so who knows what the actual numbers are in hundredths of pounds.
Man, I can't see any of those photos at work. I'll have to look later though.
Well if you find it again, let me know.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 08-05-2013, 09:30 AM   #64
FT86RGV
Here they talk about it in post 13,14
http://www.ft86club.com/forums/showt...highlight=q300
and ft86speedfactory has it listed as 2.5" on their website
http://ft86speedfactory.com/invidia-...-tips-468.html
The Following User Says Thank You to FT86RGV For This Useful Post:
Anthony (08-05-2013)
Old 08-05-2013, 10:13 AM   #65
Anthony
Weight Nazi
Anthony's Avatar
Gah, I hate this nonstandard ID/OD measurement system. I think everyone should only do ID, since piping thickness can vary. Inner diameter is what you're really worried about at the end of the day.
Old 08-07-2013, 04:05 AM   #66
Anthony
Weight Nazi
Anthony's Avatar
Bump for new lightest exhaust and lightest front pipe. @BrianJC's terribly anorexic Amuse front pipe and catback. Review here.
Old 08-07-2013, 08:16 AM   #67
Captain Insano
On this topic, are your first post measurements for diameter all inner diameter or outer diameter? I'm guessing the Invidia are ID.
BTW, the Invidia frontpipe and midpipe are also 2.5 OD and 2.36 ID.
Old 08-07-2013, 08:20 AM   #68
Anthony
Weight Nazi
Anthony's Avatar
They are mostly OD, as far as I know. Most places don't specify what the number is that they're giving you, so I figure it's usually OD.
That would explain the weird 2.36" number.
Old 08-07-2013, 08:22 AM   #69
Anthony
Weight Nazi
Anthony's Avatar
Do you have a source for those numbers? Seems like the exhausts would also be 2.5" OD.
Old 08-07-2013, 09:01 AM   #70
troek
troek's Avatar
Drives: 2012 Toyota 86
i really wish i would have weighted my j2 exhaust before i bolted it on, i know the dual tip is around 40 lbs minus the front pipe, but not the quad tip. anyone have those numbers?
troek is offline   Reply With Quote
Borla UEL headers + HKS Front pipe + Greddy SP AxleBack = music sounds to my ears. NoFear99 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 09-22-2013 11:02 PM
FS: OEM Exhaust and Mid and front pipe Bcarlos Engine, Exhaust, Bolt-Ons 3 07-24-2013 05:16 PM
Exhaust,test pipe, over pipe, headers, or suspension build ShikoBariki Engine, Exhaust, Transmission 20 05-01-2013 04:16 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 12:29 PM
